Question about Miele KFN8662SD Bottom Freezer Refrigerator
Kfn8662sd miele clogs
The temperature display for the fridge on my Miele KFN8662SD fridge freezer is working but the fridge does not chill. If I press the "boost" button, the fridge does get cold and continues to saty cold for the ~2 hours the "boost" is operating. So the mechanical refrigeration system is working and so there must be a problem with the controls. If the temperature display is working then i assume that the temperature probe is working and it is connected to the PCB(unless there are 2 probes). Therefore i expect that there is a problem with the PCB. Is this diagnosis correct? and if so - how do i get to and replace the PCB ?
maklean
  • 1665 Answers
SOURCE: MIELE KFN8762SDED (SS/fridge/freezer)
Have a look at page 5 (KFN8767 Miele refrigerator) it may be similar. Exact model number didnt find.
http://www.miele.co.uk/Resources/OperatingInstructions/KFN%208767%20S%20ed-2.pdf
Posted on Sep 19, 2008
SOURCE: Fridge Freezer will not maintain fridge temp, but freezer fine
My miele fridge freezer has just come up with a fault code F4 where the temp is... what does this mean and how can we fix it???
Posted on Jan 18, 2010
  • 70 Answers
SOURCE: Miele bottom freezer / fridge. Main control panel
Electronic is about 150 pounds plus vat
Ring Miele in UK on phone number below.
01235 233133
Posted on Mar 29, 2010
  • 70 Answers
SOURCE: Miele KFN8462S fridge freezer is displaying an F2 fault code.
F2 Is fridge evaporator sensor faulty it will require new sensor part no.7323301
Posted on Jul 23, 2010
SOURCE: My Miele fridge freezer KFN8762SDED
Hi Jean, Sorry I have no solution - but have an identical issue with my Miele fridge freezer... - In case you have managed to find a solution, I would be grateful if you could let me know what it is, to save me from running around... ?? Best wishes in any case, Guy
Posted on Feb 15, 2011
I have a Miele Kfn 8452 sd who blink 2 leds both in the same time, freezer and super freeze,and i hear the sound alarm, i need to know whats the problem, what is damaged?
Press alarm button once
either left door open too long or temperature too low
adjust fridge to 4 centigrade
freezer to -17 centigrade
Dec 28, 2015 | Miele Refrigerators
Miele KFN8993SDN Freezer temperature to high
Temperature displays
During normal operation, the temperature display shows the temperature in the middle of the refrigerator section and the temperature in the warmest part of the freezer section.
Aug 20, 2015 | Miele KFN12923 SD-2 Stainless Steel 369 l...
How do I set the temperature for miele fridge freezer pigeon pair kfn 9753 iD?
Wait for it to cool
while it dies you will see flashing bars
wait
it will cool
Feb 24, 2015 | Miele Refrigerators
Miele fridge keeps beeping
Door is open (shut it)
or
seal on door is broken ( replace it)
or
temperature dropped too low ( reduce it)
or
door was lett open too long (reset alarm)
- after ffix
press alarm buttons once to switch of beeps
Oct 20, 2013 | Miele KFN8862SD Bottom Freezer...
Miele kf 3855 s-6 fridge part not working. Where is the thermostat?
The PCB is probably the temperature controller and most likely uses electronic temperature sensors in the refrigerator and freezer sections. Not having seen this model before, I'm guessing, but perhaps there is a problem with defrosting such as a clogged defroster drain tube, and the insulation between the freezer and refrigerator is iced up. This could also coat the refrigerator temperature sensor in ice if it is on the divider between the two compartments, thus fooling the controller into thinking the refrigerator is too cold. A manual defrost or drain tube inspection should rule this out.
Jul 16, 2017 | Miele Refrigerators
Drain hole not draining despite poking with blunt tools
Sometimes a guitar string will clear clogs in the tube, They are strong and flexible.
Jun 16, 2011 | Miele KFN8662SD Bottom Freezer...
My Miele fridge freezer KFN8762SDED has a problem in the fridge section. The temperature varies between 4 and 13 degrees. If I put on the super chill the temp comes down to normal, 4 degrees only to rise...
Jan 12, 2011 | Miele KFN8762SDED Bottom Freezer...
Dec 30, 2009 | Miele KFN8762SDED Bottom Freezer...
Apr 01, 2009 | Miele KFN8462S Bottom Freezer Refrigerator
No problem just use the + and - buttons when you have chosen the temp. you want just let go and that is the temp the fridge or freezer will set at.
Aug 19, 2008 | Miele KFN8762SDED Bottom Freezer...
Miele KFN8662SD Bottom Freezer Refrigerator Logo
Top Miele Refrigerators Experts
Starnley Johnwells
Starnley Johnwells
Oloyede Monsuru
Are you a Miele Refrigerator Expert? Answer questions, earn points and help others
