Question about Watches
How to turn off the alarm on xilaration watch fmdx250
How do I set the alarm on model wau111a tag watch
  • Pull out the crown to the alarm setting position. The crown is located on the right side of the face of the watch. Pull the crown out until "AL", the alarm indicator, is shown on the watch. Depending upon the model of your Tag Heuer Aquaracer watch, you will either pull the crown out in the first or second position.
  • Select the hours and minuets for the alarm. Once your watch is in the alarm setting position, press the bottom right button on your watch. This will enable you to select the hours and minuets that you want to set the alarm for.
  • Set your alarm. To begin setting your alarm turn the crown clockwise until the desired hour or minutes are displayed on your Tag Heuer Aquaracer watch. If you happen to accidentally pass the alarm time, turn the crown counter-clockwise the get back to the desired alarm time.
  • Save your alarm. When you are ready to save your alarm, simply push in the crown. Once your alarm sounds, to silence it press any button on your Tag Heuer Aquaracer watch.
  • Nov 06, 2014 | Tag Heuer Link Watches
    Alarm off
    - Keep on pressing mode button on watch till alarm mode appears.
    - to verify alarm mode check out the time alarm rings and match it with the display while selecting the mode.
    - press adjust button to disable
    - or press two buttons on right of watch to adjust the alarm
    Mar 29, 2014 | Casio G-Shock World Time Analog Digital...
    C9 champion digital alarm
    Since you don\'t know how to turn it off, the alarm will give you simple instructions. Just stop pressing the buttons. Is there a symbol or an alarm or clock on any of the buttons?
    May 10, 2013 | Watches
    How do I turn off the alarm on my Armitron watch?
    I don't know whether this is what you are looking for, as the watch comes with no packaged instructions OR general support, on their website, XD,
    Nik.
    http://home.earthlink.net/~eldonenew/armitron.htm
    or
    http://www.ehow.com/way_5786808_armitron-all_sport-watch-instructions.html
    Armitron All-Sport Watch Instructions By Brian Walker eHow Contributor 9 Found This Helpful The Armitron All-Sport is a unisex style of watch made by Armitron that features a digital readout and four buttons around the outer dial for adjusting various aspects of the watch. It can set alarms, keeps the time as well as the date, and has a built-in backlight. Accessing and adjusting these various settings is a fairly simple process.
    Other People Are Reading
    Setting Date, Time and Alarm
    • To enter the date and time setting mode, press and hold the "mode" button, located on the top-left of the watch. Continue holding this button until the display begins to flash. This first display is the alarm setting, should you choose to set an alarm to go off. If you'd like to set the alarm, use the "alarm" button on the bottom-right of the watch to advance the hours to the desired one. Then press the mode button again; this will cycle through the minutes and seconds of the alarm to allow you to set those as well. Once you have set the alarm, you can press the "date" button at the top-right of the watch to proceed to the regular time setting. These numbers, which will now be flashing, also are adjusted by pressing the alarm button to change them. Pressing the date button again will now cycle through the hours, minutes, seconds and the date. As you continue to press the date button, the All-Sport will continuously cycle through these options; don't worry if you forget to set one, you can simply press the date button a few times until you get back to the setting you need to change. Once the alarm, time and date have all been set, you can press the mode button one more time to exit to the normal watch mode that will display the date and time.
    Using Chime and Alarm
    • The Armitron All-Sport features both an alarm and an hourly chime. The alarm function will cause the watch to continuously beep at the selected time until you turn it off by pressing a button. The chime will cause the watch to beep once every hour. You can turn both these features on and off by pressing and holding the alarm button and while holding it pressing the date button. The first time you do this, the chime will turn on and a small house symbol will be displayed on the watch face. Performing this button-pressing sequence again will turn on the alarm, which in turn displays a small clock icon on the watch face. Each successive pressing of this button sequence will alternate between the chime and the alarm, turning them either on or off.
    Backlight
    • The All-Sport also features a built-in backlight to help you view the watch in dark conditions. This light can be activated by pressing the "light" button on the bottom-left of the watch. Pressing this button is the only way to activate the light, and doing so will only cause the watch to illuminate for a few seconds at a time.
    Read more : http://www.ehow.com/way_5786808_armitron-all_sport-watch-instructions.html
    Jul 20, 2010 | Armitron Round Digital Sport 408089 Watch
    Can't turn off the alarm on a timex Expedition Watch
    buy a Casio wrist watch at KMart for around $17.00. They last five years, then the
    band breaks and you buy a new watch. I timed the traffic signal system of our city for 20 years from a Casio wrist watch. Now in retirement, I have a Time Expedition which has several alarms which I do not need, and can't turn off. We change the time twice annually, so having alarms and chimes go off without warning ca bve a nuisance.I found some instructions on a website which shows how to turn the alarms off.
    Jun 02, 2010 | Timex T41091 Expedition Watch
    Turn off alarm
    go to alarm mode and choose the alarm (1-5) using the "forward" and "reverse" buttons, then hold the bottom right button down to toggle it on or off
    Aug 24, 2009 | Casio DB36-1AV Wrist Watch
    Can't turn off alarm
    Here are the instructions to view, change alarm time and turn off alarm:
    From normal time display:
    Press MODE once to display stop watch.
    Press MODE again to change alarm time.
    Press MODE again to change time.
    Press RESET once to display current alarm time.
    Press and hold RESET then press START to turn on and off alarm (watch for alarm symbol on top left)
    Press and hold RESET then press MODE to turn on daily alarm vs one time (watch day marker lines at the bottom)
    Hope this helps.
    May 05, 2009 | Watches
    Turning alarm offI
    how do I turn off the hourly setting
    Jan 19, 2009 | Casio DB360G-9A 30 Pages Telememo Watch
    How to turn off the every hour alarm on my casio 593 watch
    go to mode menu scroll it and find the alarm mode ,when you see in a display a bell it will alarm every hour but if take the bell display it will not alarm every hour..
    Jun 25, 2008 | Casio Watches
    Unwanted alarm
    using the button at bottom left of watch, set to the alarm mode and press the button at bottom right to toggle between alarm settings. The bell and wave symbols will appear and disappear on top left of watch display.
    Jan 08, 2008 | Oregon Scientific SE233 Wrist Watch
    Watches Logo
    27 people viewed this question
    Top Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Watch Expert? Answer questions, earn points and help others
