Question about Ariston Technologies Ariston XF905 Electric Single Oven
Trying to find dimensions for old model fridge/freezer Ariston OK-AF 3100. 70/30 split? 60/40 split? Many thanks.
Ariston tc720 dials have rubbed off
We had the same problem when our cleaner rubbed off the markings. Ariston "customer services" were very unhelpful (the model is now so old they don't offer any replacement facias for it) but managed to get replacement stickers from Mark at
http://www.ovenlettering.co.uk/. They come with a diagram for all four dials showing where they should go and are very easy to apply. Would highly recommend.
Jan 19, 2014 | Ariston Technologies Ariston FO98P...
I have moved into a new apartment which has a old oven installed. Model: Ariston C 34S G1(X) EX. I find the markings on the panel cleaned off.... can you help me with a manual or atleast the pictures of...
please download your exact ariston c 34s G1 x ex model user manual as under:
http://www.downloadbooklets.com/booklets/searchBooklet.do;jsessionid=D853DE5228C47CD663A9DB6F6CA04067
Aug 04, 2010 | Ovens
Got a fan assisted gas oven. Trying to bake a cake
Temperature control with gas ovens is not an exact science. However the control should be better than you say.
Have you tried reducing the set temperature to compensate for the 'overshoot'. It may be worth a try.
Jan 04, 2010 | Ariston Technologies Ovens
Our power went out tonight for 20min and after it came back on, the light and temp displays in our Frigidaire fridge/freezer does not come on. The freezer light appears to be working and it sounds like the...
Your display panel went out and needs to be replaced. This is a fairly easy part to replace. Just call us and we'll ship your part out asap!! We look forward to working with you!
Oct 18, 2009 | Frigidaire FEB27S5A Electric Single Oven
Whilst working, my Ariston oven ventilator tangential fan motor at times produces an intermittent metallic noise, as if metal is touching with metal. What could this be, and how can this annoying noise be...
Whilst Working? An explanation of what you were doing would be extremely helpful.
#1) If it sounds like metal on metal, chances are its METAL ON METAL.
#2) Its pretty obvious you didn't make graduate highschool, let me explain this as simple as possible so you don't hurt yourself trying to read it.
#3) Your fan (thing that blows) probably caught a wire (metal string), or was altered slightly and is now hitting a metal ventilator (sponge) which is installed near the fan on this particular model.
Oct 11, 2009 | Ariston Technologies Ovens
Ariston oven error code F8E0
solved by rotate the temperature knob!!!
maybe would be a problem of the potentiometer or knobe of temperature
Jun 28, 2009 | Ariston Technologies Ovens
I have an Ariston oven (model;208587057) but no manual
Hi
Press and hold the two buttons with the casserole dish on (one is crossed out) and use + or - to change the time.
Hope that helps.
Jun 09, 2009 | Ariston Technologies Ovens
Ariston Technologies Ariston XF905 Electric Single Oven Logo
51 people viewed this question
Top Ariston Technologies Ovens Experts
ashburton
Dan Webster
Dan Webster
Are you an Ariston Technologies Oven Expert? Answer questions, earn points and help others
