Question about Varian Cp-3800 Gc Manual
Column pressure - Varian Cp-3800 Gc Manual
Why is the steering column moving on my 2007 GL450?
there are probably small plastic lock pins that take up the slack in the column
these break of when a heavy pressure is applied to the wheel either by the drive or in an accident to allow the column to collapse
the fix is a new steering column
check the steering column for failed "U" joints or flexible connections
Take it to an accredited specialist steering shop for a proper diagnosis
Oct 26, 2015 | 2007 Mercedes-Benz Mercedes Benz Gl 450
How can I fix a faulty vale water vale working incorrect
the pressure activated switch is turned on to control a shutoff valve when the pressure in the clear tube reaches a certain level. If the tube is blocked, it will not get the light pressure on the air trapped by the column of water. Boyle s law P1V1=P2V2,
so replace (or clean out) tube with the same ID tube or the volume inside will not be correct for the rising column of water to activate the pressure switch.
Nov 09, 2014 | Washing Machines
Steering column top bearing replacment
double posted, with 1999 added.
the FSM says dont reuse steering wheel bolts.. (unique)
here is an online quote to get to the combo switch
quote;
Removal & Installation
  1. Disconnect and isolate the battery negative cable. WARNING(bags can kill, my comment)
    Wait two minutes for the airbag system reserve capacitor to discharge before performing further diagnosis or service.
  2. From below the steering column, remove the three screws that secure the lower steering column shroud to the multi-function switch mounting housing.
  3. Using hand pressure, push gently inward on both sides of the upper shroud near the parting line between the upper and lower shrouds to release the snap features that secure the two shroud halves together.
  4. Remove both the upper and lower shrouds from the steering column.
  5. Remove the Steering Control Module (SCM) from the steering column.
  6. Remove the two screws that secure the left multifunction switch to the SCM .
  7. Disengage the two retaining tabs , next to the screw mounts that secure the left multi-function switch to the SCM.
  8. Disconnect the left multi-function switch from the SCM.
To install:
  1. Position the left multi-function switch onto position on the Steering Control Module (SCM) .
  2. Engage the two retaining tabs, next to the screw mounts that secure the left multi-function switch and firmly snap into place.
  3. Install the two screws that secure the left multifunction switch to the SCM. Tighten the screws to 22 inch lbs. (2.5 Nm).
  4. Position the lower steering column shroud to the underside of the steering column.
  5. Install the three screws that secure the lower steering column shroud to the multi-function switch mounting housing. Tighten the screws to 17 inch lbs. (2 Nm).
  6. Position the upper column shroud over the steering column with the hazard warning switch button inserted through the hole in the upper shroud.
  7. Align the snap features on the upper and lower shrouds and apply hand pressure to snap them together.
  8. Reconnect the battery negative cable.
Dec 22, 2013 | 1999 Jeep Grand Cherokee
Runs but only when applying pressure to the steering wheel
sound like loose wires to the ignition switch in the steering column. just remove steering column shroud and lower the steering column check the ignition switch wires.first disconnect negative battery cable before working on ignition switch. either switch wires loosen or switch could be bad.
Jul 29, 2013 | 1990 Ford F150
Propane ventless wall heater pilot light is to big
You have the correct pressure equaliser on the propane bottle giving the correct pressure.
  1. The minimum gas supply pressure must be 1" water column (249 pa) above the manifold pressure printed on the appliance data plate
  2. The maximum gas supply pressure must not exceed 14" water column (3487 pa or 34.9 Millibars)
Feb 10, 2018 | Heating & Cooling
G'day to you. We have an AEG OKO lavamat 88840 update washing machine. Today we put it onto a 40 deg programme, using the Time Saver function. After approx. 5 minutes, it stopped mid-programme, with...
Check your pressure sensor. Make sure that the air column that operates the pressure sensor is not blocked. Find the pressure sensor and remove the air hose to it. Blowing into it with the hose attached to the pressure sensor will check the pressure sensor. Use an ohm meter to measure if it changes. Blowing on it with it connected to the air column will check that nothing is blocking it.
Nov 08, 2017 | AEG Washing Machines
Carrier furnace burners will not light.if i blow at the burners it will light.I think maybe bad gas valve or not enough pressure
this sounds exactly like the problem. I replaced a gas valve yesterday in a Goodman furnace that had the same symptoms. I would check it or have it checked with a manometer before you replace the valve. If your inlet pressure is right and you cant get enough pressure by turning the adjustment screw clockwise, it is bad. LP should have @11-13inches of water column coming into the vavle and an outlet pressure of 7 inches of water column. Natural gas should have @5-7 inches coming in and an outlet pressure of 3.5 inches of water column
Jan 06, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
My 1998 saturn has a steering wheel problem. It is locked in park and will not unlock do I need to replace the whole steering column I can't start it ect..
Well, if your wheels are turned to one side it may just be that you have to put a lot of pressure on the steering wheel, which in turn puts a lot of pressure on the ignition lock, making it seem like your steering column is locked. You will have to take the pressure off of the ign lock so you can turn the key. I am talking about some serious pressure. Ask someone you know that is a "bigger person" to turn the wheel while you turn the key from the passengers side.
Oct 13, 2009 | 1998 Saturn SL
Steering
Is your wheel turned in one direction all the way?
Can you not turn the key to the on position?
If so try relieving the pressure off the steering column by applying pressure to the steering wheel in the opposite direction that the wheels are turned and try to turn the ignition on then.
Somtimes the pin on the steering column gets pressure applied to it when the wheel is turned in one direction fully.
Hope this helps
Sep 06, 2009 | 2001 GMC Yukon XL
Varian Cp-3800 Gc Manual Logo
59 people viewed this question
Top Varian Science & Laboratory Experts
Tom Chichester
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Varian Science and Laboratory Expert? Answer questions, earn points and help others
