Question about Ovens
Lamona oven LAM 3204 Do I close oven door when grilling
  • George Watson
    George Watson Mar 16, 2014
    I think so. Do you keep it open? Wondering this myself...
  • George Watson
    I mean I think u keep it open
5 Suggested Answers
  • 250 Answers
SOURCE: No Grill operation for stoves 720ef
Supply an email address for you and I will grant you access to my BT Digital Vault where a copy of the complete handbook is lodged. It includes circuit diagrams.
With your fault, can you here the switch operating, if not it just may be stuck?
Posted on Dec 16, 2009
SOURCE: diplomat softline oven with separate grill
grill will not light, door was shut when grill was on.
Posted on Apr 05, 2010
SOURCE: my oven door does not close tight
These hinges are now obsolete and you cannot get them anywhere. The poblem with this type of hinge is not with weak springs or anything like that, it is with the pivot pin in the door hinge. Follow these instructions and it will not cost you anything for the repair.
It is best to remove the oven from the housing. Remove both sides of the oven panels, you have to remove the top first, then the sides (remove about 20 screws all together). Support the bottom oven door first by tying a bit of string between the bottom and top oven door hand rails. This will stop the door falling down when you remove the springs. unhook the springs and the door will just slide out. (Use a loop of string attached to the back end of the spring to pull it from its holes.)
Dismantle the door by removing the screws. You will probably find that the the hinge pivot pins have come away from the U shaped hinge bracket. The secret is to make sure that these are fixed firm back into the bracket. What I did was to nip the U hinge bracket in a vice, (or use pliers) so that the pin will now protude slightly each side of the bracket. This allows more surface bearing area so the pin will not pull itself out of the hinge. To further make sure, I glued the ends of the pin with epoxy resin.
Then reassemble.
My door now feels like a new one even though it is 15 years old.
Posted on Feb 04, 2011
  • 3 Answers
SOURCE: Cooker flavel milano 60 4 years old Oven working fine, but grill makes problms.may be i am not using right method. Actually every thing is fine, but when i start grill and close the grill door its fir
Hello, you're probably not getting enough air in to keep the flame sustained, check for an outside air tube that might be clogged, if not than try keeping the door a crack open. Hope this helps
Posted on Oct 22, 2012
Hello, my lamona oven tripped a fuse when i turned top grill on whilst oven was on. why does this happen?
not designed to do both at the same time . draws too much current .
Oct 22, 2016 | Ovens
Tip
Omega europa oven control settings
Fan symbol - defrost (fan only - does not use thermostat)
Fan symbol within a circle - fan forced oven
3 little triangles - static grill (keep oven door open)
3 triangles above the fan symbol - fan grill (keep door closed)
on Aug 30, 2010 | Ovens
Oven Wont Heat up
have an electrician check the oven element as it may be burnt out
Mar 07, 2016 | Ovens
I have a Bosch wall oven in my unit but no user manual. The number on the door is bosch hbe632uau/03. Is it ok to close the door when using grill function or will the glass blow out?
if the grill section is behind the oven door then the door should be open
if there is a door for the grill section then the oven door can stay closed
to get a user manual ,go google and type in-- user manual for bosch oven model ( type in what you have) --( or leave it out if it doesn't recognize the model)
If a page is available with a pdf version you can down load it
Oct 19, 2015 | Bosch Ovens
Should oven door be open or closes when grilling
if there is a separate grilling door above the oven door it has to be opened if not read the operators manual but normally the oven door would be open
Sep 14, 2015 | Ovens
Lamona oven manual
The instructions for Grill use are in this manual available online. As you have not provided the model number I am hoping this is close to what you have.
http://www.bgsa.co.uk/student/downloads/oven_01010903.pdf
Aug 25, 2014 | Ovens
Lamona LAM 4400 oven not switching on
may be an internal fuse / wire burnt off oven control as nothing works
Nov 10, 2013 | Ovens
NEW WORLD - NW601FP Electric Oven
i believe after buying this oven that the left knob at turning clockwise position 1 is defrost which works by just blowing room temp air around, position 2 is oven on, position 3 is conventional grill must be used with door open and position 4 is fan grill can be used with door closed ,and the knob on the left is for setting oven temp and and turn fully round when using the grill to heat the grill
Jan 17, 2012 | New World Ovens
Diplomat softline oven with separate grill
Nov 05, 2008 | Ovens
Ovens Logo
318 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
