Question about Home
Shires shower valve
Water is too hot how can I addust the control to alloe more cold water?
  • 374 Answers
SOURCE: Shaking of the valve D500058BNT Parma Shower, not the pipes
The issue you have is known as water hammer per se. It is the result of water logged air chambers in instances such as yours. The easiest solution is to turn off the water supply to the house and drain the entire system from the lowest point available such as a hose bibb/water spigot. Turn off your electric water heater if applicable as lack of water will burn out the elements. Once this is done turn the water supply back on to the house and bleed the excess air out of each appliance by turning it on and running both hot and cold water until air dissipates. Another cause may be an inadequately secured plumbing system behind the shower itself. The piping should be secured to some cross member to prevent movement caused by water pressure. A special device is made in extreme circumstances and larger systems called a water hammer arrester which does the same job as an air chamber but uses different principles to accomplish the task. I hope this is of assistance to you and thanks for using Fix Ya. If I can be of further assistance please let me know.
Posted on Oct 21, 2008
  • 374 Answers
SOURCE: Not enough hot water
Some higher end models do have an adjustment that is behind the face plate. You would have to remove the handle and the screws in the faceplate to expose them. If you have adjustments they will be located on the brass valve body facing you. You will need a flashlight and a flathead screwdriver to make the adjustment. If your model is not equipped with adjustments you could have a faulty valve stem. The stem is comprised of a rubber band like gasket that separates port holes into which the waters flow. There could be some piece of trash blocking the port not allowing adequate water from the hot side into the valve.Some valves stems are also able to be installed upside down causing the same issue as the ports do not rotate fully to allow adequate supply. However you say that you have adequate pressure on the hot side but not warm enough. There is another possibility also based on the way the shower supply was plumbed but there is no need to go into this unless this does not resolve your issue. I hope this is of assistance and thanks for using Fix Ya. Please let me know if I can be of further assistance.
  • 14 Answers
SOURCE: moen single handle valve tub/shower
The Moen Posi-Temp Valve is a pressure balanced valve and when not used for long periods of time they can stick causing only cold or hot water to pass through the valve.
A New Posi-temp cartridges can be purchased at most plumbing supply houses or big box outlets such as Lowes or Home Depot.
As long as you had cold water before, a new cartridge will solve the problem. In the future it would be wise to occassionally operate the valve at least a couple of times a month in order to keep the pressure assembly from becoming lodged in position. Just follow the instructions included with the new cartridge on the proper removal of the old cartridge and the installation of the new cartridge. a little silicone grease inside of the valve before installing the new cartridge will also help.
Be sure that there is no particles of the old cartridge left in the valve.
sanray
Posted on Dec 27, 2008
  • 597 Answers
SOURCE: No cold water, Only hot water in showers.
The plumbers screwed up when they installed your showers. There are two connections on each shower. one for hot and one for cold. they connected the two hot water lines together with a T fitting and then ran a line to the main hot water line and tied it in. Then they connected the two cold water fittings with a T and ran that line to the main hot water line and tied it in there instead of into a cold water line like they were suppose to. This is the only possible logical solution to this problem. They tied your cold water connections to both showers into a hot water line instead of a cold water line.
Posted on Jun 01, 2009
jeff_drakesr
  • 155 Answers
SOURCE: no cold water from Moen 2253 tub/shower valve,
Here is a quick check to see if the cartridge may be at fault allowing the cold and hot to mix. Turn off the hot water supply, with hot water supply off turn faucet on. Turn to the hot and cold sides, If you have only cold water then your faucet cartridge is at fault or the cartridge housing is worn. Shut all supply valves and remove cartridge and inspect housing for signs of wear. If wear is visible a new shower valve is needes. If none visible replace cartridge. I have included a link of a PDF file an exploded parts list. I hope this helps in solving your problem. Please rate if the answer helps in any way. Good Luck and have a great week. Jeff
Posted on Apr 05, 2010
Why don't I have water pressure on the hot water side of any faucets
Most class a mtorhomes have water valves in your water fill bay that have controls for all faucets. There is separate one for hot and cold.
the hot would be turned off for storage to allow you to drain the hot water heater for storage.
there may be hot water valve for all faucets or one valvefor each faucet.
Jul 21, 2014 | Itasca 2008 Ellipse 40WD
Shower force
Are you wanting to change/switch the hot and cold range of the shower or the temperature max and min? As for the range, the Monitor pressure balance valve may be having build up or problems. This valve controls the mixture of hot and cold water. To fix this, you will need to turn off the water supply, take the pipes apart and clean out the valve (I would recommend a professional). As for the max and min, you may just need to check the water heater pressure in your house. It may not be the faucet at all.
Elisa Jed ' http://www.ryansallglass.com/
Feb 18, 2014 | Delta Home
Getting hot water when shower valve is first opened.
If I understand correctly, you have single handled shower faucet.
Normally there is a wait for hot water to arrive at faucet.
But now hot water is already at shower faucet.
Single handled faucets have a mixing area inside valve where hot and cold come together before going into sink.
This mixing valve can have crossover where the hot and cold can pass through to each other even when faucet handle is off. When single handle faucets get old, this can happen.
How it happens:
For example another faucet is turned on inside house, and pressure differential between hot and cold causes hot water at shower handle to pass through mixing area and into cold water line.
So if another faucet has been run, then that lets hot flow to faulty single handled shower faucet.
To confirm this is the problem: turn on other faucet and put ear against shower faucet to listen for moving water.
This condition may also signal there is a water leak.
The problem is not harmful, but will draw cold water into water heater each time, and is energy wasteful.
Replace faucet or have plumber repair problem.
Feb 19, 2011 | Price Pfister Single Lever Handle Faucet...
Moen shower valve turns on full to cold water but flow becomes minimal when valve is turned to warm/hot. not getting enough warm water to shower. can this be fixed without rplacing the valve?
yes and no. Find hot water heater and insure cold water supply valve is open all the way. check to see if there is a hot water supply value and that its open all the way. If you replace shower value over iron pipe on the hot side it is corroded up replace pipe and value. If copper, find hot side, find value and open it up.
Nov 28, 2010 | Moen & One Handle Tub & Shower Faucet
I've been given an old (10+ yrs) Moen shower control valve that I want to use (it does apparently have pressure balancing built-in), but don't know which side is hot and which is cold. Does Moen always...
Moen and all shower valve manufacturers follow american federal guidelines. Hold the unit in your hand with the handle facing you - the left side is the hot water inlet and the right side is the cold water inlet.
Nov 25, 2010 | Moen & Posi-Temp Single Handle Shower Or...
New Pegasus shower valve that does not get hot water
single water handles are often put back in 180 degrees off, remove the shaft and turn it over
Aug 02, 2010 | Union Pegasus F1228100PBV Series 5000...
Not enough hot water, has to do with a shower valve
Hello, first if any water supply hot or cold is turned off, you will experience trickling as you mention. You must have both cold and hot in order to adjust the temperature on your valve. if you had a plumber intall this unit you should ask him to adjust it. Otherwise here is how:
Rotate the handle counterclockwise to stop and let water run till cold water is purged, check
temperature. Rotate handle to off, remove handle parts (see Disassembly in your manual) and temperature limit stop, rotate clockwise to decrease and counterclockwise to increase maximum hot water temperature, reinstall temperature limit stop and handle (TIP: Do not screw handle in until desired maximum temperature is achieved) Repeat steps until desired maximum
Feb 21, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Water is either hot or cold - no in between.
I found a way to get warm water in the shower, but I'm not sure it qualifies as a solution. After trying everything else I thought that maybe when I was feathering the faucet in the shower toward the cold side so I would get warm water that at a certain point it blocked the flow on the hot water side enough so that the sensor in the hot water heater sensed there was no demand in the line and it shut the water heater off. To test this, I went to the kitchen and turned the kitchen sink faucet all the way to the hot side and then turned it on so that I got a small flow of water. I waited for the water to get hot to be sure the hot water heater was working. Once it was hot, I left it running to keep demand in the line and then I went to the shower and turned the faucet on. When the water got hot I started feathering the control towards the cold side and soon I had warm water. So I think I'm right in that the sensor in the hot water heater was shutting the water heater off when the demand in the shower was lowered to a certain point when I was trying to adjust the water temp in the shower.
So now I can get warm water, but it means I have to leave the hot water running at another fixture in the house to create a false demand in the system so the hot water heater doesn't shut down. Is there a way to adjust the senor in the hot water heater so that it will stay on when I'm using the shower only, so I don't have to waste water by running another faucet when I want to take a shower?
Nov 28, 2008 | Water Heaters
Home Logo
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
