Question about Sewing Machines
Viking husqvarna e20 top tension too tight
  • 26 Answers
SOURCE: bottom tension to tight
There's hardly any way to significantly adjust the bottom, or bobbin tension. There's just a small, flat spring attached to the side of the bobbin case, under which the thread runs. There's adjustment there. You need to adjust the top thread tension via the small thumbscrew that's against the plates on the top thread tension discs. Increase or decrease tension there until top and bottom threads are equally centered between layers of material.
You can adjust presser foot tension with the knurled nut at the top of the machine. I never had the kind of problem you mention though. I set my machine at about 6 stitches per inch or a little more (max is 5, recommended), and presser foot tension is only heavy enough to pull a single layer of material through.
Hope this helps.
Posted on Jul 13, 2009
  • 371 Answers
SOURCE: husqvarna viking, interlude 435...unable to solve tension problem
Sounds like the tension unit is at fault. First check the bobbin tension by removing the bobbin case. Use a half-full to 3/4 full bobbin. Be sure it is threaded through the bobbin case with thread hanging straight down with tension spring on top. Tie the stitch plate to the end of the thread. If the thread pulls the bobbin out, the bobbin tension is too loose. If it does not move when "jiggling" the bobbin, it is too tight (which is not likely based on your description). Small screw (through an open hole) on the side of the bobbin case adjusts the tension of the bobbin case. Left for loose and Right for tighter. Otherwise, contact local authorized Husqvarna Viking dealer for their assistance. You can find the closest dealer at the Husqvarna Viking website - http://www.husqvarnaviking.com/us Good luck.
Posted on Sep 24, 2009
  • 152 Answers
SOURCE: My sister owns a Husqvarna Viking Iris Embroidery
The Iris Tension unit is controlled by the computer. You can't turn the dial with your fingers. There are 2 buttons on the panel that control the tensioin knob. The graphic looks like rope (sort of) and there is a + and a - on each side of the graphic which increases or decreases the tension.
Posted on Oct 10, 2009
  • 152 Answers
SOURCE: Designer I software compatibility
You need the Husqvarna Viking software to turn those file extensions into the SHV format. It's about $400 at your dealer. Their web site does a nice job of showing its features. You get over 100 fonts and alot of designs too. You would open your current designs on a screen and then re-write them to the floppy or stick depending on your model of D1. It then sends the stitch information with the picture of the design to the floppy so your D1 can display the image. (The SHV format)
The VIP and HUS format don't carry the image file for your machine so it say's, "file not found", when you try to open them in your D1.
Posted on Oct 24, 2009
  • 201 Answers
SOURCE: Husqvarna Viking Designer I breaking needles
Dls8864's suggestion was a very good suggestion - make sure the metal stitch plate is pushed all the way to the back. Also make sure that the thread is feeding freely - if it is catching on something it can cause the needle to be pulled aside and make it break. Does the design fit properly inside the hoop you are using? If the foot and/or needle strike against the side of the hoop, that will cause a breakage. Is the bobbin thread okay - not making a bird's nest underneath?
Posted on Feb 01, 2010
Trying to sew zigzag but the bobbin thread is showing up on top
1. Try to loosen the top tension first.
2. If this doesn't work remove the bobbin and tighten the bobbin.
3. The purpose of this is to have the top and bottom tension even. This is similar to a tug of war. Whichever way is stronger is where the knot will be going. You want the knot in the middle of the fabric.
4. Test your top tension by leaving the foot up. Pull the thread through back and forth. It should be easy. If it isn't you will need to adjust the tension mechanism.
There is a tension set document added to help you.
May 16, 2015 | Husqvarna Viking Emerald 116 Sewing...
Tension problems with Husqvarna Viking freesia 425
the bobbin tension needs to be adjusted by a sewing machine shop. it would be a good idea to have the machine serviced also.
Jun 24, 2013 | Husqvarna Viking 1
Bottom thread comes up to the top, what to do?
bottom threads on top means the top tension is too tight. Loosen top tension.
Oct 05, 2012 | Husqvarna Viking 1
I have a Husqvarna Viking 100. How do I adjust the bobbin tension?
U do not recomend that you adjust the bobin tension, what do you have the top tension set at? It should be between 3 and 4, have you put in a new needle? Also, check to make sure the thread is 'seated' right between the tension disc, if you stil have a problem then your machine is out of time.
Sep 07, 2010 | Husqvarna Viking 1
As Iam quilting with my macine the top stitches are ok, but back of quilt the thread is all boggled up-Tension ??
yes, this is a tension issue. Check your bobbin area. Make sure you have put the bobbin in the case with the H logo up and the thread pulls off the spool in a counter clockwise motion. Make sure the bobbin is sitting in the case and threaded through the "catch" on the bobbin case. Then leave a long piece of thread from the bottom, holding the end of the top thread, lower the needle for one revolution using the handwheel. Does the top thread catch the bobbin thread and pull it to the top? This is done without fabric. Your checking to determine if the top thread catches the bobbin thread and pulls it to the top. IIf it does not, it is most likely hook/needle timing. f it does, gently pull on the bobbin thread and determine if it pulls through with a little resistence (checking bobbin tension). Make sure you are using correct needle -- Schmitz or Inspira needles are recommended (Universal size 80 is standard). Make sure you are using Husqvarna Viking made for your machine -- original ones were green but there are some new colored ones but all have the Husqvarna logo on them. Otherwise take it to an authorized Husqvarna Viking dealer. You can find your closest dealer at the Husqvarna Viking website - http://www.husqvarnaviking.com/us Good luck
Sep 23, 2009 | Husqvarna Viking 1
Problems with tension on machine
Yes, you need to set your top tension higher. and make sure that the top quilt isn't stretched too tight.
Husqvarna viking, interlude 435...unable to solve tension problem
Apr 13, 2009 | Husqvarna Viking 1
Bobbin on a Viking #1+ sewing machine
Could be the bobbin case tension is too tight--are you using a thicker thread than usual? Also, check to make sure that it is the correct bobbin for your machine--several are very similar but if not exact, will not sew properly. Also, if the thread is not evenly wound on the bobbin, there would be problems. Check to make sure the bobbin thread is threaded through the bobbin tension. It may help to tighten the top tension, but if the bobbin case tension is too tight, adjusting the top tension will not completely resolve the problem. The tension is correct when the top and bobbin threads meet in the middle of the fabric--this means that whenever you start a different project, you may need to re-adjust the tension.
Understanding Thread Tension Threads
Learn the Ins and Outs of Troubleshooting Sewing Machine Tension
Sewing Lesson 10 How to Fix Tension on Your Sewing Machine
Jun 19, 2017 | Husqvarna Viking 1
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
