Question about LG LMVM2075 Microwave Oven
Lg mivrowave preset cook options dont work, show a lock sign
I have a Hot point EM925RCW 900 watt micro wave in my RV. My preset cooking buttons, (popcorn, potato, pizza, nor time cook) will not work but the number cooking works. Syggestions
I would guess either the circuitry for part of the keypad is defective or prehaps more likely the unit has developed amnesia because either the supply to the programmed memory chip is broken or the chip has failed.
It really amounts to the same thing as almost all those components will be on a single board and the repair guy is unlikely to worry about what is wrong but will simply replace the board.
The question is how much is the luxury of presets worth to you and will a repair be significantly less than the cost of replacement?
Jun 13, 2016 | In Microwave Ovens
My built-in-functions are locked.i dont know how to remove that lock.whenever i press that buttons the display shows the lock sign.
Your manual will tell you how to take off the lock. It is usually a combination of buttons pressed at the same time that turns it off and on.
Dec 12, 2014 | Microwave Ovens
Cannot unlock the display panel
Elise,
So I'm understanding that the lock icon stays on no matter what you have tried. I would try pressing and holding the START/STOP button for 5-10 seconds to see if it changes. I don't know how long you've been leaving it unplugged for when you do unplug it, but i would suggest at least 3-5 minutes. If these don't work what I would do is either contact the manufacturer or maybe even a local authorized technician. This way they would be able to assist and possibly have some more suggestions or be able to find and solve the issue for you.
-Best regards-
Jan 16, 2014 | Frigidaire FFMV164LS 1.6 Cu Ft 1,000 Watt...
How do I unlock the key panel
Opening the door while the oven is cooking will greatly shorten the life of the door switches and lead to failure.
Always hit "Stop" first unless the recipe calls for it.
The instructions for the child lock are in the owner's manual.
To set the lock, press Stop/Clear, then hold the "0" pad for more than four seconds. You will hear two beeps and the display will show "LOCKED".
To unlock, hold the "0" pad for more than four seconds. You will hear two beeps and the display will no longer show "LOCKED".
May 18, 2013 | LG LMVM1935 Convection/Microwave Oven
Hello, I have an AEG microwave, 6 years old. When I turn the button to chose the cookingtime and the WATT , the display shows what I choosed so thats OK. When i then press the start button the microwave...
This can be due to wrong choice or fault in the power supply ,main board or the magnetron.
You should try with a preset selection and if the microwave works then the fault relates to correcting the power to time settings.
Check out with microwave cooking tips.
Feb 01, 2013 | AEG MC143EUX 750 Watts Microwave Oven
Whirlpool mivrowave W10292071A MH7140XF Microwave Oven
My whirlpool microwave hasn't worked sice powers outage. Is there usually a reset button or fuse, somewhere
Jan 03, 2013 | Whirlpool MH7140XF Microwave Oven
I have an ifb microwave-ifb25sc2 it is showing a cook option and nothing is getting heated
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
jfkkj
Sep 07, 2010 | LG LMV1680ST Microwave Oven
Our builtin mivrowave open button in jammed
just pulled out the button and saw a hook broken inside.
removed the hook and put the button back and it works
May 07, 2009 | Whirlpool MH7140XF Microwave Oven
My microwave is locked and i dont know how to unlock it
"Locke" meaning the door? or locked meaning the buttons don't work? If it is the buttons then you have the child lock on. Push and hold the "Start" button for 4 to 5 seconds, and it will unlock.
Mar 12, 2009 | LG LMV2083SW Microwave Oven
I dont know how to use my microwave oven for cooking food.
i dont know how to set temperature and cook in microwave ovan
Jan 31, 2009 | LG LMH1017 Convection Microwave Oven
LG LMVM2075 Microwave Oven Logo
24 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Greg Cann
Greg Cann
Devabhakthuni...
Devabhakthuni...
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
