HOW TO SET UP Bush CHT100DVDTB Home Theater System
skotkolr
  • 558 Answers
SOURCE: HOME THEATER SYSTEM SET UP
75 ohm coax cable generally does not carry 5.1 surround, you may need to see if your cable box has a 5.1 surround capability, the cable company will be able to help you on that .one other thing the receiver you are using (distribution) may need to have the source changed to the one from the cable box ie. fiber optic or coaxial (orange rca plug). red and white from the cable box does not carry 5.1 surround, only stereo. thanks for using fixya!
Posted on May 28, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: philips home theater system
Make sure there is a video cable of some type running from the back of the Philips to the television, and make sure the TV is on the correct source channel. Make sure the home theater system is in disc mode.
-Tha Mp3 Doctor
Posted on Dec 31, 2008
SOURCE: sony home theater system ht-k25 instructions
http://www.manualsmania.com/model.php?model=59dab3492a57f91914626b922f6b9e3237bdd95
here's the online instructions, all the wires are colour coded so you can't go far wrong.
Posted on Feb 27, 2009
ginko
  • 19396 Answers
SOURCE: sony home theater system started blinking protect
Protect mode will kicking whenever a fault is detected.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Posted on May 04, 2009
  • 21 Answers
SOURCE: Can't get the Samsung HT-z310 Home Theater to stay on AUX2
you need a fibre optical cable for this, simply you connect that from your dvd to tv and then set the input on the dvd to digi in. i have exactly same home cinema system.
Posted on Sep 14, 2009
My home theater system shows only philips logo and nothing else... I want to reset my htb3520/94 bluray home theater system...
Reset it to what? Go to set-up on your theater and make sure you have your TV on the correct HDMI input for the theater. Go through set-up. That should do it. . .
Aug 19, 2017 | Philips Audio Players & Recorders
I want to upgrade to a 4k tv but my home theater does not support 4k. Can i run sound only thru it?
You can run the sound to the home theater system in many cases. It depends on the home theater system and the TV. If the home theater system has a digital audio input, it is easy to connect most 4K TVs. Connect the 4K source to the HDMI or Displayport connector on the TV. Check whether the digital audio uses an optical cable or a coaxial cable. Make sure that the TV has the matching output and get the correct cable. Set the TV to use external speakers (under the Audio part of the setup on most TVs) and turn off the internal speakers.
Very few 4K TVs have analog audio output. If your home theater system only has HDMI and analog (RCA red/white) audio inputs, you will need a digital to analog audio converter and both digital and analog audio cables. The converter will look like this: https://www.amazon.com/Gefen-Digital-Adapter-Converter-GTV-DIGAUD-2-AAUD/dp/B0013LWK3A .
I hope this helps. Please add a comment with the make and model of your home theater system if you need a more specific set of details about doing this.
Nov 20, 2016 | home Audio Players & Recorders
How do i program rca home theater
How to Setup a RCA DVD Home Theatre System RTD325W ...
? 10:31
https://www.youtube.com/watch?v=20dRIj8KWPU
Jan 28, 2012 - Uploaded by TheHandofOdd
Just how to setup and get the optical cable working for those who need help.
RCA Home Theater System Set Up - YouTube
? 5:37
https://www.youtube.com/watch?v=j0UhnbrjJto
Sep 14, 2012 - Uploaded by gangstafly5000
The RCA hooked up to 43' plasma Samsung. ... RCA Home Theater System Set Up. gangstafly5000 ...
RCA 5.1 Surround Sound 1000 Watt HOME THEATER ...
? 13:06
https://www.youtube.com/watch?v=1xfEmkwCwyA
Oct 18, 2014 - Uploaded by bigtruckseriesreview .
I bought recently rca system home theater and makes strong fan.... +Aiden woodruff Change he settings to surround, and make sure all of the ...
How to Set Up an RCA Home
Jan 13, 2016 | RCA Televison & Video
Need help, got a LG 42PJ550 Plasma TV and a Bush Model CHT100DVDTB but there isnt a headphones socket so i can link it up, have you guys got any ideas or help?
Theres a simple solution
you should buy
a scart adapter
http://www.amazon.com/Scart-Composite-S-Video-Audio-Adapter/dp/B006RBMJ46/ref=sr_1_1?ie=UTF8&qid=1408100307&sr=8-1&keywords=scart+adapter
and
some rca audio cables
http://www.amazon.com/iMBAPrice%C2%AE-PREMIUM-6-Feet-Stereo-Plated/dp/B001VIYYCK/ref=sr_1_2?ie=UTF8&qid=1408100626&sr=8-2&keywords=rca+cable
plug it in
and plug the red and white cords to your auxiliary input from your Bush model (its located to the back of you home theater and writes aux) then by pressing the aux button you should hear volume from your tv
Ps the adapter switch should be at the output mode
hope that was somehow helpful
Aug 10, 2014 | LG 42LG50 42 in. LCD HDTV
How do i hook up a rca Rtd325w dvd home theater to a coby tft lcd flatscreen
You can use either the multi pin connector cable, or plug the white, yellow and red cables to the TV set at the DVD player input or "Video 1" and the the audio output of the TV Another red and white set of RCA cables into the audio input of the home theater. This way the TV can play through the home theater system when you are watching cable or over the air.
If you do not want to hear the TV audio, you should go to the audio properties and select "external speaker system" but if you do this the home theater system must be on to hear any audio from the set until you set it back to the TV speakers through the TV's setup menus again.
Apr 03, 2012 | RCA Audio Players & Recorders
Hi, i have just bought a bush cht100dvdtb home cinema system and was wandering if i could get the sound through the speakers when just watching tv
owen steve,
I am not familiar with this brand and cannot locate an owners manual for it to see what inputs you have available. Most home theater systems have more than one input and also have various formats which can be input. For example: hdmi, dvi, rca etc. Your owners manual should have several possible setups and one I would think would be hooking your TV up to it. It would require an audio output from the TV but if your TV was made in the last 10 years that should not be a problem. It will probably be a pair of rca jacks. If so, just connect the output of the TV to the input of the surrround system. You should be able to select the input for that signal based on the input you inserted the cables into. When watching the TV you would just switch to the appropriate input.
If your unit only has one input (very unlikely) you could still make it work by running the audio from the DVD to the TV and taking the output of the TV to the cineama system.
Thanks for using FixYa and for the great rating.
hardrocko
Nov 25, 2010 | Televison & Video
The sound isnt being played through my bush cht2dvd home theatre kit when im watching tv only when im watching a dvd its connected to my tv with a scart cable, Help please.
Hi Hoggy - do you still have the problem?
One way I found to solve the problem - if you have a Sky box (I actually have Sky+), connect the AV cable between the back of the Sky box and the Bush system. Then using the 'source' button on the front of the Bush - select AV1 (or AV2 depending on which AV sockets you plugged in to).
(Of course - will only work when watching a channel on the Sky box)
Steve (stevemweiner'at'gmail'dot'com)
Dec 25, 2009 | Audio Players & Recorders
Compatibility fo TV and Sound system
TV has audio outputs, the RCA cable type. If you connect the audio output (red,white) from the TV(look on the back), and connect the RCA cable to Input of home theater system,you should get TV sound from home theater system. You may have to set the audio on the TV for external source. Go to menu, to audio setup, to options. On the Home Theater system, you may have to select the audio source, i.e. audio input 1, etc.
Aug 09, 2009 | Samsung Theater System
I keep getting the 'rear check' message on the tower panel display and all cables are connected what could this be this is on my new HT-TXQ120 DVD HOME THEATER SYSTEM
With the home theater system off, press and hold the REMAIN button on the home theater's remote control for 5 seconds.
Note: You can release the REMAIN button when the POWER LED blinks blue.
With the wireless module turned on, use a ball point pen to press the RESET button on the back of the wireless module. The POWER LED in the front of the home theater blinks two times.
Turn on the home theater. The LINK LED on the front of the SWA-3000 changes from red to blue, indicating the wireless module has connected to the home theater.
If your home theater continues to display rear check after you have tried the steps above, call Samsung Customer Care at 1-800-SAMSUNG (1-800-726-7864). Have your model number and serial number on hand to set up service.
Jun 29, 2009 | Samsung HT-TXQ120 Home Theater System...
Nov 27, 2008 | Samsung HT-Z310T Theater System
212 people viewed this question
 Grubhead
Grubhead
