Question about Brother SX-4000 Typewriter
Hammer doesn't strike
I was typing along one day when the machine just stopped printing anything on the paper. the print head moved normally, and I could hear the wheel clicking as it moved, but nothing was on the paper. I assumed at first that I had simply come to the end of the ribbon, so I replaced it. Of course that didn't work or I wouldn't be posting this. I realized then that the hammer isn't moving at all. I tried every mode. I tried resetting the machine. I tried turning it off. I even tried unplugging the machine. Nothing helps.
Try taking the wheel out and aliging it with the piece in the middle with a hole in it so that the pin and the wheel connect when you push the lever forward to connect the wheel to the disk.
Posted on Sep 14, 2007
  • Sarah
    Sarah Apr 14, 2014
    none of this worked
2 Suggested Answers
  • 329 Answers
SOURCE: IBM wheelwriter
Is the hammer moving at all? There is a rubber part on the I think left side of the ribbon hammer, down on the side of the printer. This will adjust the amount of impact. I really doubt if
this is the problem, but worth a try to look at. This part and I think it is a blue slide will move up and down to adjust the impact. Possible lubrication and there is a large spring that actually pulls that hammer forward, check to see if this spring is OK. Other than that electronic problems such as main board, printer motors, etc. Does hammer move freely by hand? Also mechanical binding in the printer... GOOD LUCK.
Posted on Jul 23, 2008
Bought new Brother ML300 will not type anything on the paper, please help!
I would check all the basic stuff first. Is the print wheel locked into position? Is the platen all the way forward? (lever right side) Is the ribbon installed correctly and not cocked up on one side? Do you hear the hammer striking the paper? If you hear the hammer striking the paper, it is a ribbon problem. If you don't hear it, it is a hammer / print wheel problem.
Jun 24, 2014 | Brother ML-300 Typewriter
Solution for unable to Init.43 repair
To clear the message, you need to disconnect the Brother machine from the power outlet to check the machine. Follow the steps listed below: Check for foreign objects, such as a paper clip or scrap of paper, inside the machine. Disconnect the machine from the power outlet and open the scanner cover by pulling up on the lower right corner of the cover. Look inside the machine and remove any foreign objects. If you see jammed paper or another item inside this area, gently pull it out and then close the scanner cover securely. If the error continues to appear, move the print head and examine under the print head. NOTE : The images shown below are from the representative product and may differ from your Brother machine. 2-1.Disconnect the Brother machine from the poweroutlet. 2-2.Open the scanner cover by pulling up on the lower right corner of the cover. 2-3.Check the print head's position. In the example photo the print head is positioned at the left hand side of the platen area. 2-4.Gently move the print head to the center. Caution Be careful not to force the print head to move. If the print head is positioned at the far right hand side, you cannot move it. Please contact Brother Customer Service from "Contact Us". 2-5.Examine under the print head. If anything is found, remove it. Hint Use a flashlight if necessary to check thoroughly. 2-6.Close the cover and reconnect the machine to the power outlet. If the message continues to appear on the LCD, the machine will require repair as the print head has failed and will need to be replaced.
May 29, 2014 | Brother Sealed Mfc-j430w Wireless Printer...
Hammer wont strike, just bought new.
Check to see if you are in the display mode (it displays what you are typing, the carriage moves along, but only prints when you hit the return key)
Sep 09, 2013 | Brother Ml100 Standard Electronic...
Sears SR2000 typewriter solenoid
If this is a Nakajima print head the print solenoid is on thr R. side of the head and the armatures crack and stop printing.
DickyO
Dec 31, 2012 | Office Equipment & Supplies
Horizontal print gaps on ml184+
The most common cause of missing sections in the letters is a bad print head. These types of printers (Dot Matrix) create the print with the print head which has a line of small pins called hammers that are activated by an electromagnet. Each pin has its own hammer. If the electromagnet fails or you have something jamming the hammer then it will not move to strike the ribbon and make the image or letter. You can get a replacement print head online for about $15.00, the part number is 50063802. Here is a picture of what the print head looks like. :
Dec 30, 2011 | OKI MICROLINE 184 Turbo Matrix Printer
Unable to print 70
  1. Open the Outer Back(Rear) Cover (1) at the back of the machine. Pull the jammed paper out of the machine.
  2. Close the Inner Back(Rear) Cover (1) if it is open as shown in the illustration.
  3. Close the Outer Back(Rear) Cover. Make sure the cover is closed properly.
  4. Pull the paper trays (1) out of the machine.
  5. Push the two green levers up on both sides.
  6. Pull out the jammed paper (1) and press Stop/Exit.
  7. Push the green duplex unit up.
  8. Reset the machine by lifting the scanner cover from the front of the machine and then closing it.
    If you cannot remove the jammed paper from the front of the machine, or the error message still appears on the LCD after you have removed the jammed paper, please go to the next step.
  9. Using both hands, use the plastic tabs on both sides of the machine to lift the Scanner Cover (1) into the open position. Make sure that there is no jammed paper left in the corners of the machine under the plastic covers.
    Note
    • If ink gets on your skin or clothing immediately wash it off with soap or detergent.
    • If the paper is jammed under the print head, unplug the machine from the power source, and then move the print head to take out the paper.
    • If the print head has stopped in the right corner as shown in the illustration, you cannot move the print head. Press Stop/Exit until the print head moves to the middle. Then unplug the machine from the power source, and take out the paper.
    1. Gently close the scanner cover using the finger holds on both sides of it as you push down on the Scanner Cover Support (1).
    Caution Be careful not to trap your fingers under the scanner cover. Always use the finger holds provided on both sides of the scanner cover when opening and closing it.
    1. Push paper tray #1 and paper tray #2 firmly back into the machine.
    Note Make sure you pull out the paper support until it clicks.
Nov 11, 2011 | Brother MFC-6890CDW Printer
Epson TM-U295 Matrix Printer light printing problems The paper i use is 3 sheets, 1 original and 2 copies, the copies no longer print clear, i have tried changing the ribbon but this only improves the...
You need to adjust the print head spacing. This is a lever along the side inside the printer by the print head. It just move the head closer or further away from the paper. The closer it is the harder it strikes the bottom pages and it should print darker on them. If you get it too close it can catch the paper and cause a jam so you have to give it a bit more space. You may end up redoing this if you use a different brand or type of nc form paper. Just open the cover look for a lever on the side and lick it a notch (should show circles so go to the smaller one) and try printing. You might have to waster a few pages before it behaves but this is all you need to do.
Sep 02, 2011 | Epson TM-U295 Matrix Printer
Clean enable 46 error i seen in my brother 295C, can u help? How i solve it?
  1. Check for foreign objects, such as a paper clip or scrap of paper, inside the machine.
  2. If the error continues to appear, move the print head and examine under the print head.
jam7.gif Hint Use a flashlight if necessary to check thoroughly.
If the message continues to appear on the LCD, the machine will require repair.
Note Please contact Brother Customer Service from "Contact Us".
Mar 07, 2011 | Brother MFC295CNAll-In-One InkJet Printer
When power is turned on the machine acts like it is supposed to. The carrier repositions itself and the motor is heard running. However, when I type, the carriage (with the disk) moves to the right with...
its a printer right?
and it dot matrix type right?
if yes. try this
check flexible cable from main PCB to print head. if its torn. maybe the initial sensor is ok but not the data line.
replace flexible cable.
Mar 04, 2011 | Computers & Internet
Brother GX 36750 - I replaced the ribbon, re-installed the daisy wheel, reset the pitch, pushed CODE RESET, but the letters I type are not matching what is printed on the paper. I press 't' and it types...
When you turn on the machine (or press [Code]+[Reset}) the print head moves to the right side, the print wheel spins, and the ribbon jumps up and down, that is the machine resetting its self.
If a reset does not work the reset tab may be out of alignment. I would
  1. Power it off and then turn it back on and test to again.
  2. If it's still typing the wrong or unreadable letters then turn off the power, open the lid. On the bottom of the case there is a metal frame on the right side of the frame you will see a small metal tab pointing towards the middle of the machine. When the machine resets its self, it uses that tab as a reference.
  3. That tab is easily bent which causes the reset to be wrong. Most people can bend it by hand, DON'T use a pliers! The tab can break off completely. It does not take much pressure and it does not need to be moved very far at all. Just nudge it towards the back (or the front) power up and test it. It might take a couple of tries to either direction to get it right. Be ready to turn off the power if when the print head resets. If you bent the tab too far the tab will not enter the print head correctly.
This reset tab most often gets out of alignment by a child playing with the machine, but if a foreign object is in the machine when the print head is moving.
Dec 04, 2010 | Brother GX-6750 Typewriter
Brother SX-4000 Typewriter Logo
430 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
