Question about Sewing Machines
Beldray BEL0198 - the top thread is not picking up the bobbin thread. I have rethreaded top and bottom a few times and still not working. The thread is gutermann and the needle no 70. Can you help please?
    Problem Solver:
  • 14 Answers
Make sure your bobbin case is in correctly. If not, the thread won't loop around for the top thread to pick it up.
Posted on Jul 31, 2013
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 67 Answers
First thing to do is fit a BRAND NEW needle - ensure it is the correct type AND that it has been fitted facing the correct direction. Next recheck thread path - use a QUALITY thread (not a cheapie). Esure that the bobbin has been wound on tightly (should not feel spongy when pressed with your nail) and that the bobbin has been inserted correctly into the bobbin case (can go two ways, but the thread will not be feeding correctly unless the bobbin is in the correct way. Still not picking up? .... remove the shuttle hook from the machine and check VERY carefully for ANY slight burring on the hook point, or anywhere along the edges of the hook behind the point. If there are any, they will need to be carefully removed using 400 or finer wet and dry abrasive. None of these solve the issue, then it most likely is timing or the clearance between the needle scarf and the hook - both best done by a technician as part of a routine service :)
Posted on Feb 08, 2015
SOURCE: singer sewing machine model 6012 c
hi
i want to know how i put thread in the sewing machine
thank you
Posted on Aug 23, 2008
i_luv_2239
  • 23 Answers
SOURCE: The needle thread will not pick up the bobbin thread
It looks right but its not. Try looking on the internet for threading instructions. The bobbin winds in two directions, I have never saw a Bernina but I have 2 new machines and the thread goes in and then threads back to the left. Its hard to describe. But if the bobbin isn't right it will not pick up the thread. Write to Bernina for instructions. There are websites that have the directions for free.
Posted on Nov 19, 2008
sew dutch
  • 24 Answers
SOURCE: Top thread won't pick up the bobbin thread
re insert the needle, maybe you did not put the needle up as far as it is to go. Make sure the flat side of the needle is to the back of the machine. Without any thread in the machine hand turn the wheel and look to see if the hook of your bobbin would/could catch the thread (to see if timing is right)
then thread the machine and hand turn the wheel and see what it is doing.
Your timing might be off, but I do not think that is likely. Though it is possible that when the needle fell out, it hit something hard, broke, and pushed the machine out of timing. then you need to bring it in.
Posted on May 26, 2009
  • 136 Answers
SOURCE: will not pick up bobbin thread
Unusual for this machine. Check to be sure the needle is inserted with the flat side to the back of the machine. If it is, remove the needle plate, bobbin and bobbin case. Turn the hand wheel slowly toward you and see if the point of the hook is above or below the eye of the needle when the hook point is aligned behind the needle. If the eye is above the point of the hook the machine is out of time and best taken to qualified technician.
Posted on Jul 04, 2009
miket756
  • 2702 Answers
SOURCE: NEEDLE WON'T PICK UP BOBBIN THREAD
im not!
it needs a good service the timeing has sliped out a little, nothing more that that,,,see its not a lost cause just yet
Posted on Oct 24, 2009
Testimonial: "Thanks! I was hoping to avoid paying for a fix, but it looks like I have to **** it up. So much for being thrifty and restyling my clothes."
Thread not picking up the bottom thread
Remove the top thread from the machine.
Install a brand new needle.
ALWAYS RAISE the presser foot and rethread the top thread!
If it is still not picking up the bobbin thread, then the machine may be out of time. Search for sewing machine timing or take it for service.
Make sure the top tension is set appropriately--the default is the midway point and then tweak it for your particular machine.
May 21, 2017 | Sewing Machines
Top thread not picking up bottom thread
Try installing a brand new needle. Bent or damaged needles sometimes do not contact the bobbin thread to pick it up.
Usually threading is not an issue, but you may want to rethread the machine (be sure to always RAISE the presser foot during threading).
If it still doesn't pick up the bobbin thread, most likely the needle/hook is out of time. Take it for service.
Jun 04, 2016 | Sewing Machines
Machine saying to rethread the upper thread but not picking up bottom thread from bobbin. Constantly rethreaded upper thread still won't sew.
Consult the owner's manual to make sure it is threaded correctly. Install a brand new needle making sure it is installed properly. Also, be sure to RAISE the presser foot BEFORE threading the upper thread.
If it is still not picking up the bobbin thread, the machine may be out of time.
Jan 20, 2016 | Brother InnovIs QC1000 Electronic Sewing...
Beldray sewing machine won't make a stitch
try changing the needle--make sure the needle is the right one for
the fabric being sewed, and also inserted the right way in the needle
holder and all the way up into the needle holder
try rethreading the machine top and bobbin--make sure every
thread guide is used
make sure the bobbin is turned the right way in the bobbin case
if none of these suggestion help then the machine needs to be
checked to see if there is a problem with the timing.
Nov 01, 2012 | Sewing Machines
Have been trying to adjust the bobbin pick up and seem to get that part the the thread gets caught in the bobbin mech or knots up on material
try to rethread top and bottom, and make sure the thread is seated in the top tension disc. I have owned a few Whites and had a lot of timing issues with them
Aug 14, 2010 | White Sewing 1418 Mechanical Sewing...
The bottom thread is all tangled. I have
Hi! This is the machine I use (mostly) and I've found it really doesn't like lint. I brush out lint every few hours and it has made a huge difference in how my machine sews. I suspect your machine may be as sensitive to lint as my is, so give her a really good cleaning. Then, rethread (yes, I know you've done that already, but do it again, for grins.) everything. Pay careful attention to the way the bobbin thread comes off the bobbin (from left to right) when you rethread. If you usually use the automatic bobbin pickup, don't. Pick up the bobbin thread the regular way, and, holding the top thread and bobbin thread securely in your left hand, start to sew.
I sure hope this helps!
Please let me know if this works, ok?
Robbie
Jan 28, 2010 | Brother CS-8060 Computerized Sewing...
I have been using the zig zag stitch for appliques and all of a sudden the bottom thread which is a different color is showing on the top. I have rethreaded top and bottom threads, changed needles, cleaned...
it sounds like no bobbin thread tension. there should be some resistance when you pull on the bobbin thread. if there is none or too little you may have some lint or thread caught behind the bobbin case tension spring.
very carefully try and push the tip of a thin pin into the bobbin case tension spring and pick any accumulated thread or lint out.
if the bobbin case spring is clean, try tightening the bobbin tension a little at a time until your zig zag looks ok.
of-course all this is done after checking needle threading and needle for damage.
scott.
Jul 29, 2009 | Janome Sewing Machines
Janome Memory Craft 9500 Troubleshooting
Have you tried a new needle?
If re-threading, changing the brand of thread, etc. does not work, then it's likely your machine is out of time. Search for sewing machine timing or take it for service.
May 24, 2017 | Janome Memory Craft 9500 Computerized...
Machine won't sew
Change the needle and be sure the flat side is to the back. Rethread the machine. Remove and reinsert the bobbin. Hold the top thread and turn the handwheel to see it the top thread will pick up the bobbin. If yes, it should sew ; if not, it is probably out of time and needs to be seen by a technician.
sewman7
Jul 15, 2008 | Euro-Pro Shark 60 - 384
Singer sewing machine model 6012 c
hi
thank you
Dec 15, 2007 | Sewing Machines
Sewing Machines Logo
136 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
