Question about Sony Audio Players & Recorders
Sony CMT-DX400A on display shows only "HELLO" (Radio, CD, USB not working) help me please.
  • 80 Answers
Its a software problem reflash ur flash ic
Posted on Jan 22, 2014
Testimonial: "Thank you for your answer. I don't know how to reflash. Can you tell me how? I didn't find the firmware. Thanks and regards,"
  • 4234 Answers
SOURCE: sony cmt-hp7 - broken
The unit will attempt an internal reset to start from a known position. If you are hearing mechanical noises, the unit is out of sequence and must be rebuilt. These are not the most straightforward units. If any portion of hte system fails the "startup" sequence, the entire unit will stop. Unfortunately, this may need to see a servicer.
Dan
Posted on Mar 21, 2008
gopakumarg43
  • 74831 Answers
SOURCE: micro hi fi component system sony cmt-ne5 / ne3 I
Hello
Check its sled motor. It is the motor that helps to spin the disc inside. If disc do not spin inside, check the voltage at the terminals of this motor. If it is alright, and comes near to 5VDC, the sled motor is damaged and have to be replaced. OK.
Posted on Jan 24, 2012
SOURCE: new sony hifi system with dab radio model cmt-spz90db
Posted on Feb 10, 2008
  • 4234 Answers
SOURCE: radio does not work
If the unit is only a few months old, returnit for warranty repair or exchange. A power fail should not effect it. Try unplugging it for a few hours to force a system reset. If that fails to resolve the problem, have it serviced under warranty.
Dan
Posted on Jun 04, 2008
SOURCE: cmt-ed1 sony
If you mean the CD spindle hub, not the stabiliser. Then you can buy the PlayStation 1's CD spindle hub  (plenty, just google with keyword ‘Playstation 1 spindle hub’ and you will see)  to replace it.
Just push in the new spindle hub, not too close, not too far, from the laser head.
I did, it worked.
Posted on Dec 17, 2008
Looking for a firmware for Sony CMT-DX400A.
check this for manual.
http://www.manualsonline.com/search.html?q=Sony%20CMT-DX400A
Jun 30, 2016 | Sony Audio Players & Recorders
How do you fix the Display backlight which has stopped working on Sony CMT-CP33MD
The backlight is provided by a simple soldered-in incandescent bulb, mounted behind the display. You will need to disassemble the unit, unsolder the bulb, and replace it with a new one.
May 03, 2015 | Sony CMT-CP33MD CD Shelf System
Sony CD/Radio CMT-EP505: Setting fixed radio stations
Click Sony Support to download instruction manual copy of CMT-EP505 that has operation details of every thing in this system.
Jul 07, 2009 | Sony Audio Players & Recorders
CD is not playing on my SONY Home Audio CMT-EH15
HI. that grinding sound is signaling a lens assembly issue. the linkage and gear assembly seems to be jammed. this assembly must be able to move freely i order for the lens to track the CD. if the lens assembly is stripped or jammed, it will not be able to read and it will shutdown into stand by mode to prevent the motor from damaging itself. its most likely gear failure.
Unfortunately, the repair parts for this unit are only available from sony repair depots and, you will need to contact sony manufacturing in order to receive a repair ticket.
May 19, 2009 | Sony Audio Players & Recorders
How to play an ipod using the (Audio in) system
On the remote click 'Function' and itll scroll through the settings.
Tape, CD, Tuner, Audio In.
Choose Audio In.
I know this may seem annoying but itll work.
Apr 12, 2009 | Sony CMT-NEZ3 Shelf System
Cd player not working
Hello
Replace the laser pickup unit along with its connection wire to main board. OK.
Apr 08, 2009 | Sony CMT-NE5 CD Shelf System
Prestting the stations
All of the presets I have encountered in the last years were thankfully simple; you manually tuned the station, then simply pressed and held the desired button until the display was stable (not blinking).
Mar 17, 2009 | Sony CMT-HP7 CD Shelf System
Sony CMT-NEZ30 no sound, goes to standby
Check your speakers maybe one are about to burn out
Jun 26, 2008 | Sony CMT-NEZ30 Shelf System
Remote for the CMT-HP7
The remote control for model number Sony CMT-HP7 can be found in the link below.
Sony CMT-HP7 Replacement Remote
Apr 16, 2008 | Sony CMT-HP7 CD Shelf System
506 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
