Question about Broan-NuTone CV570 Central Bagless Central System Cyclonic Vacuum
Nutone cv750 problem
The unit works fine for about 10 solid minutes then trips it's internal breaker. I wait a few minutes and push the reset and it's good for another 10 minutes and the same thing happens. What do I need to fix this problem? Thanks, Jim
  • jlaley Sep 01, 2007
    I did check the filter and even replaced it with a new one. Someone suggested that the circuit board could be causing it to trip. I don't mean the breaker in my panel box. Vacuuming for 10 minutes works fine then it shuts off. If I wait a minute or two the reset button will stay in and it works again for maybe 5 to 10 minutes this time. The motor sounds fine with no laboring or excessive heat coming off it, it just trips. Could the reset button itself be weak?
    I don't have a cv570 model, mine is a cv750 like it says in the title. Are they the same?
    Sergeant:
  • 279 Answers
I doubt that's an electrical breaker - because it wouldn't take 10 minutes to flip, it would happen almost immediately. It must be the heat breaker. There are two reasons your vacuum system could be overheating and tripping that breaker. Either you need to replace the filter - if it's partially clogged then the motor may have to work too hard to get suction and cause it to overheat. I'd suggest checking the filter first, because that's the easy fix. If it's not the filter, then your motor is going out. You'll want to replace that. Check the filter, and let me know. I'll see if I can find a place to order a new motor for it.
Posted on Sep 01, 2007
  • John Goodman Sep 01, 2007
    I don't think it's the reset button. I suppose that's a remote possibility, but the timing of it seems wrong. I could see the reset button causing it to shut down, but I don't see why you would have to wait a minute or two to restart it if that was the case.
    The reason I thought it was a heat problem was because of the fact that it runs for 10 minutes first. However, if the motor is not getting hot, it is likely the internal breaker. I knew you didn't mean your breaker box - there's an internal breaker as well.
    Item 11 on this parts list:
    http://parts.broan-nutone.com/nutone/Sho...
    Ah, I didn't realize. Sorry about that.
    Parts for your model are here:
    However, it is a bit different. From what I can tell, there isn't a separate breaker in this model. I believe it is integrated into the control board (meaning your friend is probably right).
    The board is $153.50 - item 20 on that list. A bit more pricey than just the breaker for the other model.
    Seeing as how the switch is $2.44, and there is a small chance that's the problem, you might want to order that. I think it much more likely to be the control board, but we're talking about $2.44 versus $153.50 for parts.
SOURCE:
Tornado cv30 1
will shut down if the motor over heats check for blocked filters
Oct 16, 2013 | Broan-NuTone Vacuums
My Hoover Duros (blue color, S3000 something model with the power brush) worked fine for 3 years, than it died. The other day I couldn't turn it on... What can it be? A fuse? Where's is the fist in...
manual > http://hoover.com/file/682/
To reset the breaker:
(1) Push the ON/OFF switch
http://hoover.com/file/682/completely
down. You will feel some
resistance when the switch moves
downward. The switch will also move
slightly upward on its own.
(2) Wait one minute.
(3) Repeat step 1.
(4) Turn the cleaner ON and continue
cleaning.
If the brushes continue to stall and
the breaker trips again, clean the
brushes to remove debris. (Figs. 4-1
through 4-4)
To reset the breaker:(1) Push the ON/OFF switch
completely
down. You will feel someresistance when the switch movesdownward. The switch will also moveslightly upward on its own.(2) Wait one minute.(3) Repeat step 1.(4) Turn the cleaner ON and continuecleaning.If the brushes continue to stall andthe breaker trips again, clean thebrushes to remove debris. (Figs. 4-1through 4-4)
Jul 28, 2013 | Vacuums
Nutone cv353 unable to stop
You may have a stuck relay or one of your access port switches may be bad. According to the owners manual: "A complete check of all Wall Inlet and Power Unit low voltage control lead connections (external yellow leads). Turn system off by removing fuse or tripping circuit breaker at
house fuse box."
Dec 27, 2011 | Broan-NuTone CV353 Central Vacuum
NuTone CV750 Central Vacuum won't shut off. The on/off switch on side of unit has no effect. Did continuity test on switch, it tests ok. I've disconnected the low voltage wiring at the side of unit,...
I will assume that you disconnected the switch from the circuit when you did the continuity test -- that is really important.
If so, then i think that the relay inside the top of the unit is stuck on, or the low voltage wires (inside the top) going to the relay are shorted together.
You can easily remove the top after removing 3 (or 4) screws from the upper side of the unit. Be careful to align the vents in the top with the cooling ducts from the motors when replacing the top.
Aug 31, 2010 | Broan-NuTone CV750 Central Vacuum
Motor runs , but no suction at any of the outlets including the one on the side of the unit
if you dont have any suction coming directly out of the unit then you probably have a full container or a dirty filter. look inside the container up by the motor for a filter that can be cleaned or replaced
Jan 01, 2010 | Broan-NuTone CV750 Central Vacuum
The CV750 stopped working. It will come on sometimes but most of time it will not work. I installed new bag and cleaned filter. Green light on side of unit is on. Switch on side of unit will not make it...
The motor may have a sticking brush or a dead commutator segment. Turn off power to the unit to check for sticking brushes. Reapply power, does it now run? If not, shut it off, physically turn the motor a few degrees, and reapply power. If it still doesn't run, look for loose wiring around the motor. If it does run, replace the motor armature or the entire motor if the armature is not available as a separate part.
Oct 18, 2009 | Broan-NuTone CV750 Central Vacuum
Vacuum working perfectly and everything stopped. Went to the utility room and found a plastic bag on top of the equipment. Tried the reset button, etc. nothing works.
sounds like a bad relay in the tank just a simple repair but should be done by a vacuum tech or electrician. Could be a motor is nothing is starting at all, but not as likely.
Jun 14, 2009 | Broan-NuTone CV353 Central Vacuum
Nutone central vac vx550
It's a known problem. I bought my vx550 last year in July and it stopped working this year in May. On for 5 minutes, shut down, can't run for a few hours, runs for another five minutes, etc. I called the Nutone customer service department and they exchanged the unit for a new one, cross shipped, via UPS. Mine was still under warranty though. It has to do with some defective thermostat or controller in the electronics of the vacuum.
Good luck
Sep 11, 2008 | Broan-NuTone VX475 Bagged Central System...
Nutone vx550 vac problem
The vacuum is defective, if you call Nutone and tell them the probelm, they will replace it for FREE, no charge to you. CALL 888-336-6151, that is the Nutone Tech Suport line.
Mar 11, 2008 | Broan-NuTone VX475 Bagged Central System...
Broan-NuTone CV570 Central Bagless Central System Cyclonic Vacuum Logo
453 people viewed this question
Top Broan-NuTone Vacuums Experts
Gerry Harvey
Gerry Harvey
JoeVacs
robert
Are you a Broan-NuTone Vacuum Expert? Answer questions, earn points and help others
