C itoh s4
Loses top of form after 1st label is printed but always feeds the same form length
SOURCE: 2 LABELS COME OUT
your label length is set incorrectly, there are 2 things it could be
1) your software is telling the printer the label length is longer then the current labels, even if the label size is out my a single millimeter the printer will give you this issue of feed an extra label. you need to change this in your software. you can set a label size smaller then the current label size and it will work correctly
2) you software is not setting a label length and so the printer is going off its internal setting, to recalibrate hold feed and power up the printer letting go after the light starts flashing
it is important to note that label roll will change slightly over time so even though you are ordering the same labels as a year ago the manufacturer will have slight changes from batch to batch
Posted on Nov 09, 2007
bartech9
  • 155 Answers
SOURCE: datamaxI class 4208 top of form fault
The printer must be calibrated or the type of sensor is wrong. Verify that the sensor type is correct for your label (gap or black mark) and you can calibrate it by pressing the FEED key for about 5 seconds approximately.
Posted on Mar 13, 2009
joeshea123
  • 65 Answers
SOURCE: Feed and Tear Off position problem
You can give this a try. This will alter the top of form setting.
http://www.profitmonster.com/printers/ml320tb.html
Let me know if this helps.
Posted on Mar 28, 2009
SOURCE: blinking amber light will feed labels but doesn't print on them
I have had the same problem and just got my printer working. I moved the peel lever to the lower postion and the printer now works without any problem. The user guide says to postion the lever to the up position (inactive) but that caused the amber blinking lights (not recognizing the label properly)when loading labels. Hope this helps
Posted on Aug 11, 2009
  • 67 Answers
SOURCE: will not feed full length of label. display reads
You may need to take out the whole ribbon assembly by removing 3 screws. The ribbon sensor looks like a L shaped clear plastic glass.
If still not working. buy the ribbon assembly.
Posted on Nov 07, 2009
I have got a datamax m class mark II and i have got a fault top of form and i can not print anything or i can not connect to printer from my computer. i have all drivers on and i think all is fine but i...
1)PLACE THE SENSOR IN TO THE LABEL GAP PROPERLY 2)CHECK THE SENSOR TYPE IN PRINTER(menu->media settings->sensor type) 3)PERFORM A MEDIA AUTO CALIBRATION(press and hold feed on control panel) 4)SET FACTORY DEFAULT SETTINGS
Apr 15, 2011 | Datamax M-4208 Thermal Label Printer
It begins to print then stops half way
Having the same problem here... very random... send a print job of labels and it will print the whole lot, or freeze at random points but always halfway through a label... no error message... unplug usb and replug doesnt do anything, but unplug and replug power and off it goes printing more lables but may even freeze again after only a few more have come out... also, every day the first print job of the day prints half the label and pauses for about 10 seconds then keeps going...
- Windows XP Pro SP3
- LabelWriter 400 as supplied out of the box
- Genuine DYMO labels
Jan 28, 2011 | Dymo LabelWriter 400 Thermal Printer
One label printing over two label forms
Always check to make sure the printer is advancing one label at a time by itself before printing. If it does then you know the printer has a good read on the label size. Then if it misaligns when printing then you know the problem is in the printer driver because the printer is only going to do what it's told to do.
So best is to turn printer off, power up, press feed to see if one label feeds ok. If the label feed is off at this point then the printer needs to be calibrated which is done by pressing and holding FEED while turning the printer on.
Hope that helps !
Jun 03, 2010 | Zebra TLP 2844-Z Thermal Label Printer
Losing half of top line when printing
Label definition in printer driver may need adjustment. Try calibrating printer, printer on solid green light, hold down feed key & release after light blinks 4 times, (blinks once, twice, three times then 4 times) Download the Zebra setup utility and use it to configure printer.
Sep 29, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Oki 321 turbo in PPR emulation mode, does a form
Generally the form feed character is sent by your software. Try setting the page length in the printer setup to be the length of one label.
Sep 28, 2009 | OKI MICROLINE 321 Turbo Matrix Printer
Prints on two cards
You can modify the position in the menu.
The start position can be prgrammed in the personal settings.
Moving the paperwon't change anything because the printer will always check the top of feed
Sep 03, 2009 | Datamax I-4208 Thermal Label Printer
Printing a label 4x 1 7/16
Try setting the page lenght using the printer panel
To do this, enter MENU mode by pressing SHIFT+MENU
press GROUP button until prints REAR feed or BOTTOM feed ( depend on where you load the forms from )
Press ITEM button until it prints form length
Press SET to change length as required
To exit, repeat SHIFT+MENU
All the best
KM Hoo
Feb 11, 2009 | OKI MICROLINE 590 Matrix Printer
Mar 27, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
2 LABELS COME OUT
Oct 13, 2007 | Zebra LP 2844 Thermal Printer
C.Itoh CI 5000 Matrix printer
Did you check the lines per page setting on the printer? For normal 11" length forms, the setting should be 66lpp.
Jun 07, 2007 | Itochu C.itoh CI 5000 Matrix Printer
274 people viewed this question
k24674
jasbo
jasbo
