Question about XO Vision Xtab Android Ebook Reader
Wi-fi Problems - XO Vision Xtab Android Ebook Reader
    New Friend:
I forget my pattern
Posted on Aug 26, 2013
How do I change the password on the kindle for the wireless network?
To add a new Wi-Fi Network:
If you don't see the network you want to connect to in the list of detected networks, you can add it by choosing "Enter other Wi-Fi network" at the bottom of the list of detected networks.
  1. Make sure you are within range of the network you want to add, and that you know the network name and password (if required).
  2. Press the Home button, then press the Menu button.
  3. Navigate to "Settings" by moving the 5-way controller down, then press the 5-way controller to select.
  4. Select "view" next to "Wi-Fi Settings" to display a list of detected Wi-Fi networks.
  5. Use the 5-way controller to navigate down to "Enter other Wi-Fi network" and press to select.
  6. Enter the name of the Wi-Fi network that you want to add.
  7. Enter the password (if required). Press the Symbol key to enter numbers or characters not present on the Kindle keyboard. You can continue to use the keyboard while the Symbol menu is displayed.
  8. Choose "submit." Kindle connects to the new Wi-Fi network.
If your Kindle fails to connect to the new Wi-Fi network, it will display an "unable to connect" message. You can try manually entering all the network information for the Wi-Fi network by choosing "set up network" when you see the "unable to connect" message. If you don't know the network information, try connecting to a different network, or contact the network's administrator.
To forget a Wi-Fi network:
You can tell Kindle to forget the Wi-Fi network you're connected to so that your Kindle doesn't connect to it automatically in the future.
  1. While connected to the network that you want to forget, press the Home button, then press the Menu button.
  2. Navigate to "Settings" by moving the 5-way controller down, then press the 5-way controller to select.
  3. Select "view" next to "Wi-Fi Settings" to display a list of detected Wi-Fi networks. You may have to wait a moment as your Kindle detects networks in range. The Wi-Fi network you are currently connected to displays the word "forget" next to it in the list of available networks.
  4. Choose "forget" to disconnect from the network.
To connect to a Wi-Fi network:
  1. Press the Home button, then press the Menu button.
  3. Select "view" next to "Wi-Fi Settings" to display a list of detected Wi-Fi networks. You may have to wait a moment as your Kindle detects networks in range. Kindle automatically scans for available Wi-Fi networks at periodic intervals. To rescan for available networks at any time, select "rescan."
  4. Select "connect" to connect to a network. If you see a lock symbol next to "connect," the network requires a password to connect.
  5. If necessary, enter the Wi-Fi network password, and choose "submit." Press the Symbol key to enter numbers or characters not present on the Kindle keyboard.
Once you are connected to a Wi-Fi network, Kindle automatically connects to it again whenever that network is in range. If more than one previously used network is in range, your Kindle automatically connects to the network that was most recently used.
Tip: Once your Kindle connects to a Wi-Fi network, that network displays "forget" next to it in the list of available networks. Selecting "forget" disconnects your Kindle from that Wi-Fi network and also prevents Kindle from automatically connecting to it in the future.
Mar 07, 2016 | Tablets & eReaders
I have a nextbook. 7".tablet my Wi-Fi want come on what do I need to do?
go into settings and turn on wi fi if it has wi fi. check aeroplane mode is off. Know WEP or WPA encryption key for Wi FI also if security being used on Wi Fi system.
Aug 14, 2015 | Tablets & eReaders
Irulu 7" tablet keeps disconnecting from internet. It's connect for a minute or so and then just drops. Just received replacements for 2 in the mail yesterday. No connection problems with old ones.
How many 'bars' are showing on wi-fi signal strength indicator (presuming you are using wi-fi for internet access)? If the signal strength is low, you could be losing connections that way, or there might be interference on the wi-fi channel that the tablet is using. Try changing channels in your wi-fi setup and see if there is an improvement in the behavior.
Feb 07, 2015 | Tablets & eReaders
Cant get wi fi signal.
Solution 1.Check wireless connection.
The first step of diagnosis have to any other device connected to the same network, ensure the wireless connection is working fine, or verify the settings of your wireless router to correct it.
2.Check your Keep Wi-Fi on during sleep Settings.
Owing to Wi-Fi sleep policy your Wi-Fi connection may be going to get disconnected every now and then.
Tweak this policy to keep your Wi-Fi connection awake.
[Settings] >>[Wi-Fi]>>[Advanced]>> Check [Always] to keep the Wi-Fi on during sleep.
Save changes and exit all the screens. Your Wi-Fi will never get disconnected again due to this policy.
3.Check signal strength of wireless connection.
The performance of a wireless network connection depends in part on signal strength.
You have to connect the Wireless network where the signal strength is strong.
Check Wireless network signal strength icons in notification bar.
4.Try to turn off/on Wi-Fi on the device.
First to turn off Wi-Fi, [Settings]>>[Wi-Fi] >>[turn Wi-Fi to off].
And then to turn on Wi-Fi, [Settings]>>[Wi-Fi]>>[turn Wi-Fi to on].
5.Try to forget network on the device.
Forgetting wireless networks allow your tablet/phone to reset some settings.
[Settings]>>[Wi-Fi]>>Press & hold your[Net Work Name(SSID)]for 2 seconds.
>>Select[Forget Network]>>Re-Connect your wireless networks if it's disconnected.
6.Try to reboot your device.
7.Make sure your firmware is up-to-date.
>>Select[Settings]>>[About tablet]>>[System Firmware Update]>>[Check Update].
8.Try to reset your device.
Note: once RESET was performed, all data, apps, settings and personal information will be deleted after initialization.
Third-party programs might be the major probability of Tablet/Phone instable, suggested to have a full reset for the device if the situation persists.
[Settings]>>[Backup&reset]>>[Factory data reset]
9.Try to other wireless connections.
If steps above were not able to solve internet connection problem still, please try other wireless connections if available, otherwise contact your networking provider to technical support.
Oct 09, 2014 | Worryfree Gadgets 7inch Zeepad 7.0 Android...
How do I determine what generation is my iPad?
on the backside of the iPad is a model number: determine-generation-ipad-jq4dbyibaqf10wv4m2e43laj-1-0.jpg determine-generation-ipad-jq4dbyibaqf10wv4m2e43laj-1-2.jpg
Model iPad (1st generation) iPad 2 iPad (3rd generation) iPad (4th generation) iPad Air iPad Air 2 Picture 200px-ipad_1_psd_mockup.png 200px-ipad_3.png 200px-ipad_3.png 200px-ipad_3.png 170px-ipad_air.png 170px-ipad_air_2.png Model Number[99] A1219 (Wi-Fi)
A1337 (Wi-Fi + 3G) A1395 (Wi-Fi)
A1396 (GSM model)
A1397 (CDMA model) A1416 (Wi-Fi)
A1403 (Wi-Fi + Cellular (VZ))
A1430 (Wi-Fi + Cellular) A1458 (Wi-Fi)
A1460 (Wi-Fi + Cellular (MM))
A1459 (Wi-Fi + Cellular) A1474 (Wi-Fi)
A1475 (Wi-Fi + Cellular) A1566 (Wi-Fi)
A1567 (Wi-Fi + Cellular How to find iPad IMEI ICCID serial number
http://en.wikipedia.org/wiki/List_of_iOS_devices#iPad
Sep 21, 2014 | Apple iPad Tablets & eReaders
How to tune in kindle to wi fi?
From the Home screen, press the Menu button.
Select Settings, and then select view next to Wi-Fi Settings.
In the list of detected networks, choose a network to connect to it.
If your Wi-Fi network and router support WPS (Wi-Fi Protected Setup), your Kindle will detect it.
If you don't see your network in the list, you need to add the network manually.
If the network is protected by a password or WPS (Wi-Fi Protected Setup), enter the password and then select Submit.If you don't know the Wi-Fi network password, contact the person who set up the Wi-Fi network.After you connect to a Wi-Fi network, your Kindle automatically connects to it again whenever that network is in range. If more than one network is in range, your Kindle automatically connects to the last network used.
Aug 16, 2014 | Amazon Kindle Fire HD
Why wony my nobis nb09 connect to wifi tablet problems
1. Make sure your device's OS is up-to-date.
2. Make sure Wi-Fi is enabled.
3. Make sure you are using the right password to connect to the Wi-Fi.
Jul 22, 2014 | Double Power Nobis NB09BLUE 9" 8 GB Wi-Fi...
Nobis tablet problems
Maybe you have the wrong password, perhaps it's case sensitive, maybe you have the wrong encryption set up on your router, maybe the tablet is faulty. Try it elsewhere to narrow the problem.
Jul 22, 2014 | Double Power Nobis NB09 9" 8 GB Wi-Fi...
How do I know if my iPad is an IPad 2 or 3
check the model nr. on the back side:
Apple Device Model Number
1iPad Wi-Fi (Original/1st Gen)A12191
iPad Wi-Fi/3G/GPS (Original/1st Gen)A13371
iPad 2 (Wi-Fi Only)A13951
iPad 2 (Wi-Fi/GSM/GPS)A13961
iPad 2 (Wi-Fi/CDMA/GPS)A13971
iPad 2 (Wi-Fi Only, iPad2,4)A13951
iPad 3rd Gen (Wi-Fi Only)A14161
iPad 3rd Gen (Wi-Fi/Cellular AT&T/GPS)A14301
iPad 3rd Gen (Wi-Fi/Cellular Verizon/GPS)A14031
iPad 4th Gen (Wi-Fi Only)A14581
iPad 4th Gen (Wi-Fi/AT&T/GPS)A14591i
iPad 4th Gen (Wi-Fi/Verizon & Sprint/GPS)A14601
iPad Air (Wi-Fi Only)A14741
iPad Air (Wi-Fi/Cellular)A14751
May 26, 2012 | Apple iPad Tablets & eReaders
I can not or do not have a password for the sky wifi how do i get it
If the sky wi-fi is your own wi-fi service then the password is normally on a typed label stuck to the wi-fi router itself along with the SSID of the wi-fi network which should be the same as you have selected on the Kindle in confirmation you are connecting to the correct network.
If the sky wi-fi is not your own wi-fi then you will either need to contact the owner or administrator of that network or select a different wi-fi network to connect to as described in the Kindle Support web pages for your device.
Dec 27, 2011 | Amazon Kindle Wireless Reading Device
XO Vision Xtab Android Ebook Reader Logo
41 people viewed this question
Top XO Vision Tablets & eReaders Experts
Are you a XO Vision Tablet and eReader Expert? Answer questions, earn points and help others
