Question about Casio 140CR Cash Register
The till is not printing numbers its only prinitng symbols, as if its gone into another mode.
Where can I locate the dot as in dot com
Try using symbol mode:
Press the left scroll key and select 123 till you get SYMBOL mode
then scroll (press the right scroll key) till you get the . symbol
(Information from the user guide page 34.)
User guide is available to download click here
-Charles
Jul 03, 2016 | Motorola Pre-owned W385 Black Verizon Flip...
When sending an email where is the period
-Charles
Printing paper slow and inaccurate
It may have absorbed to much humidity. Buy new paper, and look for a 24lb paper and the highest number brightness like 99. Paper will absorb moisture acting like a sponge.
Dec 15, 2012 | VeriFone VX510
How to print pics with the date stamp from canon A580
The date stamp feature on this camera will only work in postcard mode- resolution set to 2M (1600 x 1200) and compression set to fine. You have to set the picture mode to that first. You also have to set the date and time if it isn't set already.
To set the mode quickly, set the mode switch to camera, turn the mode dial to A (auto), then press Func. button, scroll down to the "L", scroll across to the mountains with the clock dial, then press the Disp. button to turn date prinitng on and off.
Nov 28, 2010 | Canon PowerShot A580 Digital Camera
Replaced Drum Cartridge - Alarm light still on and still says "replace Drum Cartridge. How do I reset?
Try this procedure, it should help fix the problem,
Turn Printer off. While holding down Enter and Menu keys, power the printer on. You should see PCU Diag Mode displayed. Hit Menu key 6 times till Counter Set is displayed. Hit Enter key Dev xxxxx displayed, left 3 numbers are blinking. Hit (down triangle symbol) till numbers are 000. Hit Menu key, right 2 numbers are blinking. Hit (down triangle symbol) till numbers are 00. Hit Menu key. Drm xxxxx displayed, left 3 numbers are blinking Repeat steps 7-10. Dev tm xxxxx displayed. Repeat steps 7-10. Drm xxxxx displayed. Repeat steps 7-10. Life xxx displayed. Life should be set to 005. Hit Menu key. TNL xxx displayed. TNL level should be between 90-110, if you have problems, try changing TNL. Hit Enter key Counter Set is displayed. Hold down Form Feed key and insert blank paper into manual feed slot. You should get a beep confirming reset. Power printer down and back up, you are done.
Oct 06, 2010 | Sharp FO-4400 Fax
How to turn printing on and off?
PRINT KEY: To save paper you can only print what is displayed, even in non-print mode. Pressing after the entry of a number will print the entry with the symbol “#” even in non-print mode. Pressing will insert a separator into a number entry such as a code, date, etc. Separators are displayed as a period and dashes but printed as periods. MEMORY + KEY / PRINT ON / OFF KEY: Pressing selects print mode or non-print mode. Cause the calculator to operate in a display / print or display only mode, depending upon the calculator’s present state. “P” on the display: Print mode. “NP” on the display: Non-print mode. MEMORY – KEY / DECIMAL SELECTION KEY: Pressing sets the number of decimal places in the result. “F” on the display: The answer is displayed in the floating decimal system. “3, 2, 1, 0” on the display: Presets the number of decimal places in the answer. “A” on the display (Add mode): The decimal point in addition and subtraction entries is automatically positioned to the 2nd digit from the lowest digit of entry number. Use of the add mode permits addition and subtraction of numbers without entry of the decimal point. Use of , and will automatically override the add mode and decimally correct answers will be printed.
Aug 18, 2010 | Sharp EL-1611P Calculator
How to delete "Memory Full" message in Canon imagerunner , 2000/1600 series copier
Get in to service mode i.e, press Additional function(*) button. Then press 'ID' button. '$ service mode' symbol appears. Press < or > buttons till No.' 12 clear' comes. Press ' OK '. Then press < or > till ' ALL ' comes. Then press ' OK '. Switch OFF and ON.
Jul 21, 2010 | Canon imageRUNNER 2000 Copier
HP Deskjet 3845 print queue not clearing
Have you tried going to safe mode, turning off the printer and manually opening it at the control panel>printers... try and delete or cancel prinitng at these settings...
Dec 09, 2007 | HP Deskjet 3845 InkJet Printer
Magicolour 2350
Try updating the drivers for the printer from the manufacturers web site. I doubt the issue is related to the printer itself, otherwise it would fail to print magenta all the time.
Jul 25, 2007 | Minolta magicolor 2350 Laser Printer
Casio 140CR Cash Register Logo
32 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
