Question about Sewing Machines
Innopower outdoor patio heater model no. H1107&1207
  • Sewing Machines Master
  • 7,365 Answers
Your question was put in the sewing machines catagory
so it needs to be put in a different catagory so you can get someone to help you
Posted on Jul 31, 2013
Looking for Sherpa lined clogs that can be worn outdoors in winter
Search the internet for what you seek. Check with footwear vendors--possibly western wear stores. You won't find information here in the sewing machine category.
Nov 13, 2016 | Sewing Machines
Sewing outdoor polyester ( denier) medium weight with outdoor polyester thread. bottom stitch is not straight? evenly spaced but irregular in alignment. Help?
increase the needle thread tension
the bottom stitch is a direct result of the needle movement pulling the bobbin thread up to the hole so for the bottom stitch to be irregular , so is the top stitch
Nov 22, 2015 | Sewing Machines
How to get heater on manuleas we cannot get it on at all?
I didn't know that sewing machines had heaters. Can you please post your question in the correct section with more information.
Feb 21, 2015 | Sewing Machines
Sewing on upholstery, thread bunching up on bobbin side
You need to lower the teeth that feed the fabric. There should be a knob on your machine to do that. this plastic coated fabric is not sliding along properly.
Oct 07, 2014 | Sewing Machines
Stitch tension problem - bobbin thread lies flat or bunches. If you increase the needle thread tension there is no improvement - even at the highest needle thread tension the bobbin thread is a mess. Any...
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 16, 2011 | Consew 7360R-1 Mechanical Sewing Machine
Trying to sew light indoor outdoor material (zig/zag stitch) keeps getting tangled in the feed dogs and needle keeps sticking in the material from the top. It is mangling my fabric.
What size needle are you using? You should be using at least a #14 or #16. A #11 is too light duty. Try that and see if it doesn't make a difference.
Apr 14, 2011 | Brother CE5000 Computerized Sewing Machine
Trying to find an owners instruction manual for Husqvarna E. series 450 , 16 in gas chain saw.
Umm. Husqvarna makes both sewing machines and chain saws (good ones). But this needs to be posted in a category other than sewing machines. I would suggest "Home & Garden/Patio & Garden" as the most likely one I could find for you. Good luck.
Jan 26, 2011 | Husqvarna Sewing Machines
I am sewing on "WeatherMax" fabric (making golf flags) - an outdoor, lightweight, material; in the wind my fabric is fraying and splitting. Was it the needle? Is it the fabric? is it the machine? Did I cut...
Hi. Interesting problem. For outdoor materials (and advise on sewing on outdoor materials) I rely on Sailrite (http://www.sailrite.com/) and interestingly, couldn't find Weathermax fabric on their site. I would contact their forum (http://forum.sailrite.com/) and ask the question there. Matt Grant (I think he runs the sewing part of the forum) is extremely knowledgeable and helpful.
Sorry I don't have anything more for you,
Robbie
Mar 30, 2010 | Necchi 4575 Mechanical Sewing Machine
I have a Dimplex in wall heater model 690221900 120 volt 1500 watt. Their is a 110 volt feed line (black, white and ground wire)coming in to the heater housing as well their is a two wire thermostat...
Well, for your wiring, there's nothing wrong with it, So, I think there's two way to find out which ones is wrong, first:
Install your heater without thermostat first, is it working, does the breaker blowing!!!.
If No, then your thermostat is the cause, but if Yes, then,
second:
Try install it with the new breaker with 10 A minimum, you must replace the breaker with new ones.When it's OK, then try install the thermostat too.
Hope it works!!!
Dec 09, 2009 | Sewing Machines
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
