Question about MSI Computers & Internet
FRONT PANNEL CABLES - MSI Computers & Internet
    Brigadier General:
  • MSI Master
  • 3,400 Answers
Hi! i am using Intel DG33FB motherboard, i need the information about the connectivity of front pannel audio. for this it is Realtek HD audio port. i am having 5 cables set for the front pannel...
The L&R-Ret2&3 are common so only one needs fitting so for the speakers you only need to connect 3 cables. R-Out, L-Out and one return (either L of R). I'll comment back shortly on the mic pins for you.
Dec 23, 2010 | Computers & Internet
I have P5KPL-AM/PS motherboard. How can i activate my audio front pannel
First of all check if your front panel is connected via cables to motherboard. I am biding that is not connected.
Oct 30, 2010 | ASUS P5KPL-AM SE Motherboard
How can i replace my turn on/off switch ?
Try first to remove the cables and battery to it. Then press and hold the power button for 10 secs. Then reinsert cables and battery. If didn't turn on, try to remove cables and battery again. Then remove the screws at the bottom part of the laptop. Then remove the hard drive and optical drive. Then unscrew the screws at the front part of the laptop, and then remove the motherboard and keyboard then you can replace the on/off switch...
Jun 22, 2010 | Acer TravelMate 4220AWLMi Notebook
HOW DIFFICULT IS IT TO REPLACE THE WINDOW MOTOR IN THE DRIVERS DOOR? THANKS
Time consuming but it can be done. Are you sure the motor is bad? I'd check the switch and also check the wiring inside the black, rubber boot that runs from the door to the inside of the car. Over time when you open and close the door a bazillion times, the wires in the boot flex and sometimes break. Kind of tough to peel the rubber boot back but I'd go that route before ripping the door apart and replacing the motor.
My first inclination is a bad switch.....
Good Luck
Dec 29, 2009 | 2001 Chevrolet Suburban
My motherboard doesn't specify input for computer case cables
First you need to know the model of your motherboard. Next visit manufacturer's site if can't find the manual, Google it.
May 20, 2009 | Computers & Internet
Front pannel connection regards
there are small input adapters lying unused in your cabinet.just connect them to the incoming adapters and you are done.
Oct 24, 2008 | Mercury P4VM800M7 Motherboard
Error message
its the problem of internal white colour cable.
there are two white cables one the front pannel cable and other the scanner cable.any of the two cable could be faulty very rare chance of both faulty but may me faulty.
thanks
Aug 22, 2008 | HP OfficeJet 7410 All-In-One InkJet...
The OSD on my Harman/Kardon 347 does not show up anymore. I am using a Compostie cable and it just stopped working a while ago. I had hooked up an X-Box 360 to my T.V using the 3 RED, GREEN, BLUE component...
Put the receiver in stand by mode (amber light) and hold on the tone button for 8 seconds. This will reset the receiver. After it says reset, let go of the tone button and wait about 30 seconds. Then hit OSD and you should be good to go.
Jul 22, 2008 | Audio Players & Recorders
Soltek SL-75FRN2-L front pannel connecting
The USB header on the MOBO is an 8 or 10 pin in a 2X4 or 2X5 orientation. there will be one pin missing, that is not unusual. the plug will have the same socket filled. Most MOBOs have multiple USB headers on it and they are almost aleays labeled USB2 or whatever number.
May 19, 2008 | Soltek SL-75FRN2-L Motherboard
Computers & Internet Logo
18 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
