Question about Xerox Phaser 3100MFP/S Laser Printer
Ready. Missing param
Pdf param missing
Quero ar arquivos e packs aparesse name is instaler missing
Aug 22, 2012 | Microsoft Windows 7 Home Premium 64BIT...
How do i change language from french to english model no it's e63
follow this settings->phone settings-> language settings->phone language-> english.
Param?tres-> Param?tres-> Param?tres du t?l?phone-> language language-> Anglais T?l?phone. for help use this :http://translate.google.com/
Oct 25, 2011 | Nokia E63 Cell Phone
The screen looks blue and i have tried the converence
<object width="640" height="360"><param name="movie" value="http://www.youtube.com/v/9oI1Nzq7CR8&hl=en_US&feature=player_embedded&version=3"></param><param name="allowFullScreen" value="true"></param><param name="allowScriptAccess" value="always"></param><embed src="http://www.youtube.com/v/9oI1Nzq7CR8&hl=en_US&feature=player_embedded&version=3" type="application/x-shockwave-flash" allowfullscreen="true" allowScriptAccess="always" width="640" height="360"></embed></object>
Oct 03, 2011 | JVC AV-56WP74 56" Rear Projection...
I have a Gateway MXMX6438 laptop. I am missing the
yes i can,go to this site and download the drivers you need from here http://support.gateway.com/support/drivers/search.asp?st=pn&param=1008901
Dec 17, 2009 | Gateway MX6438 Notebook
I can't find a way to increase a ring tone volume on my Samsung SGH-U700.
there should be 2 buttons on the side of the phone push the top one or menu>settings>profiles>pick on that you want to use then hit the left soft key and scroll down to volume
done
Apr 17, 2009 | Samsung SGH-U700 Cellular Phone
Change baud rate
Baud Rate is to lower the transmission speed of the fax, however these are the temp settings and once the power is off you have to reconfigure that. Follow the following steps :
From the front panel:
  1. Press and hold the * key for 3 to 5 seconds until the display screen reads Test -001+ .
  2. Enter in 620 on the key board, and press the Check Mark and the screen will read Cfg param id:
    1. Enter the parameter ____ on the key board and press the Check Mark.
    1. 159 - Receiving Fax baud rate
    • 153 - Transmitting Fax baud rate
    1. The screen will read Cfg param val: 26
    1. Enter in the value ____ and then press the Check Mark .
    1. 0 = V.17 14400
    • 2 = V.17 9600
    • 6 = V.29 9600
    • 10 = V.27 2400
    1. Screen will read Test -001+
    2. Press the Reset button until you get back to Ready
    Dec 13, 2007 | HP OfficeJet D135 All-In-One InkJet...
    Xerox Phaser 3100MFP/S Laser Printer Logo
    204 people viewed this question
    Top Xerox Office Equipment & Supplies Experts
    Xeroxrep
    Level 1 Expert
    Philip Hughes
    CheckitRight
    CheckitRight
    Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
