Question about LeapFrog Scout My Puppy Pal
Stuck repeating itself
It just keeps replaying the intro music and repeating endlessly i have tried to recharge it and it seemed to get worse it has slowly deteriorated I bought it about a year ago and for the first 6 months it was still boxed unused the last flat was vaguely damp but not to the point it should present a techincal issue
How do i get my mp3 out of intro mode ???
During music play back tap the Quick Option menu. Then choose Repeat Mode and change it from Intro mode to All or Repeat All.
If you haven't user guide you can download it:
http://www.cobyusa.com/files/manuals/MP826_MN.pdf
Thanks.
gylacz
Aug 12, 2011 | Coby MP826 MP3 Player
When Im done recording and replay it, there are parts that have glitches and repeat itself. What do I do? I checked everything and everything seems to be ok. Im not sure how I can fix it.
Do you mean you're hearing reverb (echo) of recording? If your recording music or vocals make sure playback speakers are off when doing so. If you leave them on, you're recording multiple times IE: ECHO
Mar 07, 2011 | Blue Microphones Snowball Professional...
Wont play the whole song
Sounds like the player is running in INTRO mode, only playing the first part of each song. To change playback mode, follow the steps as described below.
Switch the player ON and start music playback:
1. Press PLAY button to START music to play
2. Press PLAY button again to PAUSE the playback
3. Press MODE button to enter playback mode selection
4. Scroll with MODE button through selections
5. Press MODE button when selection REPEAT is in the display
6. Use MODE button to select from: Normal, Repeat One, Repeat
within current Folder (if any), Repeat Folders (if any), Repeat
All songs, Random Play back, and Intro
7. Press MODE button to confirm selection
May 02, 2010 | Element Electronics GC823 MP3 Player
Mp3
Oh on the first ten second thing. Do you accidently have it set on INTRO? Cux i accidently did that also. So check that.
Dec 26, 2008 | Element Electronics Zr-Element Digital...
Element mp3 will not play longer than 20 seconds of each song
Best Solution!!! I called tech support (866-823-1671 - very nice/helpful) because my daughter's was doing the same thing. I was told to let the song start to play, press the M button during the song, choose 'Repeat' which will bring up a list of options and then choose 'Normal'. It worked.
Dec 23, 2008 | Element Electronics Zr-Element Digital...
Set the Delstar to Randomly play songs
Call Customer Support @ 1-800-998-7771 to get another copy of the manual or ask for their website or google it. Delstar is a company in India. But they have offices here and warehouses and service centers too.Mylittle manual says... Playing Mode (playing the sub-menu) The first item in the playing sub-menu is Playing Mode. When choice is confirmed, the player will play according to the setting rule. SYSTEMS SETTINGS is last on menu as SYS; then...
Replay Mode is the A-B with dual arrows back and forth above the letters on your players menu bar.
Repeat choose one setting when you wish a different playback mode.
[N] = NORMAL Once list song plays, done with. Will continue to play eachsong in the file till through all, then stops. This is the default setting.
[1] = REPEAT ONE Repeat playing one single song.
[D] = with arrow going backwards above it is... FOLDER Plays all the music in the playing folder.
[D] = with dual arrows back and forth above is... REPEAT FOLDER Plays the same file of music repeatedly.
[A] = with dual arrows above is ... REPEAT ALL Repeats playback of all music in the directory.
SHUFFLE
[R] =RANDOM Plays the music in the present folder randomly.
INTRO
[I] = Plays the first 10 seconds of all the music in the present folder in sequence.
Apr 29, 2008 | Delstar DS-3512 MP3 Player
Keeps looking for downloadable software
it could be... a problem with the ds itself, if so get it repaired
Apr 06, 2008 | Nintendo DS Lite Console
Songs wont change
It is stuck on "Repeat One" - refer to p.23 of your user's manual -
You can set your player to play music tracks randomly (Shuffle All ) or repeatedly (Repeat One or
Repeat All ).
1. From the main menu, select Settings > Play mode.
2. Use the VERTICAL TOUCH STRIP to scroll up or down the options.
3. Press § to select an option.
4. Press § again to deselect an option.
While you are playing music you can see the following active play mode screen.
-Tha Mp3 Doctor
Oct 30, 2007 | Philips HDD1630 MP3 Player
LeapFrog Scout My Puppy Pal Logo
Top LeapFrog Toys Experts
Nikki  Mclean
Nikki Mclean
relojmesa
GI Consulting
Are you a LeapFrog Toy Expert? Answer questions, earn points and help others
