Question about Sewing Machines
Hyundai 60 stitch sewing machine. Needle bends and eventually snaps whenever I backstitch...why? It's like it is hitting something metal, what could it be?
    Problem Solver:
  • 14 Answers
This sounds like a problem with your tension adjustment. The lower adjustment (for the bobbin) and the upper have to work together or you will get loops that can get tangled underneath. they can wrap around your needle if left to build up and snap the needle. My sewing machine has a screw that can be loosened or tightened to correct this underneath, where the bobbin is. Look for the manual online and see if this is the problem. Hope this helps.
Posted on Jul 31, 2013
SOURCE: singer quantum cxl sewing machine needle hitting metal
Your needle is probably to long or you need to open it more
Posted on Apr 08, 2009
  • 3 Answers
SOURCE: sewing happily on any material when suddenly the
Be sure to have the right needle for the right material! that sounds maybe a bit like I am taking you for a ride! but not! I sew professionally and have a box full of needles! Most of the needles you buy in the shop have a designation (jeans, jersey etc! ) afterwards there is something like 70, 80, 90 up till 100!
70 - very fine fabrics, silks and sheers
80 - fine fabrics, thin cottons
90 - average and 'normal' fabrics
100 and more - thick fabrics, curtains etc!
If your problem persist, you may need to take your machine for servicing! how old is it? and what brand? yours,
rick
Posted on Oct 28, 2009
  • 2501 Answers
SOURCE: Singer 7442 Needle seems 2b 2 long.Hits something below
I could be that the new needle has not been pushed in far enough.
Try loosening the fixing and try pushing the needle further in.
Posted on Feb 13, 2010
  • 223 Answers
SOURCE: Brother XL 3027 sewing machine the needle hit the
That's ok, needles get bent all the time and sometimes broken too. Just give it a new needle (look on the shaft at the top of the needle, you should see a screw to loosen for removing the needle). Note that the needle is made with a flat side on the shank to locate it properly, watch how the bent one is positioned when you remove it.
lp
Posted on Dec 27, 2010
  • 1564 Answers
SOURCE: Toyota rs2000 sewing machine needle hitting metal
Needs to be timed.
Posted on Aug 30, 2012
Why does upper thread snap when backstitching?
May be an issue with the feed dogs, or possibly a burr on the hook. Lay a peice of scrap material under the foot as if you were going to sew, remove needle, then run machine in reverse to see if it feeds material backwards as it should
Nov 07, 2015 | Singer Advance 7422 Electronic Sewing...
Pixie plus sewing machine needle does not go down into the bobbin but hits the metal plate on top of the bobbin. The needle cannot go through the sewing slot.
Sounds like your needle is set to off-center. Check your manual. You may have a straight-stitch plate in your machine but you have it set to stitch off center or it is set to zig-zag stitch and the needle is unable to clear the stitch plate.
Aug 13, 2015 | Singer Pixie Plus Sewing Machine
I have a Husqvarna Opal 650 machine that was just purchase in July. I am hired to sew headbands, and we use Coats Transparent polyester thread. It's worked perfectly, until last Saturday it suddenly...
change the needle again, the needle could have a burr
check for burrs in the needle plate area and in the bobbin area
is the needle the right one for the fabric being sewed? was the needle inserted correctly into the needle holder?
is the tension correct for the fabric being sewed?
Oct 14, 2013 | Sewing Machines
I have a brother SE-400 the metal ring that catches the top thread under the bobbing case (the bobbin housing?) hits my needle with every stitch, bending and breaking needles. The timing has been...
The metal ring sounds like the hook you are talking about.
Timing is only one of the issues you must also adjust the needle to hook clearance and needle bar height. The tip of the hook must pass above the eye of the needle in the scarf on the back of the needle without touching the needle. Who adjusted the timing and what did they do?
Oct 13, 2013 | Brother SE400 Computerized Sewing Machine
Needle hits the plate and bends. What would cause this?
try another needle and see if the needle still bends,, if the needle
still does bends then there could be something wrong with the needle
bar and the machine needs to be checked.
Nov 05, 2012 | Kenmore Sewing Machines
I have a Hyundai 60 stitch sewing machine, the needle snapped so I replaced it now it won't stitch! I have changed bobbin, tension, tried different stitches but it still won't stitch! It's...
Take the needle out and put it back in carefully. If that doesn't solve the prob, replace it with another needle, and hopefully it will return to working.
Sep 24, 2012 | Sewing Machines
Hello. I hope u can help me. I cannot get my stitching tight? If I pull the thread it comes right out. Thanks Jodie
You need to backstitch over the beginning and end of your stitching, Jodie. When you start out, manually turn the wheel to put the needle into the fabric. Push the foot pedal to stitch forward a little. Now, reverse over those stitches to nearly where you started stitching. Use the foot pedal to go forward again, stitch to where you want to end. Reverse again, just a 1/4 inch or so. Then take the fabric out and cut your stitching.
This backstitching keeps your thread from pulling straight out. You should always use it with straight stitches and general zigzag stitches. Don't use it with decorative or embroidery stitches, though, as it mars the appearance of them. But if you're doing any type of topstitching that uses straight stitches, backstitch in the area that will be in the seam allowance, ever so slightly, or your top stitching will pull out, too.
Hope that helps!
May 19, 2011 | Kenmore 16622 Mechanical Sewing Machine
Can this machine sew over pins?
You must remove the pins as you sew otherwise you will either break the needle or do worse damage to the machine. Home sewing machines were never meant to sew through metal.
Feb 04, 2011 | Brother LS-2220 Mechanical Sewing Machine
Need to know how to do button holes
for an older sewing machine, one knob usually sets the button cams, or the step by step adjustments. for newer models, there is likely a button hole setting, the icon is probably a button hole (a tall narrow rectangle with thick lines). if none of this works, here are the manual steps for a proper button hole
1) Align needle all the way to the left. Set stitch length to smallest possible. Set stitch width to medium (2 or 3, machines are all different).
2) Stitch down in a line half again as long as the length of the buttonhole (always allow a little extra; it's okay!). Remember not to feed the fabric yourself; let the feed dogs do the work. The stitches will be very close together. This is the left side of the buttonhole.= '
3) Align needle to center. Stitch length remains as small as it gets. Set stitch width as wide as it can go.
4) Backstitch a small bit. Probably no more than 8 or so stitches; you may want to use the handwheel. This is the bottom of the buttonhole: '_
5) After reducing the stitch width to "middle" (same as step 1), you have two choices here: You can either backstitch up the entire right length of the buttonhole (pretty tricky, but a tad faster), or you can crank the needle gently down into the bobbin, lift the foot, rotate the garment 180 degrees, re-align the button hole so the lines will be parallel, and drop the foot again.
6) If you pivoted your garment, the settings for the third stitch are identical to the first stitch. If you did not, align the needle to the right before you backstitch. Either way, this is the right side: '_'
7) Return the needle to center, widen the stitch completely again, and either stitch or backstitch the final side 8 or so stitches.
8) use a seam ripper to rip the cloth in the middle... make sure you do not cut any of the stitching!
Sorry this is so long, I remember making these and wanted to get it down right.
Oct 30, 2010 | Janome MyExcel 3123
Sewing Machines Logo
37 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
