Question about iRiver H340 MP3 Player
Iriver H10 stopped working.
I have had my Iriver for nearly 2 years now and have had some problems with the battery. Now, when I turn it on, it seems as if all the music has been deleted so I can't play anything. However when i connect it with my computer and try to sync it with windows media player, all the music seems to be on there still. I'm not sure what to do, and I dont know how to reset it or reformatt it. Any help would be so useful. Thanks.
Database refresh in option menu, takes a while but then it shows your music in your music's menu. otherwise you can listen your music in the browser
Posted on Jun 28, 2008
The music is still there but the player has errors. To fix it use the error checking that checks for any errors and fixes them. For more info email tonycoolboy45@gmail.com
Posted on Dec 16, 2007
IRIVER WONT WORK AAAAHHH HELP!!!!!? my iriver wont work when i try to turn it on it comes up and says system files missing to restore the system files, connect to iriver plus wat dose that mean i have...
When system files are missing on the player, you will need to reinstall the FIRMWARE.
When looking online for the connection type for the H10 / H10JR, I can see 2 CONNECTION TYPES for the H10 / H10JR:
1. MTP, when using Windows Media Player 11 ( WMP11 ), for the H10.
2. iRiver Plus, when using iRiver PLUS, for the H10JR.
The connection type determines what software on the computer will be used for transferring media.
Each software on the computer needs corresponding firmware on the player to be installed.
When the player itself comes up with the information to connect to iRiver PLUS, this is the correct software for this device probably. Then the device is a H10JR.
When not having the program iRiver PLUS, go to the iRiver support site, for the download:
http://www.iriver.com/flash/index.asp?code=0302
In the left column click Plus3 and go for the download.
Run iriver plus 3 and then select [Tools > Portable Device > Firmware Upgrade] from the menu.
Need more help ? Just post a comment.
In case you have the other model player, the H10, let me know if you need assistance for its recovery.
Dec 15, 2009 | iRiver H10 MP3 Player
Iriver H10 - DB Open Error
one idea...
connect player to your pc using the ums trick
What is the UMS trick on IRiver H10?http://www.zolved.com/synapse/view_content/5942/What_is_the_UMS_trick_on_IRiver_H10
This article tells you how to transfer music to your player The UMS trick is a great thing to know how to do. With it, you can transfer music, or treat your H10 as a harddrive to put anything you want on.
The UMS trick will also allow you to use your H10 with virtually any OS.
For 5/6 GB MTP Models
  • Make sure your H10 is turned off and disconnected from the computer.
  • Take out the battery, wait a second, and put the battery back in.
  • Turn on the hold switch (so that you don't accidentally turn the H10 on all the way).
  • Plug the H10 into your computer.
  • Turn on the H10 while holding the "O" button.
  • You will see the message "UMS Mode" if you have done everything correctly. You can now let go of the "O" button.
For 20 GB MTP Models
  • Poke the "reset" button with a paperclip.
  • You will see the message "Emergency Connection" if you have done everything correctly. You can now let go of the "O" button.
For UMS Models UMS models do not need this trick because they are
always in UMS mode!
---download and run the free playlist maker called easyh10. It will read the music files on your h10, rebuild a playlist and save it to your player.
Feb 03, 2009 | iRiver H10 MP3 Player
Iriver H10 V's Vista
Just to let everyone know I have the H10 6Gb player and the reason your having problems getting the H10 to work with Vista is because it isn't supported by Vista at all even with updating your firmware...
Dec 23, 2007 | iRiver H10 MP3 Player
Windows media player vs. h10 20gb
Fimrware upgrade might actually result in this problem - check the iRiver help forums - i believe I saw a horde of people with this issue
Oct 27, 2007 | iRiver H10 MP3 Player
Database refresh on Iriver H10
I have done this. my iriver is almost full i have the 20gb, when the you do the database refresh, it just takes a really long time. mine takes about 2 hours to finish, once you see the clock on database refresh you cant do anything but wait till its finished.
Oct 18, 2007 | iRiver H10 MP3 Player
Iriver h10 system initializing screen
The only thing I could do was completely delete the data and download everything all over again. I did this using the iRiver Firmware. For now I know no other way to get past this problem.
Aug 17, 2007 | iRiver H10 MP3 Player
Iriver H10 20Gb Jammed
Hi StevieB Try following.1/Prepare a handy tool (straightened paper clip) to insert into "reset" hole atop of H10 2/gently insert tool into reset hole and feel a click 3/ turn on H10 if this works great 4/if H10 continues to jam lock up then it may require reloading firmware sounds complicated but easy steps available chk iRiver support website
Mar 28, 2007 | iRiver H10 MP3 Player
IRiver H10 Problem...
Hard drive finished.
The iriver usses the Microdrive, which is a piece of sh...
I wonder can replace the Microwith the Compact flash.
Ipod mini & Creative can use Compact flash
Apr 09, 2007 | iRiver H10 MP3 Player
IRiver H10
Require more history 1/condition of H10 battery B4 this problem (blown Charger Fuse) occurred 2/perhaps battery condition severly depleted creating high current draw upon initial charge attempt 3/not certain if an circuit protection fuse exists in H10 4/Chk charger wiring for shorts bare contacts etc.
Nov 27, 2006 | iRiver H10 MP3 Player
Iriver backlight not working
Take the battery out and put it back in again.It worked for me!
Oct 02, 2006 | iRiver H10 MP3 Player
iRiver H340 MP3 Player Logo
76 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Mohamed Ismail
Mohamed Ismail
Peter Dragonetti
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
