Question about Ford 8340 Tractor W/rops 1/16
Hi my Ford 8340 SLE shows error codes 1 , 3 and 7. I know that they means but I unable to find there is a problem and digital/electronic instrument cluster shows only gears and error codes, please help
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 34 Answers
If you have a autozone near you they can help find your trouble
Posted on Aug 19, 2013
1996 GMC Sonoma 4.3 SLE has a P1886 code showing what and where is the problem?
the code is 4x4 initialization error. which means if you have a 4x4 then the computer is not seeing it. or if you have a 2 wheel drive then the computer "glitched" and now it thinks it is a 4x4 . either way the computer will have to be "flashed" that is reprogrammed.
Nov 18, 2011 | 1996 GMC Sonoma
Unable to use the oven since the power outage...two codes appear on the display--e1 f1......tried to reset but no luck.
Hi
Error code F1-E1 means that an error with the keypad has occurred. Usually it happens due to loose ribbon cable on the keypad or the electronic control assembly itself going bad. To resolve this issue first, disconnect the power to unit and then gain access to the back of the clock assembly (Electronic Range Control/ERC). Now unplug the touch pad ribbon connector from the ERC, it would be a flat wire approx. 1 1/2" to 2" wide and make sure that the cable is not broken and nothing is shorted on the keypad. After this is done insert the cable back and then plug the unit back to check. If the error is still there then the electronic control board should be replaced. Hope this helps...please post back for further assistance.
Daniel
Jul 25, 2011 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
I get error codes on the unit. Can you tell me what the error codes mean?
I AM GETTING ERROR 3 ON MY LIFESOURCE BLOOD PRESSURE MOINTOR 7 WHILEPUSHING ON START BUTTON,IT DOES NOT GO AHEAD MORE THEN FIGURE 2 & COMES BACK TO 1 & THEN SHOWS ERROR 3,CAN ANYONE,SUGGEST OR GIVE SOLUTION/REMEDY ON MY MAIL ID:hemant_pandya12@yahoo.com I HAD LOST OPERATING MANNUAL & WARRANTY CARD,ALTHOUGH THIS MONITORING INSTRUMENT'S HAVING LIFE TIME WARRANTY,INCLUDING CUFF. THANKING YOU.
H.M.PANDYA.
Mar 03, 2011 | Lifesource Digital Blood Pressure Monitor...
Radio code for my ford fiesta
Your Code is : 1 6 4 8
Ford  Code Entry Instructions
Once the unit has been turned on the display will show ' CODE - - - -'
Press preset [ 1 ] repeatedly for the first digit
Press preset [ 2 ] repeatedly for the second digit
Press preset [ 3 ] repeatedly for the third digit
Press preset [ 4 ] repeatedly for the third digit
To save the code press the [ 5 ] key to accept.
The set should now operate.
Mar 06, 2010 | Alpine Car Audio & Video
Getting an f-- warning and on control panels
Hi there.
The F-- error means the camera cannot detect an electronic contact with the lens; since you are using a "G" lens, it was likely a matter of an improperly mounted lens, or likely dirty electronic contacts on either the camera body or lens.
Give it a clean, remount the lens, clean the electronic contacts and try it manual mode.
Good luck
May 29, 2009 | Nikon D80 Body Only Digital Camera
Temperature control show code CE model GLFU2067FW4
It means there is a wiring error in the door. The only way to fix this error is to get a new door. What a pain! I had the same problem and the freezer was only 1 1/2 years old - thank goodness the manufacturer didn't charge me.
Mar 28, 2009 | Frigidaire Freezers
Sharp mini system error code 20
The code CD20 means Tray error. The cd mechanism will have to be reset by a serviceman .
Jan 06, 2008 | Sharp Multi-System Mini Component System...
Ford 8340 Tractor W/rops 1/16 Logo
144 people viewed this question
Top Ford Toys Experts
D. E. Hev
Are you a Ford Toy Expert? Answer questions, earn points and help others
