Question about Adtran Netvanta 1534 Layer 3 Gigabit Ethernet Switch 2nd Gen
How to set privileged mode password on NETVANTA 1534 L3 switch
4 Suggested Answers
  • 33 Answers
SOURCE: Forgot password of Adtran NetVanta 1224R Switch
  1. Recovering passwords requires direct physical access to a unit. This procedure cannot be performed remotely over Telnet, SSH, or the Web GUI.
  2. Connect a straight through serial cable to the console port of the unit.
  3. Configure a VT100 session (i.e. HyperTerminal or ProComm) using the following settings: 9600 bps, 8 bits, no parity, 1 stop bit and no flow control.
  4. Reboot the unit by removing the power.
  5. As the unit boots, you will be given the opportunity to break into bootstrap mode by pressing the ESC key within 5 seconds.
  6. While in the monitor mode issue the following commands:
Bootstrap# bypass passwords
Bootstrap# boot
Notice that you are issuing the boot command not the reload command following the bypass passwords command. Once the unit has finished booting up, you can issue the enable command and you will not be required to enter the privileged (i.e. enable) password. Once you are in privileged mode, you can view the configured passwords by using the show run command. A new password can also be entered by going into global configuration mode by using config terminal command and issuing the enable password <word> command where <word> is the new password. Also remember to change any Telnet, SSH or Web GUI passwords if necessary.
Below is a sample output of these steps:
Router (1200990L1)
Executing bootstrap...
ram: 268435456 bytes of RAM detected.
Serial Number: LBADTNXXXXXXXXX
Bootstrap version: 11.03.00, checksum: 0F3C, Thu Feb 09 17:40:34 2006
vfs: NONVOL: 120 tracks, 128 sectors/track, 1024 bytes/sector.
eth0/1: initializing...
eth0/1: MAC address is 00:A0:C8:XX:XX:XX
bootstrap: Checking boot configuration...
bootstrap: Primary image is 'NONVOL:/NV5305A-12-01-07b-E.biz'.
bootstrap: User escaped to command line interface.
cli: starting command line interface...
cli: starting user interface
Press '?' for help.
bootstrap#bypass passwords
bootstrap#boot
Posted on Mar 20, 2009
  • 83 Answers
SOURCE: netvanta reset password
Enter admin as the username, enter your admin password, and click the OK button. (The default password is
password.) Here is a link to your manual:
http://www.wedophones.com/Manuals/Adtran/NetVanta%202000%20Series%20Quick%20Start%20Guide%20(Rev%20B)%202nd%20gen.pdf
Posted on May 25, 2009
SOURCE: setting timezones on Netvanta 3200 router
clock auto-correct-dst
clock timezone -5-Eastern-Time
clock set 23:58:00 05 May 2010
Posted on May 06, 2010
I do not know the password to acccess adtran 3430 router. how can I reset the router to reconfigure
Thank you for using FixYa
The default password is 'password' and then 'admin'
uaafqqavnaaaaaelftksuqmcc
http://docs.google.com/viewer?a=v&q=cache:2jM0LFDsYpEJ:www.andovercg.com/datasheets/adtran-netvanta-3430.pdf+Adtran+Netvanta+3430+Router&hl=en&gl=us&pid=bl&srcid=ADGEESj5spjwkyVJC6UyQDNwkyvakTTZSbWo4enx_ZgRd2xVMlQV1Xb-vUjtRni1jRfONgwG5SfKaIvKtgH0FFtuKhbjlU2nDcw8m1JheO2ZyLt3Vtv0hizo49rXEr_Ck7dj-wibAQ6B&sig=AHIEtbRallEW86bs2qN3VdcAR2SK5Nno6w
I hope this was useful and please comment if this was helpful to you.
Apr 29, 2011 | Adtran Netvanta 3430 Router
Is there a way to perform local password recovery on a Netvanta 3200 router?
can you not reset it, there should be a small hole at the back of the router
just push the point of a pen in the hole and that should reset it..
Nov 24, 2010 | Adtran NetVanta 3200 Router
How Can I reset the SMC 8612XL3 switch to default factory mode?
hi there Ramesh -- please rate me
i believe i have what you asked for .. read on
i found the following information
a 2 page overview for this item
http://www.smc.com/files/AR/ds_8612XL3.pdf
home page for this item
http://www.smc.com/index.cfm?event=viewProduct&cid=8&scid=44&localeCode=EN%5FUSA&pid=1179
**MOTHERLOAD**
manual http://www.smc.com/files/AQ/MN_8612XL3_MAN.pdf
command.
Default Setting
None
Command Mode
Privileged Exec
Command Usage
This command resets the entire system.
Example
This example shows how to reset the switch:
Console#reload
System will be restarted, continue ? y
i hope this helps you
Nov 05, 2010 | SMC 8612XL3 101001000Mbps TigerSwitch 1000...
Can you please advise how to do the password recovery on Adtran Netvanta 1335
Call ADTRAN Technical Support at 1-800-4ADTRAN and they will be happy to assist you.
Oct 08, 2010 | Adtran NetVanta 1335 Router (1700515E2)
I have an Adtran NetVanta 1335 Router that keeps shutting itself off everynight after my store does all it downloads. I have put it onto it own power supply, any assistance to help keep it up would be...
You need to enter maintenance mode (a web interface) and check the power settings from there as some of these have the ability to sleep etc at preset times.
sort of added security and green all in one function
Aug 31, 2010 | Adtran NetVanta 1335 Router (1700515E2)
Can not ping our netvanta 3200 from behind a Linksys nat router
The switch between the NAT routers and the Netvanta had some faulty ports ... the physical connection was broken. Once the switch was replaced, the internet connection was restored.
Dec 29, 2009 | Adtran NetVanta 3200 Router
Setting timezones on Netvanta 3200 router
Aug 28, 2009 | Adtran NetVanta 3200 Router
Netvanta reset password
May 25, 2009 | Adtran NetVanta 3200 Router
Bootstrap# boot
Router (1200990L1)
Press '?' for help.
bootstrap#boot
Mar 20, 2009 | Adtran NetVanta 1224R 24-Port Ethernet...
Access any command line
That is the expected behavior of the switch.  If you want to go into privilege mode, you need to type "enable" at that prompt and enter the correct password.
Aug 12, 2008 | Cisco Catalyst 3560-24PS Switch
Adtran Netvanta 1534 Layer 3 Gigabit Ethernet Switch 2nd Gen Logo
246 people viewed this question
Top Adtran Computers & Internet Experts
Gareth Tomlinson
Gareth Tomlinson
Jax Planet
Jax Planet
Are you an Adtran Computer and Internet Expert? Answer questions, earn points and help others
