Question about GE Advantium SCA1000H Convection / Microwave Oven
Where can i find a Husky wrench, 66604? - GE Advantium SCA1000H Convection / Microwave Oven
Replacing a fuse
do they look like allen screws or more like stars(torx)?
Dec 31, 2011 | Whirlpool MH2155XP Microwave Oven
The small round metal mesh discs inside the kitchen tap have fallen out & will not stay in when re-inserted. Now the water squirts out at weird angles drenching the kitchen work surfaces. Do I need a...
Hi Jean,
These mesh discs and the part they go into - along with a few other small parts - make up what is called "an aerator".
Most aerators simply screw on threads at the end of your faucet. You can remove it by twisting it. You may need a wrench to loosen it first. Wrap the aerator in thick cloth / towel so that the wrench does not dent or scrape the finish on the aerator body.
Some aerators thread up and inside the faucet - rather than at the end - and need a special wrench to remove
Once removed, you should reassemble the parts and reinstall on the faucet. You may find replacement aerators in Home Depot, Lowe's, etc. if you're missing parts, etc. If changing it out, be sure to bring the old one with you to match.
I hope this helps & good luck!
Sep 22, 2011 | Microwave Ovens
I have a 7560c moen faucet that is loose at base of sink. how do I tighten it Thank You
The faucet is secured by a nut from underneath, and it's hard to reach because of the sink basin. You need a special tool called a basin wrench to get up to the nut and tighten it. This picture shows one in use:
The faucet you have has only one threaded piece and nut, but it's the same principle.You can find basin wrenches at the big-box home improvement places and most hardware stores, or you may be able to borrow one from someone who does plumbing repairs. They aren't expensive if you decide to buy one.
Jul 08, 2011 | Microwave Ovens
Our kitchen faucet has continued to lose water pressure over the past two weeks to the point that it's down to a trickle. We have removed the faucet to look for any clogging and there is none. what could...
You took off the faucet, but did you take the aerator off the spout? That's a very common trouble, especially if you have hard water with lots of minerals. The aerator screen gets clogged and your water slows to a trickle or is stopped entirely.
The aerator just screws onto or into the faucet, but you might need a wrench to remove it if it hasn't been off in a while. Tape the jaws of the wrench to keep from damaging the chrome unless you plan to replace the aerator. Once it's off the faucet you can take the aerator apart, noting the order of the pieces, and clean off the screen. Reassemble it and put the aerator back on and you should have your water back.
You might also just want to replace the thing; you can find replacements at hardware stores and home improvement places. Just take the old one along to make sure you're getting the right replacement.
Mar 12, 2011 | Microwave Ovens
Need installation instructions for replacing door handle on kitchenAid microwave oven model KHMSi55LSS0
Remov fan cover, bottom plate, you can either do it right and pull out the entire plastic baffle to reveal the hindge bolts or you can just jam something between just enough to get a long socket on a small socket wrench. You must replace the entire door. Trying to replace just handle is almost impossible.
Feb 13, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Broken door handle on GE JVM1490 900 Watts
Go to ;
http://www.appliancepartspros.com/
and enter the model number etc of your unit. Note the diagrams in the left-hand corner of the screen. They also sell parts. Tools will be simple screwdrivers and small wrenches.
Dec 26, 2008 | GE JVM1490 Convection/Microwave Oven
Hood range microwave not heating up
We had one that did the same thing. my brother got so mad at it he put a wrench in it and turned it on. It didn't do anything to it. No power surge nothing. It acted as if I put a plate of food. Lighted up turned and even beeped when done. The wrench wasn't even hot. Now I do recommend this myself. But we went and got antoher one.
There is something in there that magnifys the power inside the mircowave and it sounds like its out.
Dec 12, 2008 | Emerson MW8778 Microwave Oven
Replacing the interior lamp inside the microwave on the top.
Yes, Bobby, it can be done. Before you begin, though, go to Home Depot and look in the tool department. There, ask for a "Husky Pro #66604". It's a 1/4" and 5/16" drive 90 degree ratchet that's about 4 inches long. While you're there, pick up a #2 1/4" drive phillips screwdriver bit. You'll use both of these to do the light. Both for about $12. UNPLUG YOUR MICROWAVE! Stand on a small ladder in front of the Microwave (MW), remove the 2 screws that hold the vent louver in place and remove the louver. You'll now see a black plastic grill (just above the door handle)remove the 2 screws with your new tools and remove the grill and the metal box that covers the relay. Now remove the 2 screws holding the horizontal metal panel that the box was sitting on. Now gently lift that panel up, (don't try to remove it) and you'll see the lamp. It's the one with 2 white wires going to it and a shiny metal cover over it. Place your index finger on the back of the cover of the lamp and gently pull toward you and lift at the same time. This will release the catch and allow you to pull it all the way out to get to the lamp. There ya go! Simple!
Jul 29, 2007 | GE Advantium SCA1000H Convection /...
GE Advantium SCA1000H Convection / Microwave Oven Logo
469 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
