Follow this steps and fix it. God bless you
Rear-Projection TVs have a lamp, which picks up the
picture and projects it on the TV screen. A burned-out or connected lamps are
two of the most common problems for Rear-Projection TVs. First, you will want
to confirm the bulb is still good. If the bulb is bad then then replace it
immediately. Second consult your user manual and verify the lamp and lamp cover
are installed properly. Most Rear-Projection TVs have warning light which
notify you when there are lamp problems. Again consult the user's manual to see
what each light means.
SOURCE: Mitsubishi 52'' TV Model WD52525
U restart the tv,u hear alots of clicking?That mean the Ballast is dead or have problems,that why ur picture lamp not sustaning the picture.Replacing the Ballast might or will sustance the picture.
SOURCE: No picture and no sound after replace lamp for Mitsubishi WD-51525
I was having the same issue after a lamp replacement and the warranty tech said that it was the lamp power supply that went out. The part was on back order and look at the board neaqr the lamp and it had a blown capacitor. This would make since why the lamp would come on then shut off right away. She replaced the capacitor and works fine.
SOURCE: blinking timer Light (Green)
Thats a common problem caused by defective capacitors on the DM PWB which prevent the set from booting up. The V26 DLP DM kit at the following link will usually repair that issue and it comes with step by step instructions on how to do the repair. Look under the repair kit category.
http://servicemanuals.vstore.ca/
