Question about Sharp AR-M205 Copier
Replace developer - Sharp AR-M205 Copier
    Habit-Forming:
  • Sharp Expert
  • 190 Answers
Better a technician replace it...
Posted on Jan 07, 2014
The master please help, error C0F30 minolta cspro ep 4000, what needs to be repaired or replaced or serviced, please help, thank ...
When was the last time the developer was replaced in the developer unit? If has been replaced, then you might have a bad ATDC (Automatic Toner Density Control) sensor Located right below the developer unit. If the developer was replaced when it was done was a vacuum cleaner used? IF so the static electricity from the vacuum clear destroyed the sensor, NEVER USE a VACUUM cleaner to remove the developer. Also when the developer was replaced, was counter cleared to tell the copier developer was replaced, the copier uses the counters to determine certain voltages for certain assemblies, if not image problems and codes can appear. Finally, was the F8 run after the developer was installed before ant prints or copies made? If not buy new developer and start over, counter is to be cleared first, then developer replaced, then F8 run.
Apr 28, 2017 | Minolta Office Equipment & Supplies
Mesin foto copi minolta cs pro ep 4000, setelah saya ganti sponge rol busa, toner tidak mau keuar melalui sponge rol dan keluar kode eror C0f030. mohon solusinya, thank
Apr 02, 2017 | Minolta Office Equipment & Supplies
Sir.mam,
Como solucionar el c2557 de la konica minolta 282
When was the last time the the drum and developer was replaced in the developer unit? If has been replaced, then you might have a bad ATDC (Automatic Toner Density Control) sensor Located right below the developer unit. If the developer was replaced when it was done was a vacuum cleaner used? IF so the static electricity from the vacuum clear destroyed the sensor, NEVER USE a VACUUM cleaner to remove the developer. Also when the developer was replaced, was counter cleared to tell the copier developer was replaced, the copier uses the counters to determine certain voltages for certain assemblies, if not image problems and codes can appear. Finally, was the F8 run after the developer was installed before ant prints or copies made? If not buy new developer and start over, counter is to be cleared first, then developer replaced, then F8 run.
Mar 28, 2017 | Konica Minolta Office Equipment & Supplies
Having error code cof-32 on bizhub 211 printer
Did you clear the counters before you replaced the drum and developer? If not Replace the drum and developer again. This time clear the counters for the drum and developer before. This done as such
Have you had the developer and drum replaced or does the screen say Replace PC Drum? There are certain house chores the copier does before "Ready to Copy" it is waiting for them to get done equals "Please Wait". One big item is making sure the developer and toner are properly mixed inside the image unit underneath the drum. Might want to have the developer replaced and drum/cleaning blade normally done all together, then run the F8 procedure and make sure the counters where cleared Did you recently replace the drum and the developer if so did you clear the counters for the drum and developer. IF not then the copier thinks the new drum and new developer are old. Copier works on the counters that how it know it got a new drum and developer. Get new develop and new drum and have it installed correctly, Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade. (DO NOT USE AVACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. Then reinstall and RUN F8. Make sure the fax line and Ethernet cable is removed can't print anything until the F8 is run. Or you start over with new developer and new drum
Oct 27, 2015 | Konica Minolta bizhub Office Equipment &...
How I can treatment the error 015-0001 in Canon MF8230Cn
Failure in developing disengagement
Developing cylinder disengagement mechanism does not function correctly. Causes Developing disengagement mechanism fault, developing disengagement solenoid fault, developing disengagement sensor fault, DC controller PCB fault. Remedy Check the developing disengagement mechanism. Replace developing disengagement solenoid. Replace developing disengagement sensor. Replace DC controller PCB.
Dec 02, 2014 | Canon Office Equipment & Supplies
How can i fix code error c2557
Have you had the developer and drum replaced or does the screen say Replace PC Drum? Might want to have the developer replaced and drum/cleaning blade normally done all together, then run the F8 procedure and make sure the counters where cleared. Did you recently replace the drum and the developer if so did you clear the counters for the drum and developer, FIRST. IF not then the copier thinks the new drum and new developer are old. The copier works on the counters that is how it knows it got a new drum and developer. Get new developer and a new drum and have it installed correctly. Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade. (DO NOT USE A VACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. Then reinstall and RUN F8. Make sure the fax line and Ethernet cable is removed can't print anything until the F8 is run. Or you will start all over again with new developer and a new drum. YOUR Code deals with the sensor located at the bottom of the image unit. Which monitors the Toner and developer mixture
Nov 14, 2014 | Genuine Konica Minolta Konica Bizhub...
C0f30 error minolta photo copy
When was the last time the developer was replaced in the developer unit? If it has been replaced then you might have a bad ATDC (Automatic Toner Density Control) sensor Located right below the developer unit. If the developer was replaced when it was done was a vacuum cleaner used? IF so the static electricity from the vacuum clear destroyed the sensor, NEVER USE a VACUUM cleaner to remove the developer. Also when the developer was replaced, was counter cleared to tell the copier developer was replaced, the copier use the counters to determine certain voltages for certain assemblies, if not image problems and codes can appear. Finally was the F8 run after the developer was installed before any prints or copies made? If not buy new developer and start over, counter is to be cleared first, then developer replaced, then F8 run.
Sep 29, 2014 | Konica Minolta Minolta Ep4000/ep5000...
Konica minolta continuous printing
Have you had the developers and drums replaced or does the screen say Replace PC Drums? There are certain house chores the copier does before "Ready to Copy" it is waiting for them to get done, so that equals "Please Wait". One big item is making sure the developer and toner are properly mixed inside the developing units next to the drums. Did you recently replace the drums and the developer if so did you clear the counters for the drums and developer, FIRST? IF not then the copier thinks the new drum and new developer are old. The copier works on the counters that is how it knows it got a new drum and developer. Get new developers and a new drums and have it installed correctly. Counters are clear before the unit is yanked out of the machine, then you remove the drums unit replace the developer. (DO NOT USE A VACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. .
Apr 11, 2014 | Konica Minolta Bizhub Press C6000 Copier
Minolta 450 di error code COF32
Have the developer replaced. if you have had the developer replaced and that person used a vacuum cleaner to remove the old developer then the static electricity from the vacuum cleaner destroyed the sensor underneath the image unit. Worse case the main board that sensor feeds is bad now. Go with replacing the developer again first. Then worry about the sensor or the main board. Was the counter reset when the developer was replaced, was the F8 process done after the developer was replaced.. If not then get new developer have the process done correctly, the machine works on what the counters have in them if you replace the developer and don't clear the counters the machine will assume the that old developer is in the machine and adjust the voltages to certain units accordingly when in fact new developer and for that matter the drum also works on that system. is installed causing image problems and codes.
Mar 10, 2013 | Minolta Office Equipment & Supplies
Sharp AR-M205 Copier Logo
22 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
