A large black transparent strip is appearing on my Samsung UA40D5500? How to remove it?
    Champion:
  • 220 Answers
This is a Known issue with this Samsung model.The LED panel needs to be replaced.
Posted on Feb 06, 2014
Large black transparent strip is appearing on my Samsung UA40D5500
This is a known issue with this Samsung TV.Problem maybe temporarily solved by twisting left hand top corner and bottom right slightly.
Permanent solution is replacement of panel.
Samir
Aug 18, 2013 | Televison & Video
I have a cartridge jam - how do you fix it?
It could be due to the cartridges or the encoder strip (transparent strip found behind the cartridge carrier) has gotten loose from its position. Please follow steps below to identify and fix the problem:
1. Open the printer cover and remove both the cartridges. Note: If the carrier does not automatically move to the center, turn off the printer/unplug the printer from the power source and then slide the carrier to the center.2. Check the encoder strip and make sure it is secured in its place.3. Close the printer cover.4. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.5. When the printer turns on, reinsert one cartridge first. Close the printer cover and check for any errors.6. If no error appears, reinsert the other cartridge. Close the printer cover.7. Replace whichever cartridge is causing the error to appear with a new cartridge.8. If no error appears, try to print a document again to verify that the problem is fixed.
Nov 25, 2011 | Lexmark X4650 All-In-One InkJet Printer
Carrier stall
Nov 01, 2011 | Lexmark X7170 All-In-One InkJet Printer
Carrier jam lexmark x7170
Let me know if this helps. Thanks.
Carrier jam
Carrier jam on lexmark x5070 how do I fix it or clear it?
We apologize for the inconvenience. Please follow the steps below to identify and fix the problem:
  1. Open the printer cover to access the cartridge area. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
  2. Remove both cartridges from the printer.
  3. Check the cartridge area and make sure encoder strip is not loose. The encoder strip is transparent strip located behind the cartridge carrier along with the carrier belt.
  4. If encoder strip is properly seated in the printer, close the printer cover.
  5. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
  6. When the printer turns on, re-insert one cartridge first. Close the printer cover and check for any errors. The carrier jam could be due to one of the cartridges.
  7. If no error appears, re-insert the other cartridge.
  8. Replace whichever cartridge is causing the error to appear.
  9. If no error appears, try to print again to verify that the carrier jam issue is fixed.
We hope this information has been helpful.
Oct 11, 2011 | Lexmark X5070 ALL-IN-ONE InkJet Printer
The printer states that their is an automatic alignment problem does not print the black even if a new cartridge is inserted. What could the problem be?
Open the printer cover and remove both cartridges. Check the cartridge area for any obstructions or foreign objects blocking the cartridge carrier path. Also, try to check for the encoder strip (transparent strip behind the cartridge carrier) and make sure it is not unseated from its position. The encoder strip helps with the mechanism of the cartridge carrier in the assembly.
When cartridge is clear and looks normal, close the printer cover. Unplug/re-plug the printer into the power source to reset it. When the printer turns on, firmly re-insert the cartridges. If no error appears on the printer screen, try to print again.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Sep 02, 2011 | Lexmark X8350 Print, Scan, Copy and Fax...
Keep getting a carrier jam on my lexmark x6650
Try to open the printer cover and remove the cartridges. While the cover is open, check for a transparent strip(encoder strip) that may gotten unseated from its position. If transparent strip is still in position behind the cartridge carrier assembly, check the carrier path and make sure there are no debris or obstructions along its path.
Apr 24, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
Black line appears in copying from Konica Bizhub 200
If the black line appears ONLY when copying and NOT when printing then you need to clean the adf strip glass. This is the thin strip of glass that is just to the left of the large original glass. Clean this glass very well with a soft cloth and glass cleaner. The line is caused by a small particle stuck to this strip of glass.
Good Luck and Thank You for using Fixya.
Jul 06, 2010 | Minolta Di3510f Bizhub Copier
Transparency is stuck inside copier
The transparency probably melted to the the fuser roller (Did you use a transparencies sheet that was rated for use in copier?) Some copiers have a set function to allow transparencies sheets to run through. If transparencies is wrapped around the roller it maybe removed, but in most cases it needs to be replaced. If your in Maryland you can contact Innovative Copy Products if not contact your local copier dealer and they can help.
Oct 12, 2008 | Canon PC-940 Black and White Copier
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
Electro Med Services...
