Question about Microsoft Windows XP Professional
Load application autocad 2010
Why i am getting a loadapp error if i donot works for sometime? and commands in shortcuts are not working? i need to give full command e.g.- i want to draw line, if i gives l command it is not working, but if i gives "LINE" Word it is working...can somebody solve this problem?
  • 157 Answers
I think some files of this software are corrupt in program files. You need to upgrade the software with previous settings.
Posted on Jul 31, 2013
  • 6 Answers
SOURCE: unable to load dos prompt
This is probably caused by a virus. Try scanning it with your antivirus program, after you make sure your virus definitions are up-to-date. You can also run Trend Micro's Housecall if you have an internet connection. It is free. Just do a search for it, run it, and see if it finds anything.
Hijackthis is another good resource to try. Find a copy on the internet (it is free) then post your log that it makes on a website for others to help you find the bad files that are causing the problem. ASP free forums has this type of help.
FYI- another way to start the command prompt is to go to Start > Run > type cmd >hit enter. You can try to see if it starts this way, but I bet it is a virus or other malware.
Posted on May 05, 2008
SOURCE: System Error. Code : 87. Parameter is Incorrect.". Please give me solution for this
When I want to connect a software ,which connect to Database through ODBC display the messageV"System Error. Code : 87. Parameter is Incorrect.". Please advice solution
Posted on Aug 17, 2008
rylee_smith
  • 8619 Answers
SOURCE: I get a window saying Command line option syntax error.
Hi! I think you are using internet explorer 6.0 then upgrade it to internet explorer 7.0 or later. Delete temporary internet files, History and Cookies from internet properties in control panel. If this is not the case try uninstalling and re-installing internet explorer.
And if still unsuccessful then using Mozilla Firefox web browser will certainly solve your concern.
You can download Mozilla Firefox from the following link -
http://www.mozilla.com/en-US/firefox/3.1b1/releasenotes/
Posted on Dec 27, 2008
worldvet
  • 859 Answers
SOURCE: chkdsk is not working in
As a user on the system do you have limited or administrator privilegeds?
Let me run down the procedure and you can tell me first if you are doing it this way or not. OK?
To run Check Disk
Press at the same time the Windows Logo key + R, this launches the Run Command Dialog box at the bottom left of the screen.
In the text area of the run command dialog type: cmd
This opens a Command Window
With the Command Window open type this exactly:
chkdsk /f /x c:
The command is "chkdsk" without the quotes
Then there are operators known as switches. These are invoked using the forward slash (or slash) more commonly known as a "switch" in programming language.
There are several operators that can be invoked. To see them all type:
chkdsk /?
That will list all the possible operators you can invoke in the chkdsk command. This is useful should you need to refresh your memory of what to do.
The operators invoked with the slash switch may often be substituted with the dash symbol (-) without the parenthesis.
In our case we want Check Disk to check drive C and access the drive exclusively. As the C drive has the operating system running it has open handles. Open handles are executable files running to allow the function of Windows. By invoking the /x switch this forces Windows to execute your command in the only exclusive mode possible which is during bootup.
The switch /f tells Check Disk to fix any errors. Should you suspect you have damaged areas of your hard disk you would use the /r switch which instructs Windows to attempt to repair any damaged sectors and if unable to mark them as unusable and move that data to another area of the hard drive. The /r switch implies the /f switch.
Normally you will not want or need to use the /r switch unless you are told by Windows that there are damaged areas of your hard drive.
So, in our case the /f (to fix sectors and files) and the /x (to do this in exclusive mode) and then lastly typing the drive letter to check in our case c: instructs Windows to act immediately.
In order to run this command you do need permissions called security descriptors for your user account. Simply put, your account would be an Administrator account and not a limited account. Most accounts in Windows are administrative. To change a limited account to an administrator account you need a logged on Administrator who can access your limited account and change your privilege to Administrator. If you have none, you need to bootup in Safe Mode log in as Administrator (usually no password, or it is "Admin" without the quotes and either upper and lower case or all lower case.
In conclusion, should you press Windows Key + R, the run command line dialog appears; next you tye CMD to gain a command window; you then type in "chkdsk /f /x c:" without the quotes. Windows should attempt to obtain exclusive mode which it can't and will then ask you if you want to run this on the next boot. That is the normal response. You would then answer Y for yes and Windows will reboot or you will have to tell it to reboot using the Restart Sequence.
Should non of this happen and you do have an administrator account, then you probably have a virus infection hiding in a sector on your hard drive where Check Disk will remove it. There is a way around this if this is the impediment you are facing. More on this at the end if you are locked out.
Reboot your computer and on restart Press F8 like a piano key, you may be asked from where do you want to boot? Choose your Hard Drive and then immediately, immediately press F8 again like a piano key. This will bring up the Safe Mode boot options. Here is where you would usually choose Safe Mode. However, in this case, choose Safe Mode with Command Prompt. Once it boots up and you have half the screen occupied by a command window, type out the command once again to run Check Disk with the switches
chkdsk /f /x c:
needed to fix your hard drive and repair your security descriptors. From this Safe Mode Command Prompt you will have privledges and the command should execute with no problem. If it doesn't you have a serious problem on your hand and will require running a thorough Virus Scan specifically from an online Virus Scanner.
To run an online Virus Scanner follow the instructions in this Tip I wrote here:
After you attempt this and if you still have a question or should you run into trouble use the comment text box below or the Ask Me button to respond to me directly. I will then receive an email alert and will respond at my soonest. Note that I am away from my desk a great deal of the working day and am at it in the evenings though.
Regards, and good hunting,
Worldvet
Posted on Jan 14, 2009
  • 10406 Answers
SOURCE: how to give command to check virus
Start Internet Explorer.
Access: http://cainternetsecurity.net/entscanner/
Click "Start Scan".
Posted on Sep 10, 2009
Autocad changes lost
The most effective solution is .dwg recovery tool when other methods don't work
The place where you may read various thing about Autocad
Here you may read more about article below
However, a few things may get it to open:
  • Try to open the drawing file directly instead of using the Recent Documents menu.
  • Check that the storage location that holds the drawing is working properly.
  • Use the RECOVER and RECOVERALL commands on the drawing.
  • Attempt to insert the damaged file into a clean drawing or template using the INSERT command.
AutoCAD Recovery tool How to repair corrupt AutoCAD drawings and fix its errors Error Drawing file is not valid when opening file in AutoCAD
Aug 28, 2017 | Computers & Internet
My autocad dwg files have been corrupted
Displays a list of all drawing files that were open at the time of a program or system failure. You can preview and open each drawing or backup file to choose which one should be saved as the primary DWG file. After a program or system failure, the Drawing Recovery Manager opens the next time you start the application. Drawing Recovery Manager displays a list of all drawing files that were open. The System Variable RECOVERYMODE controls whether drawing recovery information is recorded after a system failure and whether to show the Drawing Recovery Manager or not.
If you want to help yourself, Autodesk and other AutoCAD users make sure to send in any errors to Autodesk when you see the Customer Error Report dialog box (CER).
Finally a solution that sometimes helps if AutoCAD cannot fix the problem is to try to fix the drawing in another program that can open and save DWG files. The more users having the similar problem the better chance it will be fixed in a service pack or future version. Eventually you might
get DWG Restore Toolbox saying the problem is fixed.
from website: http://www.dwg.restoretools.com/
Jun 20, 2015 | Autodesk AutoCAD 2010
Autocad error 0x69bbc67c
install the latest sp from the autodesk website. Failing that, turn of graphics hardware so it uses software in Options
Mar 25, 2013 | Autodesk AutoCAD 2010
AutoCAD 2010 won't start after reinstall.
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/AutoCAD-2010-does-not-start.html
Issue:
When you try to start AutoCAD, you briefly see the splash screen and the program does not start.
Solution:
This behaviour can be caused by corrupted license information.
Please check if there are any errors listed in the ACD2010ENGAdlm.log file in the folder:
C:\Documents and Settings\All Users\Application Data\Autodesk\Adlm (Windows XP)
or
C:\ProgramData\Autodesk\ADLM (Windows Vista) (Please note the file name may be slightly different for localized product versions, for example for the German version the file name is ACD2010-DEUAdlm.log)
If the log file shows errors regarding the product information table file, for example "Unable to locate the Product Information Table File" or "Product Information Table file is not found", you will need to:
  1. Uninstall all installed 2010 products
  2. Delete the ADLM folder mentioned above, and
  3. Reinstall the products
Oct 14, 2010 | Autodesk AutoCAD 2010
Fatal error unhandled c00000fdh exception at 30119435h in autocad 2011
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Fatal-Error-Unhandled-Access-Violation-Reading-0x0000-Exception-at-bcbdad73h.html
Fatal Error while opening AutoCAD Dec 05 2014
Applies to AutoCAD 2009, AutoCAD 2010, AutoCAD 2011, AutoCAD 2012, AutoCAD 2013, AutoCAD 2014, AutoCAD 2015, AutoCAD Architecture 2009, AutoCAD Architecture 2010, AutoCAD Architecture 2011, AutoCAD Architecture 2012, AutoCAD Architecture 2013, AutoCAD Architecture 2014, AutoCAD Architecture 2015, AutoCAD Civil 3D 2009, ...
See More
Issue:
While in the process of starting AutoCAD , a Fatal Error occurs.
Causes:
Fatal errors usually indicate program corruption or a corruption somewhere within the operating system.
Solution:
There are several ways to address the problem: Note: A fatal error can be caused by DisplayLink Core software. If you have this installed on your system, try uninstalling it and then see if this resolves the issue. Additionally, some antivirus or desktop locking programs can cause errors in AutoCAD as they lock the system environment from working. Your antivirus may even need to be uninstalled.
Sep 16, 2010 | Autodesk AutoCAD 2010
When inserting a raster images, receive the "FATAL ERROR Unhandled Access Reading 0x0000 Exception at 10b0961eh" message.
See More
Issue:
Causes:
Solution:
If all of the above solutions fail to resolve the issue, and a full uninstall and reinstall of AutoCAD does not help (see Remove All Products from a Windows System), then you may need to reformat your hard drive and reinstall the operating system.
Article ID: kA230000000tTXu
Sep 15, 2010 | Autodesk AutoCAD 2010
How to install autocad 2004 in windows 7
I had no issues installing AutoCAD onto a Windows 7 x86 Professional system. User is making and saving new drawings as well as opening existing drawings.
AutoCAD 2004 works fine on Windows 7 Professional 32-bit.
Aug 04, 2010 | Autodesk AutoCAD 2004 for PC
Autocad 2010 problem
If you run Win7 in XP mode, all should be fine.
May 06, 2017 | Autodesk AUTOCAD LT 2008 SLM 10 SEATS...
Microsoft Windows XP Professional Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
