Question about Sharp R-1480 Microwave Oven
The door will not latch
I believe I need a new spring or a new latch head. My problem becomes the disassembly of the door since I see no screws. How do I disassemble the door to install a new latch head.
  • 2 more comments
  • Mike Hannon Nov 01, 2007
    Latch spring attachment point to door frame broke. Instead of replacing outer door frame or trying to glue the attachment point, I fashioned a new attachment with a piece of coat hanger and it works fine.
  • Anonymous Mar 06, 2008
    disassemble door
  • Anonymous Mar 12, 2014
    door latch on nn-sn778s spring needs less tension
  • Anonymous Mar 26, 2014
    The part did not come with new springs...but can't believe the spring is the problem.
  • Sharp Master
  • 9,173 Answers
The latch head (with hooklike projections) have a spring to keep it pulled down. If the latch head can be easily pushed up and falls back freely, then the monting tab on the back of the latch head is broken and it will have to be glued or replaced. The new part is better. To get to the door screws inside, you have to remove the choke cover, as shown in the photo. You can order parts for Sharp models from Tritronics at http://www.wehaveparts.com.
Posted on Sep 23, 2007
Posted on Nov 01, 2007
SOURCE:
Sharp R-308J microwave door will not latch
If you gently push up on the door latch head assembly (hook-like devices sticking out of the door) there should be spring tension. If they just flop right up, the spring is off inside.
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
We have critical safety & disassembly info at our site, linked here.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
The best place to order parts for this brand is Encompass (formerly Tritronics).
Or you can call them toll-free at 866-779-5835.
Jan 11, 2009 | Microwave Ovens
Broken door catch, possible spring, Panasonic Slimline Combi microwave oven NN-A554W.
If you gently push up on the door latches (hook-like devices on the door) there should be spring tension. If they just flop right up, the spring is off.
The best place to order parts is Tritronics. You can also call them at 866-779-5835.
Nov 26, 2008 | Microwave Ovens
Door is not loacking.
The best place to order Sharp parts is Tritronics. You can also call them at 866-779-5835.
Nov 22, 2008 | Panasonic Microwave Ovens
Microwave broken door latch
The door latch head (hook) is pretty easy to replace or repair if that's the issue.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Sep 24, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Have a panasonic slimeline combi microwave and the plastic hook which helps keep the door locked is broken, therefore the microwave will not work
Of course the door latch head (hook-like device) is easy to replace or repair if that's the issue.
You can order Panasonic parts here.
Sep 23, 2008 | Panasonic Microwave Ovens
Dimension 4 microwave nn a725m door will not close
You can order Panasonic parts here. You can find an authorized Panasonic servicer here.
Sep 08, 2008 | Panasonic Microwave Ovens
Door does not latch close on the Panasonic Microwave Oven Model No. NN T444SF
Aug 26, 2008 | Panasonic Microwave Ovens
The safety door latches no longer latch.
You can probably find exploded views and order parts by entering your model number here at the Sears parts site.
Aug 11, 2008 | Sharp Microwave Ovens
Hi, our panasonic genius microwave door won't latch shut, thus preventing us from using it. Is there an easy fix for this?
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 17, 2008 | Microwave Ovens
Door will not stay closed, panel reads "Refer to operating instructions before use"
If you gently push up on the door latches (hook-like devices on the door) there should be spring tension. If they just flop right up, the spring is off inside.
Normally the problem is a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
We have critical safety & disassembly info at our site, linked here: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 05, 2008 | Panasonic Microwave Ovens
Sharp R-1480 Microwave Oven Logo
802 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Ekse
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
