Question about Mitsubishi WD Televison & Video
No picture flashing yellow light - WD Mitsubishi Televison & Video
    Top Expert:
  • Mitsubishi Master
  • 12,223 Answers
Please make this test and fix it.God bless you
  • Reset component settings. Usually, the problems you encounter with a Mitsubishi projection TV may be resolved through the resetting to its factory settings. If you experience inaccuracies in the color, reset the television's PerfectTint/PerfectColor capabilities. Simply press the Menu tab and then highlight "Perfect Color" using your right key arrow. After this, press "Enter" and then "Reset" in order to reset to factory settings. If you have audio / video problems (VCR or DVD player), simply press "Menu" and highlight the "Reset" option.
Reset television controls. In case you cannot fix your TV via its component settings, there are other ways of resetting. Just select "Menu", key in "1, 2, 3", and then press "Enter." In doing this, the TV's manufacturer's specifications will all be restored. If your TV's power system does not function, you should perform a complete system reset. You can do this by clicking on Reset System button located at the TV's control panel. Your television will be turned off and then a green light (LED) will quickly flash for approximately one minute. Once the light has stopped flashing, your TV should immediately turn on.
Posted on Jul 31, 2013
56 in toshiba rear projection tv. When u turn it on the green light comes on and a yellow light flashes 15times followed by a click sound. No picture. What does this mean?
Try going to www.toshiba.com to research your problem and what the 15 flashes of the yellow light means. Try unplugging your TV from the wall for about 30 seconds and then plug it back in. This will re-boot your TV (like re-booting your computer). If still no picture, if could be your bulb, motherboard or color wheel.
Mar 01, 2015 | Toshiba Televison & Video
Cant get good indoor pictures with my i634
the key to good pictures anywhere is lighting. either turn on as many lights as possible, or set your flash to 'always on' (as opposed to auto). if your lights are yellow, you will probably want to use the flash anyway.
Nov 29, 2011 | Polaroid i634 Digital Camera
Installed new lamp. When powered up blue solid light and yellow blinking light (15x) , tv would torn off and on several times trying to light lamp. Once that failed red blinking light and yellow solid...
Hi Genaro,
Blue led light lit solid and yellow led light flashes is an initial attempt of the set to re-light the lamp.Red led flashes and yellow led light solid means that the lamp won't light up that's why it only has sound without the picture.
Since you've replaced the lamp twice and still the symptoms persist, I suspected that the fault came from the ballast board and not on the lamp itself. If the ballast board gone to malfunction, there's no high voltage will produce to light up the lamp and will sensed by the processor and trigger the error code (Flashes/solid led light with color code).
To verify whether the ballast board is faulty or not, check if the lamp will lit by looking through the lamp door louvers at the rear of the cabinet upon turning on the set.
Please let me know what you will find to assist you further.
Jdvillanueva
Nov 05, 2011 | Toshiba 65HM167 65" Projection Television
My indoor photos all have a greeninsh yellow effect
That's caused by lighting. More specifically by the type of lighting in use there. Every different type of light puts out a certain color range, some pink, some green, some yellow, some bluish.
How do you fix it?
1. use flash. Flash puts out a bluish light color balanced for daylight. Most film available today is color balanced for daylight. Problem here is that on camera flashes are weak and only reach about 10 feet. The rest of the picture will be greenish yellow. More powerful flashes extend that 10 feet based on the power they have, and may provide enough coverage. The reach of the flash is also determined by the film ASA.
2. use a filter on the lens. Get an FLD (flourescent-daylight) filter.
3. Scan the negs to digital and correct with Photoshop or another photo editing program.
Jan 24, 2010 | Fuji Photography
Picture loss after picture begins to flash. blue and yellow light
Most likely the lamp is dying. Try replacing the lamp before calling a repair tech. What does the Owners manual say about the blink lights?
Oct 01, 2009 | Toshiba 62HMX84 62" Rear Projection HDTV
No picture, status light flashes yellow
display comes on works 15 seconds no power just leds green
Sep 18, 2009 | Mitsubishi PD-5010 50 in. Plasma...
Bad yellow cast to photos when printed
If you have a yellow cast to your photos, the problem might not be your printer. If you're using a digital camera, indoors under incandescent lighting without a flash your pictures will look yellow.
If this is the case, set your camera's White Balance to Incandescent lighting or use the flash. If all of your pictures, even those taken in daylight, look yellow you'll have to adjust the colors on your printer using the "toolbox" software that comes with it and back the yellow off. I've found that HP printers tend to have better color rendition than Canon.
May 24, 2009 | Canon Office Equipment & Supplies
The lamp yellow light keeps flashing so nothing works
you need to make sure the door is all the way tight. there is a switch there and if it is not making contact you will get a yellow status light
Feb 22, 2009 | Mitsubishi WD-62528 62 in. LCD Television
It wont take a photo on regular flash
Sounds like your batteries are stuffed, or not of sufficent ma capacity, should be alkline or rechargeable of at least 2500ma
Sep 20, 2007 | Sony Cyber-Shot DSC-P8 Digital Camera
Televison & Video Logo
348 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
