Need to know how to repair cracks on my paterned concrete drive
    New Friend:
    Problem Solver:
  • 10 Answers
Fixya is a place for technical problems. please turn around and go to yahoo answers or somewhere else cause this isn't the place to ask that question. sorry for the inconvenience but I will still provide you with a link. check out: http://www.bhg.com/home-improvement/advice/danny-lipford/repair-cracks-in-a-concrete-driveway/ I usally don't search the internet but I didn't know how to answer your non-technical question. sorry. hope this helps.
~JediBurrell
Posted on Jul 31, 2013
I needed the information to know about concrete drive way replacement. what should I know when the contractor comes to give estimate?
First off you need to make certain that he is going to jackhammer the old driveway and remove it from your property. I guess before that, be sure to get a reputable contractor to do it. Check with BBB if you would like to.. Then jackhammer and remove. Be certain that they are replacing the driveway with the proper thickness. I believe it is 4". They will lay down 4"x 4" wire sitting on little blocks called "adobe" blocks to suspend the wire off of the bottom.Be certain that they put crack reliefs in when they are finishing concrete. Those are the indentations that they put in due to the expansion and contraction of the concrete so it will crack in the indentations instead of on the slab. Be certain that they form up the driveway before the wire. They put 18 or 24" stakes in the ground and then nail the wood formers to the stakes. This is what hold the concrete in. They will pour it in one day then trowel it, install the expansion reliefs and then they will take a soft hair 24" pushbroom and give it a light brush finish. All of the edges will be troweled and rolled over nicely. Be certain that he doesn't over order on concrete. Basically it is length x width x depth 27 cu ft. = 1 cu. yard. There will be a small portion over to allow for any problems. This is normal. The next day they will come back, pull the forms and your good to go. Be sure to get 3 estimates. Good Luck!
Apr 21, 2017 | Heating & Cooling
How to repair cracks in concrete floors of house and how to make them waterproof
simply chip the conrete cracked maybe up to 3cm wide and 2-3 cm deep the whole way and clean thoroughlly with water and the best is to blow air after you wash with water to take away the loose debris then apply concrete epoxy arround the cracks with clean paint brush # 1-2 let it stay for about 30mins and you feel the epoxy is starting to set before then pour the conrete mix with fine sand that will do the trick.
Nov 05, 2013 | Hilti 378375 TE-YX 5/8" - 13" Concrete...
Repair concrete floor, large cracks in flooring
install backer rod into cracks that are more than an 1/8 and use concrete sealer (in the caulking section of your local hardware store). The backer rod is used to reduce the amount of sealer you have to use to bridge the larger gaps in the cracks.
Nov 05, 2013 | Mozilla Firefox
How do you fix a dip and crack in garage concrete? Our garage has a crack and is dipping down.
The highway department fixes this by drilling a hole and then pumping concrete under the concrete until it lifts up.
I suggest you contact local concrete company to see who does this type of pumping. I've seen them fix driveways.
Don't know how much it costs.
Oct 08, 2010 | Garden
How can I repair cracks in a concrete porch?
If this is on top or below (soffitt) If the cracks are movement or shrinkage when poured you can cut with Diamond grinder in a V type and then patch with a epoxy and sand fillers.If they are bigger you can use a repair motar .Your local hardware should have these in basic form.
Aug 27, 2010 | Poured Concrete
My Sony DSC-W1 5.1PIX camera fell on concrete
The cost to repair this unit under our Flat Rate Program is $141.00, (plus any applicable taxes). Return shipping is included in this price.
However, after creating the online repair request, you'll get an e-mail with the necessary cost info.
Aug 10, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Computers & Internet Logo
62 people viewed this question
David Payne
David Payne
