Question about Toshiba CZ32T31 TV
An5515 ic output toshiba vertical - Toshiba CZ32T31 TV
4 Suggested Answers
  • 2318 Answers
SOURCE: Need the vertical output ic part number for my
This set uses the vertical IC part number TA8427K.
Check this website to find the part you need.
Posted on Sep 28, 2009
Testimonial: "Wow, thank you. Gave me the part number, and a place where I can buy one. Really quick to find it and post it here. I surely appreciate it."
bihug
  • 15 Answers
SOURCE: unit has sound, no vertical deflection. caps and
If there's an audio,,it might be the defective Vertical IC...but check first if there's 24v-26vdc supply coming from FBT going to Vcc of Vertical IC.
If there's no Audio,and only white horizontal line in the screen,check the Vertical out of Jungle IC.
Posted on May 03, 2010
Testimonial: "great information, very helpful."
sethdileswar
  • 253 Answers
SOURCE: there are black bars coming from the top and
check vertical section , thare is a condensor must be weak
Posted on Jun 03, 2010
Testimonial: "thanx a lot, i changed all four condensers in the vertical section, my tv is now back to normal, thanks. 10 +."
Videocon crt tv R5313,vertical rolling (an5515-vertical ic)
Feedback capacitor within 1/2 inch of an5515 allowing voltage to pass.This capacitor will be warm to the touch. Be careful, or let someone with more experience complete the repair.
Feb 02, 2015 | Televison & Video
Vertical size is larger
If TheVertical Output IC( Tda8427k ) Has Been Changed,Then 1 Or 2 Of Filter Capacitors Surrounding The IC Is Defective. Changing The Filtering Should Correct Your Problem, Usually The Values Are 220 mfd 50v,100mfd 50v or 47mfd 50v..
May 19, 2014 | Toshiba Televison & Video
Whtie line in middle of toshiba tv cx32h60
The vertical sweep output has failed. Check the vertical output section circuits for any loose solder terminals. Check all the solder terminals of the vertical output IC. Resolder all the suspected solder terminals by applying a little more solder. If these do not help you, replace the vertical output IC.
Jul 07, 2012 | Televison & Video
White line in middle of screen on a cx32h60 toshiba tv
The vertical sweep output is absent. Check its vertical output section circuit for the fault. Check all the solder terminals of that section, and resolder them by applying a little more solder. Take special care to the solder terminals of the vertical output IC. If these do not help you, check and replace the vertical output IC.
Jul 07, 2012 | Toshiba CX32H60 TV
Im not sure if vertical output transistors is the prob, but my tv has picture only in the middle vetically, i change the capacitor and ic, but still it didnt work out, pls help.
Hello
Your assumtion is currect. But the vertical output section of this TV has no transistors at all. It is composed of an IC. Check the soldering terminal connection of this IC legs for any loose soldering first. Just resolder all the solder terminals of this IC by applying a little more solder. In most cases this will solve the fault. If not, check all the surrounding electrolytic capacitors to this IC circuit. If found suspected, replace them. Still fault perists, replace the vertical output IC with same type and number.OK.
Aug 03, 2011 | Toshiba 32A50 32" TV
Where is the la78 located on the tv and where is vertical output ic
bad Vertical Output IC (usually mounted on an aluminum heat sink with the part on it labeled LA78?? or AN?? ) and 1 or 2 bad capacitors. To find the IC follow the 4 wires that come from the Yoke (which is a contained coil of wires slipped over the neck of the picture tube(s)) back to the board. 2 of the wires go to the horizontal o/p and 2 to the Vertical o/p circuit area. the thinner gauge wires are for the vertical.
Nov 06, 2009 | Toshiba 36A50 36" TV
Unit has sound, no vertical deflection. caps and output ic ok. have b+ to output. nothing at pin 2 of output ic.
Oct 12, 2009 | Toshiba 27D46 27" TV
Need the vertical output ic part number for my toshiba 36" model CN36Z71 TV
Sep 28, 2009 | Toshiba CN36Z71 36" TV
Verticle black line
just on a whim I'd say you have vertical output IC circuits in distress.
can you say Warrenty :->
Jun 10, 2008 | Toshiba 42HP83 42 in. HD-Ready Plasma...
Toshiba TV
vertical deflection problem. Vertical output IC, pump up cap, power to output problem, bad connections, jungle IC. Its a good idea to replace all electrolytic caps near the output IC. Bad caps cause it to run hot and self destruct.
Oct 29, 2007 | Toshiba CX36F84 TV
Toshiba CZ32T31 TV Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
