Question about Video Game Consoles & Games
P14 126 on a riso gain adjustment - Video Game Consoles & Games
How to adjust a clutch on a Riso GR 3790?
Chances are good the clutch does need to be replaced. These are magnetic and while they can be cleaned, eventually they will fail and parts are no longer generally available.
As well if you pull the clutch to clean it you have to be VERY careful to mark everything and lock the gears into place. Retiming these old guys if they lose timing is something I'm successful at about 2 out 3 times. Most of them are pretty worn out and nothing wants to quite line back up right once you lose it.
Jun 13, 2014 | Riso RZ390 Duplicator
Riso V800
Riso's are famous for this, i will scrub the rubber timing roll with rubber rejuvenator and clean the steel roll with alcohol.The riso paper feed clutches are weak compared to what they were in this series you may have to replace the clutch. Bud, after doing some research you need to clean the oneway bearings on the pickup and feed rolls, adjust feed table hieght and lastly check/adjust timing in drive and feed roller-you will need a manual for this.
Hope this may help;
Regards,
VOTIT
Jul 25, 2008 | Riso RZ220 Duplicator
Riso printer 390 u a01 -211 error message
I found a small sliver of a cut master inside the master feed assembly. Once it was removed, the machine worked fine. It was hard to locate,but if you remove 2 gold screws from the top of the master feeder you can gain access to the area.the screws are just below the coil springs for the master assy. lid.
May 03, 2012 | Riso Office Equipment & Supplies
I need to know why our riso duplicator is shrinking the copies
In which direction?
Both? Check reproduction percentage?
Lenghth? Either there is a problem with set parameters or a mechanical problem. Hint: Adjustments of mastermaking speed (elongation/shrinkage) can be made in test mode 547.
Dec 03, 2010 | Riso RZ220 Duplicator
I'm getting a great deal of distortion (choppy ink coverage) along the left and right side of the paper, on my Riso RZ220.
The drum needs adjustment, it's not dispensing enough ink. On each end of the drum there is some small plastic covers with one philips screw. These are to control the scrapers to add more ink. Adust them slightly to dispense more ink.. they have plus and minus on them to tell you wich way to go. These things get out of adjustment as they get older. Also ink starts to dry in the screens making them clogged.
Aug 07, 2009 | Riso RZ220 Duplicator
Paper feeding problems Riso TR1510
refix your ink cartrdige also check there is not any paepr jam issue.
also some times printer neeed servicing creates this type of issue.
Mar 28, 2009 | Riso Office Equipment & Supplies
Riso rc6300 registration not correct
ou need to either advance (paper feeds quicker) or elay paper feed there has to be a registration adjustment
It can be as simple as adjustment of the feed wheels or some type of delay in the drum rotation
take alcohol and clean the feed rollers they may be slipping
Dec 27, 2008 | Riso RZ220 Duplicator
Movement
the riso paper feed clutches are weak compared to what they were in the GR series you may have to replace the clutch.
Apr 09, 2008 | Riso RZ220 Duplicator
Riso rz 370
if show P96172 it means that have to adjust the scanner
Mar 10, 2008 | Brother MFC-440CN InkJet Printer
Margin shift
If it is a GR or FR it is out of timing.
Jan 29, 2008 | Riso RZ220 Duplicator
Video Game Consoles & Games Logo
42 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
