Question about Air Tools & Compressors
Service manual for rapid btx530 nailer - Air Tools & Compressors
My makita an451 roof nailer keeps shooting 2 nails I've tried 2 different brands of nails
Nailers that use strips of nails (one nail directly behind the other) will sometimes drive two nails at once and is caused by damage to the driver. The nails are so close together that the driver will hit the first and part of the second nail head. Coil nailers, as your an451, use nails seperated by welded wire making it very difficult the the driver to hit the second nail. Usually when a coil nailer shoots two nails, it is acutally the trigger valve that acutates twice (two very rapid fires). Two very rapid fires is caused by faulty trigger valve. I have seen a roofing coil nailer fire one nail and a second nail drops out of the gun. Caused by weak / malfunction of nail feeder or wire used to weld nails together is too thick.
Sep 17, 2011 | Makita Roofing Coil Nailer AN451
Nailer will get two nails jammfrontiered at same time about every 3rd nail
Nail jamming is caused when the driver is able to hit two nails with one stroke. This usually happens on nailers that use nail strips with no spacing between nails. If the driver is damaged, it may be able to hit part of the second nail. If the wrong nail is used and two nail heads are in the path of the driver then jam. On nailers using nailstrip with space between nails, it is much harder for driver to hit two nails. Most jamming, however is caused by the nailer actually firing twice in very rapid succession. this type of jam is caused by faulty firing mech. (safety foot or bump fire system) , faulty/worn trigger valve or worn orings in the headvalve .
Sep 16, 2011 | Stanley Bostitch Coil Framing Nailer
Will not advance nailshandymanrentals
Open side door of nailer and dry fire the gun against rubber very rapidly, look at the feeder, it should move back and forward very rapidly. If it appears to move slowly check orings to feed piston and white oring between the body of gun and nose (remove the two screws into nose of gun). Sometimes pieces of the lower bumper will become lodged in air path to feed piston. Good luck
Nov 03, 2010 | Stanley Bostitch Rn461 Gun Coil Roofing...
I have serviced my IMCT several times per the owners manual. It needs to be serviced again however the manual has disappeared, and the one available on line does not contain the servicing instructions. ...
Here is a tip that I wrote about the Paslode nailers and the problems that can come up with them.
I also have a link to the Paslode manuals which contain Paslode cleaning and troubleshooting guides.
If you need parts for your Paslode, there also is a link for a site that sells the Paslode nailer parts.
Paslode Cordless Nailer Problems
heatman101
Oct 21, 2010 | RTO PasLode 900420 Impulse Framing Nailer
How do you set up the bostitch coil framing nailer for contact nailing?
Bostitch nailers have two triggers available. Black trigger is rapid fire while the gray is single shot. Both triggers are usefull depending on type of work. Most people say that there is a degree of accuracy with single shot allowing for better placement of nail. If speed is your goal then use the black trigger to bump fire. More information and parts can be found at www.bostitch.com , look for "Support" tab, then "service / parts " find your model number from the pull-down list and search for the manual and parts list for needs. Good luck on your projects.
Jun 30, 2010 | Stanley Air Tools & Compressors
Owner manual
Most all manuals are available at www.bostitch.com, look for support tab, then select service parts and documents. Find your model number in the pull down list and finally select usage manual.pdf, enjoy.
Jun 18, 2010 | Stanley Bostitch Coil Framing Nailer
What causes air leak around trigger and loss of compression on bostitch on n79ww modelframing nailer
Are you using air tool oil fairly frequently? Any rubber "O" rings will wear rapidly if not lubricated properly.
Jan 01, 2010 | Stanley Bostitch N88rh Framing Nailer...
THE CRAFTSMAN AIR NAILER I HAVE WILL NOT WORK AFTER I USED IT FOR ABOUT A HOUR
If you are using the nailer rapidly and the outside air temp is 50 degrees or less use antifreeze instead of oil. The head valve could be freezing
Apr 06, 2009 | Air Tools & Compressors
Dewalt framing nailer
Dewalt makes a great line of nailers and has a good network of factory repair centers with helpful repair department. Their web address is www.dewalt.com . Click on service/support button then look for Instruction Manual button to download your manual. When search window appears enter your model number. You can also view a parts list and order parts. I have a very old dewalt nailer that was not listed on their website but my local service center made me a copy of theirs at no charge. Good luck.
Jan 20, 2009 | Dewalt D51850 Heavy Duty 20 Degree Full...
I need a repair manual for a duo fast striper nail gun.model#325b
Your nailer, although very good, is rapidly becoming obsolete as many parts are no longer available. When these guns were first made available, a sales rep. demonstrated repair techniques and did not provide repair manual. Owners manual for many models are available at duofast.com www.toolpartsdirect.com has parts lists and many parts available. If you are having a specific problem please post it; maybe I can help. Good Luck
Jan 11, 2009 | Hitachi 3 - 1/4" Framing Strip Nailer
Air Tools & Compressors Logo
50 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
