How do i factory reset my archos gamepad - Audio Players & Recorders
Reset my archos 7.0 reset to factory specs
To perform a manual reset, All you have to do is
1) Take a paperclip
2) Turn the powered on unit around to the back (reverse)
3) Find the reset hole
4) Push the paperclip in the tiny hole marked 'reset' and the unit should go blank.
5) Restart your device and it should be hard reset
More information here:
http://www.archos.com/in/support/support_tech/manuals_gg7.html
Aug 10, 2014 | Archos Tablets & eReaders
Factory Reset for Archos 97 Carbon
I have forgotten the password for my 97 Archos carbon tablet.
I would therefore like you to sent me the Information as to how I can reset it back to the factory settings please.
I also have no data on it, I just want my Archos 97 back.
Look forward to hearing from you soon Frank.
Jun 12, 2013 | Archos 16GB 97 Carbon 9.7" Tablet
How to reset archos it 70 to its factory default
my archos 70b is locked and i forgot my password.what to do now?
Jan 05, 2011 | Archos 70 android tablet Notebook
How do fix my Archos 605 after resettin using factory option
Well If a white screen shows up when you turn it on, select format. Wait for it to finish, then when it asks for a update file, plug it in to the computer and copy the .aos update file to the archos. Don't put it in a folder, just put it the root, (the folder that has the folders for music, video, flash, etc.) Unplug it and the archos should recognize it and proceed with the firmware update.
The Updates can be downloaded here:
for 20GB-160GB
http://update.archos.com/5/a605/a605_r2.1.04/firmware_a605.aos
or for the 4GB
http://update.archos.com/5/a605f/a605f_r2.1.04/firmware_a605f.aos
Aug 25, 2009 | Archos 605 WiFi Digital Media Player
First time charging up of archos 5.just the green light on it didnt say usb enable or charge only.archos logo keeps flashing on and off every few minutes.is this right. it has now been charging for about 4...
Your archos probably has a glitch in it. You might have to do a system recovery of it. First download the latest firmware program from Archos website. Here is a quick possible fix when the screen comes up reset the archos by inserting a paperclip in the reset hole located at the bottom of the unit right of the connectors it might work it might not. if that doesn't fix the problem do a hard reset when the logo screen comes up hold down the volume+ button until the white recovery page comes up. First try repairing the unit if that doesn't work try format and follow the instructions. the touch screen doesn't function during the recovery page so use the volume+&- buttons & power button. When you get done your archos should be set to factory presets so you have to set it up. Good Luck
Jul 09, 2009 | Archos Internet Media Tablet MP3 Player
Cant change back to english from chinese
Try a master reset using the manual, It should reset it factory settings. You can then configure the archos.
May 16, 2009 | Archos 405 Digital Media Player
Firmware upgrade results in arclibrary boot failure
I managed to overcome the problem by doing a factory reset. Unfortunately doing this initially created more problems in that on reboot the main screen appearance looked as it should but was almost inoperable. When the usb cable was connected to my pc the disc did appear on My Computer . The system folder was only 1MB. By good fortune I had copied and saved my Archos files before I carried out the factory reset. Copying the original system files ( about 20MB) back to my Archos returned normal behaviour. Further, two additional buttons appeared. One was a manual arclibrary update button and the other a USB setup button . I cannot get file transfer to operate under windows media player mode and Windows media player 11. No problem though. I use PC hard drive mode and carry out a manual arclibrary update. None of this was possible prior to the factory reset. I believe I would still be having serious problems had I not saved and restored my system files
Feb 08, 2008 | Archos 605 WiFi Digital Media Player
770 people viewed this question
 Grubhead
Grubhead
