59.52 error in hp clj 3600dn printer - Office Equipment & Supplies
    Sergeant:
  • 241 Answers
This code means "An error occurred with the magenta print cartridge drive motor during startup orrotation."
I recommend the following steps.
1. Check that connectors J5003 on the magenta print-cartridge drive motor and J207 on the driver PCA are seated correctly.
2. Replace the magenta print-cartridge drive motor.
3. Replace the driver PCA. 186
Here is a link to the service manual:
http://www.feedroller.com/store/Service%20Manual/CLJ3000_3600_3800_CP3505sm.pdf
Hope this helps.
Posted on Jul 31, 2013
Soulvisitor
  • 1113 Answers
SOURCE: HP clj 2550n error 50.2 fuser
Replace fuser assembly is the fix
Normal consumable, the lamp electrics (lamp, thermistor) will have blown.
9337832.jpg Part info
Posted on Jan 13, 2008
  • 239 Answers
SOURCE: Firmware updates for hp CLJ 47000dn
you can down load and software and firmware for free from HP's website.
hope this helped
please rate well
Posted on Mar 04, 2009
komguy
  • 2306 Answers
SOURCE: I have a HP CLJ 4700dn printer which keeps on giving 49.2FCC
That error is a firmware error, you might try again to download and install the update, or try a new memory stick if you have additional memory installed.
Posted on Jun 22, 2009
Shah_Sheh
  • 81 Answers
SOURCE: 50.9 FUSER ERROR
The fuser is the part that melts the toner onto the page, the error is thrown by a sensor which monitors the fuser, powering off unplugging and waiting for the fuser to cool (about 25 minutes, dont test it by touching it) before turning back on the printer will fully reset the sensor and may get you going again however this wont fix a fault with the fuser. However the fuser is a consumable which means they can be purchased and fitted by the end user (Not cheap parts), I always recommend that you users buy from the manufacture as they will stand over any item they sell you plus advise on instalation and problems however check prices on-line first and make your own call
http://printertechsdotcom.stores.yahoo.net/hpcola26fune.html
Posted on Oct 05, 2009
  • 1218 Answers
SOURCE: 59.c0 error in hp clj 3505 printer
For those users who are having a problem with the printer motor, this C level problem is referred to as 'developing disengaging motor rotation error'. Most likely, this problem points to an issue with the function of the DC controller: either it has failed or it has affected the developing disengaging assembly. The solution is quite simple and the user may fix the error in a matter of few steps.
The first step is to reconnect the J16 connectors that are used for the developing disengaging motor to the J1100 connectors that are used for the DC controller PCB (that is the printer circuit board of the DC controller). After connecting these two connectors to each other, the user must replace the developing disengaging drive assembly directly.
The final step is to replace the DC controller PCB, after which the printer is to be recalibrated. for more information....
http://www.fixya.com/support/t503092-59_c0_error_hp_color_laserjet_5550
Posted on Sep 17, 2010
HP CLJ 5500
If you mean toner, you can probably do it, but most new printers have a memory chip on the cartridge which keeps track of toner. Adding toner will not change the count and the printer will ignore the new toner
Jan 04, 2014 | HP LaserJet 9500mfp Printer
Have a 59.30 error code on a hp clj 5550
My printer displays a 51.23 error, what to do? hp laserjet pro cm 1415fn color mfp
Oct 09, 2013 | HP Color LaserJet 5550hdn Printer
My HP Color Laser Jet 3600dn is currently reading an error message: 50.8 Fuser Error...Any idea what this means?
Go to HP website, locate your model, then put in error massage. They will tell you the problem and solution.
Oct 08, 2010 | HP LaserJet 3600dn Printer
HP Laserjet 3600 error 493007
Critical error. Try printing from a different application. If problem goes away, then you may have a software problem. If problem is still there, remove the memory DIMMs. You may have to replace the formatter.
Nov 24, 2009 | HP Hewlett Packard LaserJet 3600dn Printer
Jun 22, 2009 | HP LaserJet 5550DN Printer
Eror message 49.4401 on hp clj 5550
Dec 15, 2008 | Office Equipment & Supplies
I am in need of a HP CLJ 3600n Service Manual.
Not totally sure this is the right site but worth a try for the manual. Bud
http://www.generalmanual.com/Printers/HP-Color-LaserJet-3600dn-Printer.htm
Dec 04, 2008 | Office Equipment & Supplies
HP LaserJet 3600dn Printer Problem The printer is new but wil not function.
In menus, diagnostic menu, "show event log". What error codes are listed?
Apr 12, 2008 | HP LaserJet 3600dn Printer
3600DN
Reinstall printer driver this normally works
Thanks J
Jan 21, 2008 | HP LaserJet 3600dn Printer
Error 59.0
Im haveing a search on the web but when i used to repair printers error code 59 normally meant a problem with the fuser unit
Nov 04, 2006 | HP LaserJet 3600dn Printer
218 people viewed this question
jasbo
jasbo
