Question about Intel DZ77GA-70K Extreme Series LGA 1155 Z77 ATX Motherboard
Intel pc getting C6 error code on startup
Hello, My computer does not start. Getting C6 error on startup. Can not find any sollution.
Hello
Posted on Oct 05, 2013
"Windows failed to start. A
It sounds to me like the harddrive has errors on it. First, I would try completely reinstalling windows with the windows disk. If that does not solve the problem there are several pieces of software that are much stronger harddrive repair solutions than the built in Windows one. Try this one, it is free for 10 days. You will need another computer (friend's computer?) to download and burn this software onto a CD, then put the CD in your computer and boot to it by pressing any key when it asks you to.
http://www.ntfs.com/boot-disk.htm
Sep 03, 2011 | Dell Inspiron 14R Laptop Computer (Intel...
I forget my Nokia C6 phone lock code. please help meeeee :((
Hello and Welcome on FixYa!
The Default phone lock code of Nokia is 12345 or
00000.
If you have changed then to get your Master code. Type *#06# at the mobile screen to know IMEI no of your mobile or you can also see the IMEI no after pulling out the battery, It is mention at back side of the mobile Then Go Here.
Give your IMEI No there and calculate your master code and try it.
It will work as your security code If it doesn't work too then you can get online paid security code for your cell. If you want to then you can Go Here.
After getting your Cell info and charges, they will send you code.
If you don't want to then you can contact to NOKIA SERVICE PROVIDER to get your phone lock code
Anymore help, I am here to help
If it is HELPFUL, Your Rating as FOUR THUMBS (Given below to this solution) and testimonial will be esteemed.
THANKS and Keep Visiting FixYa
Mar 28, 2011 | Nokia C6 Smartphone
My sony vaio computer only run on safe mode but not on normal mode..., no audio..., what do you think is the problem
What happens if ypu try to start in normal mode? You can force a normal boot by presing F8 when the PC is booting to see the advanced startup options. If you are getting a stop error then please get me the error code so that I can help you troubleshoot.
Sai.
Oct 01, 2010 | Sony ® VAIO® V TV-PC Series -...
How to rectify the sound device in windows xp,intel core
What the Name of your Motherboard? We direct where to dowmload your Audio Drivers.
Jul 11, 2010 | Microsoft Windows XP Media Center Edition...
Windows 7 64bit ultimate edition Lots of ''Application Error''
asus M2N68-AM PLUS motherboard is supports all operating system but intel is not support win 7 64bit
May 13, 2010 | ASUS P5QC Motherboard - Intel P45, Socket...
Replace cover on Bosch Dish washer> Now a C6 code is displayed in the window
I had the same problem after replacing the white panel on my Bosch SHE45M02UC with a stainless panel. I got the C6 error code. I called Bosch customer service twice and neither rep was helpful. One guy told me he didn't know what the C6 code meant. He suggested that I call a local appliance repair guy and he would know what the code meant. I replied, you mean to tell me you work for the manufacturer of the dishwasher and don't know what the error code stands for but a local repair guy that doesn't work for Bosch does?
After all this frustration, I took the panels off and tested the dishwasher with no buttons. It worked fine! Turns out, each identical button isn't identical. Each one is labeled A-G. After putting it back together, no more C6 code! On a side note, try reseting the dishwasher. With the dishwasher on and door closed, hold down the cancel/reset buttons for 5 seconds and release. The disher should drain and reset.
Mar 27, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
I keep getting a system dump/blue screen. i tried
You might have bad memory, a corrupted registry file, corrupted system files. Try starting up in Safe mode then backup your data. Goto My Computer and right click on the hard drive and select properties. Goto Tools tab and select error checking of hard disk on startup. Might need to reinstall Windows
Aug 05, 2009 | Averatec D1002UHCE-1 All-In-One Intel...
Keep getting error message upon start-up - C:PROGR~2MYWEBS~1ar.binM3PLUGIN.DLL
Make sure you haven't recently deleted files from this location, if you can, start in safe mode, and manually check the location for viruses / trojans, also, in safe mode got to start>run and type in msconfig
in the new window, go to the " startup " tab, and check all of the startup entries to make sure they are correct, disable any suspected malware, then reboot the PC, repeat this processes untill you find the culprit. Also, be sure to scan your computer thuroughly for any viruses or malware regularly.
Jun 21, 2009 | Intel Motherboard
Error code at startup
Re: windows Vista will not start I had the same problem and came across this solution that worked for me as well: 18 Aug 2009 07:28PM I was getting a the same error codes and couldn't get Windows to boot up at all. I went to BIOS set up (restart your computer and hit F12 when the BIOS screen comes up), went to onboard devices and changed the SATA Operations from ACHSI (don't know how it got there) to the factory default setting ATA. Then I started up in "repair mode" (which was an option that was coming up when I tried to boot up before but never worked) - it went through a repair check and went to login screen.
Prior to finding this - I tried several things including start up from the Reinstallation disc, but nothing worked. I was ready to buy a new hard drive, but don't have to. Works fine!
Not sure what caused the problem to start with. It is an "Inspiron 1520"
Apr 11, 2009 | Computers & Internet
Blue Screen Error Message
Looks like you've been getting two different Stop errors...
The 1st error, 0X00000024, aka Stop 0x24, is a Windows 2000 error. (XP is just an updated version of 2000) Microsoft gives an explanation here.
For the 2nd error, starting with 0x000000ED, Microsoft's solution is here, with additional help here.
Jan 02, 2009 | Dell Dimension 3000 PC Desktop
Intel DZ77GA-70K Extreme Series LGA 1155 Z77 ATX Motherboard Logo
264 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
