Question about Bosch KFU 5755 Refrigerator
I have a Bosch KFU 5755 Refrigerator. (Double doors, cooler and freezer), 14 years old. For many years it has made much noise. Is it possible to stop the freezer and just use the cooler? Whan I turn freezer to zero, it is not cooling. The last year it has not defrosted automatically, can I do anything myself? Solveig, Norway
BIKER T
  • 909 Answers
SOURCE: Bosch Cooler is broken
im taking it that the cooler you refer to is actually a general fridge. if its not working, it is either your th/stat which has not reset or if not, assuming your fridge is an auto defrost, look behind the freezer and locate the timer. you should see a plastic knob plus/minus in the middle of the timer. turn the knob and listen if refrigerator comes on. if not call a tech.
Posted on Aug 27, 2007
Sea Breeze
  • 4655 Answers
SOURCE: Bosch cooler fridge who cools too much
In your case I will need to assume that your model is a typical refrigerator with a defrost control and these type have parts that are made up of the major parts for the auto defrost. Auto defrost has a most likely problem found in the timer or electronic defrost control. These are most times found inside the fresh food section and behind the temperature control panel in the photo below marked a E and in that photo it shows a defrost timer in lower arrow and a electronic defrost control in the upper arrow. The next most likely problem would be the defrost heater and defrost thermostat found in the rear of the freezer compartment. Sounds like the defrost system has failed. Most Brand models We are able to handle here in the USA but your model is made ih the UK and I have tried my best to Have your dealers provide me information about parts replacement. A refrigerator is a Refrigerator and that is a fact but your models is designed for your local voltage 220 volt at 50 cycles That is normal home voltage in most countries except th USA. Our voltage for an appliance is 120 volts at 60 cycles so all the electrical components ar different and made different for different countries. When I request parts or diagrams from the UK I am always rejected. Then given a local repair center to service the brand of appliance.
Posted on Sep 09, 2009
  • 118 Answers
SOURCE: Hi . My questionis: Ive got a freezer /
probably defrost problem check for ice behind panel where fan at. defrost t-stat bad is most common
Posted on Oct 27, 2009
heatman101
  • 43501 Answers
SOURCE: Formation of ice in freezer compartment
Here is a tip that will tell you where the water is coming from and how to fix it. The drain hole has froze shut and the water from the defrost will not drain out.
Water Running in Refrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Posted on Aug 20, 2010
heatman101
  • 43501 Answers
SOURCE: Bosch cooler fridge freezer. The
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Nov 28, 2010
Samsung refrigerator loud noise
if the fan is still running when you open the door , the I would be leaving that idea as a last resort
try this
get 2 taper door chocks and put one either side at the back of the fridge
push the cabinet sideways and slip one chock in a bit then do the other side
many noises are from the bottom plate that the compressor is mounted on from tapping on the floor and lifting it a bit stops the noise
the same as when you open the door the pressure on that plate is removed and so it stops hitting the floor
Nov 04, 2015 | Samsung RS261MDWP - 26 cu. ft. Side by...
Hi, My fridge ( 420 ltrs) Top Freezer making constant humming noise ( like a dieasl car engine)like the engine keeps running and try to cool the fridge. 1 year old. When I open the freezer or the...
The noise is the fan hitting ice build up on the coils... it is no defrosting properly...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Oct 14, 2010 | Samsung Refrigerators
My 3 year old Maytag with double doors and freezer on the bottom is making a humming noise. What is it and can it be fixed? Would the warranty cover it?
may be the comp lines and they need to be adjusted . other causes may be fan's / and some time the cold dampner can cause this . best to follow the noise till source is found then is't eas to correct .. mm
Aug 17, 2010 | Maytag MFD2560HES Bottom Freezer French...
Maytag refrigerator clicking noise and stopped working
either inside fan out of alignment or defrost timer could be bad
Jun 02, 2009 | Maytag MSD2756G Side by Side Refrigerator
Old refrigerator is not cold enough
I will need the model number of your refrigerator to help you better. Most older refrigerator have a defrost timer. But not knowing what yours is I won't be able to answer with a good answer. May things that cause the refrigerator to not cool properly are possible. So let me know what you find, Thanks, Sea Breeze
Mar 28, 2009 | GE Refrigerators
Freezer/Refrigerator tempurature swinging wildly
The compressor is overheating and not starting. Could be just the start relay. If this happens again try unplugging it for about an hour then it should work for a while. Heat between doors is normal this is an electric heater designed to keep the doors from sweating. You just noticed it because the refrigerator wasn't cold.
Jun 26, 2008 | Freezers
Loud humming noise as fridge is running
Sounds like the freezer fan is rubbing some wires or possible some foam insulation around the fan. I would look into the freezer compartment fan and go from there. The fan Will Shut off when you open the doors. Let me know how you make out and if you need anymore help.
Thanks,
Bill
Apr 27, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator not cooling but freezer is
Something has stopped the cold air being ducted from freezer side to refrigerator side of things. Possibly duct blocked due to ice build up, evaporator not self defrosting etc. Turn unit off for a few days till it melts and then turn back on. If it was because a door has been left slightly open you will be ok. If for any other reason you will want to have it serviced in the next week or so.
Mar 17, 2008 | Maytag MZD2766GES Side by Side...
Feb 20, 2007 | Bosch KIL24443 Top Freezer Refrigerator
Bosch KFU 5755 Refrigerator Logo
109 people viewed this question
Top Bosch Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
