Question about Boating
I have a 69 evinrude selectric 55 will not go into neutral or reverse
    Sergeant:
  • 456 Answers
Check oil in gearbox,solenoids in gearbox could be faulty, is power getting to solenoids,had many probs with these gearboxes when I was an apprentice
Posted on Oct 22, 2013
3 Suggested Answers
  • 6 Answers
SOURCE: 35hp Johnson evinrude outboard not running at full potential
Hi, did you buy your engine used? Sounds like your gonna have to get the carb or carbs cleaned. Its possible you could have a stopped up fuel filter, or not enough spark but i am guessing its gonna be the carbs. They got some gunk in em i bet. Probably old fuel turned to gunk from setting up. I had the same problem on my 40 horse.
Posted on Aug 22, 2009
Testimonial: "Hi, thank you very much for your help, I will strip the carb down and have a look. Once again, many thanks, I am very greatful"
goldbill
  • 184 Answers
SOURCE: I have a 69 55 hp evinrude outboard wit electrical
There were 3 different designs for the electric shift.(including the electro-hydro) They worked different. The earliest one (your right close that) had bendix wires and a drum they wound up on and only went into gear when power was applied. Find the connector on the port side and jumper one wire at a time. This unit was in neutral when the power failed.
The next was only in neutral when the power was applied to the neutral wire. so only apply power to one wire at a time and see if the lower is OK. Believe you needed power to both to get reverse.
If the lower works, you may have a blown fuze (also called "monkey balls" ) under the hood. Thay also had a diode that looked identical, so don't get the wrong part
Check that the power is getting to the lower by trouble lighting the connectors under the hood with the buttons or shifter. Remember some were not hot wires all the time. So find out what you are dealing with and test accordingly.
If the power is not getting there, you will need a new push button switch, but be aware that the buttons look identical, but function differently. You mush get the correct button set. Remember- some united destroy themselves if power is applied wrong.
Use electric ship oil, not 80/90 .
Posted on Aug 24, 2012
Evinrude motor problems
clean the carb jets etc and check fuel pump diaphrams not hard or perished ! balance the carbs also !
Aug 05, 2014 | Sierra Outboard Starters Johnson/evinrude,...
1996 48 hp evinrude owners manual
copy and past or type this in ebay
1996 Evinrude Johnson Service Manual 40 45 48 50 55 - 2 cyl. - FREE SHIPPING * $46.00 covers many J\E engines..
Oct 29, 2013 | Boating
Johnson outboard 25hp
You may be able to find a solution on the iboats.com boating forums.
http://forums.iboats.com/johnson-evinrude-outboards-24/
May 28, 2013 | Boating
I have a 69 55 hp evinrude outboard wit electrical push button shift.. its runs it cranks but no neutral.. so when I crank it I gotta give it throttle and go but go to slow down to put on trailer no...
Aug 15, 2012 | Boating
I need to find and print out a wiring diagram for a 55 horsepower
here is the direct link to evinrude. There you will find what you are seeking.
http://www.evinrude.com/en-US/
Sep 14, 2009 | Boating
I need to find and print out a wiring diagram for a 55 horsepower 2003 Evinrude.
hi there,you can download a wiring diagram from
forums.iboats.com/evinrude hope this helps.regards barry
Sep 14, 2009 | Sport & Outdoor - Others
Aug 22, 2009 | Boating
Need wireing digram for 40hp evinrude boat with elc st
Check out the online info on this site, or on the search window type in 40 hp evinrude wiring diagram and go from there.
Jun 08, 2009 | Boating
Boating Logo
63 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
