Question about Samsung SF-560 Plain Paper Laser Fax
Samsung SF560. Fax is showing error message that cartridge is empty although it is a new cartridge. Cartridge has been changed 3 times always for a brand new one, fax has also been rebooted. Fax will print confirmations but incoming faxes are not printing
  • 5 more comments
  • Anonymous Jan 02, 2008
    I have the same problem, fuse is fine. toner works OK in another fax.
  • sligo1 Feb 08, 2008
    have change toner in fax but getting message (jam 1) or toner empty
  • Anonymous Mar 06, 2008
    yes again i have tried replacing the toner with no joy,
    i tried both cartridges on another model in the building and they both work fine .....
    STUCK!!
    help please
  • MACRE Mar 26, 2008
    Message reads "toner empty". Replaced with 3 new toner cartidges and still get same message. Fax machine will let make copies with no problem, but is showing memory stored faxes that fax machine will not print out
  • lebonchef Apr 15, 2008
  • Anonymous May 23, 2008
    Fax has (Toner empty) elert and I have replaced three ML-1710D3 cartridges. I have tried to reboot and reset toner elert but it will still not receive or send faxes.
  • Anonymous Mar 18, 2014
    cartridge override MY CUSTOMER BOUGHT A NEW SECOND HAND PRINTER FROM A RETAIL STORE WITH NO SETUP CARTRIDGES, I HAVE PUT IN NEW ORIGINAL CARTRIDGES, ERROR MESSAGE APEARS INCERT SETUP CARTRIDGES FIRST CAN I OVER RIDE THIS
I can confirm that the information posted by guest on Apr 30 2008 is correct. It is vital that you have the correct model of cartridge installed. The SF-560 uses SCX-4216D3 and the SF-560R uses
SF-D560RA. The cartridges look very similar, but the cartridge detection contacts are different on both cartridges. The cartridges will fit in either of the machines, and this is where the problem is.
Posted on Jan 10, 2010
Make sure you have the correct cartridge as the SF560 & SF560R use different cartridges
Posted on Apr 30, 2008
  • 82 Answers
Check if there is a fuse in place (usually fitted to the front edge of the cartridge) and always replace when refilling.
Posted on Sep 08, 2007
REPLACED THE TONER CARTRIDGE WITH A REFILLED ON AND GET THE ERROR MESSAGE "SYSTEM ERROR F2-70"
Most Copier Cartridge have chips on them that tell the copier I am new, Replacing the toner/refill, does not change the chip info as long as the chip says I am empty its empty to the copier, replace the cartridge with a new OEM cartridge.
Mar 17, 2015 | Sharp FO-2081 Copier
Get rid of the error message "toner empty stop" after replacing the cartridge with a new Samsung cartridge?
After replacement with OEM cartridge it will never show Toner empty
however refil cartrdige will show the same , You need to replace the chip to remove the empty indication
Oct 01, 2014 | Samsung Office Equipment & Supplies
Fax machine Samsung Inkjet Fax SF-360. Ink was finished so ordered the correct ink cartridge and replaced it now on the screen it tells us to install ink cartridge. I have tried severeal times and i know...
If the Toner Low/Empty message does not automatically clear when a new cartridge is installed, use the following to clear the message manually:
1.Press MENU # 1 9 3 4. The machine should display TECH.
2.Press MENU, and ENTER. The machine should display TECH Mode.
3.Press the left arrow < once. The machine will show NEW CARTRIDGE.
4.Press ENTER, the machine will show YES.
5.Press ENTER, there should not be any Toner Low/Empty message.
6.Exit TECH MODE, press MENU # 1 9 3 4. The machine will no longer display TECH.
If Toner Low/Empty message continues, there may be a problem with the toner cartridge or the machine.
Jul 21, 2010 | Samsung SF-5100 Plain Paper Laser Fax
How do I change the toner?
The Fax-2480c does not use toner cartridges.
This is an inkjet and so uses ink cartridges.
There are 4 cartridges, black, yellow, cyan (blue) and magenta (red). If any of these cartridges are empty, you need replace them.
This machine takes LC-51 cartridges.
You're probably out of warranty so jsut get refills... it's cheaper
Mar 25, 2010 | Brother IntelliFax-2480C Fax
Can't receive fax but can send fax
I have a feeling that it is a re-manufactured or compatible cartridge??
There is a fuse that needs to be replaced on this unit. it blows when the cartridge is installed to reset the machine. If the fuse has not been replaced or is defective the machine will not recognize the new unit.
Feb 12, 2009 | Samsung SF-5100 Plain Paper Laser Fax
Samsung SF560 Laser Fax
in the box with the new toner cartridge was there a credit type card to use when changing the toner to reset the toner counter?
read the instructions in the box :p
May 23, 2008 | Samsung SF-560 Plain Paper Laser Fax
Samsung SF560 error message door open & jam, no toner.
I have put a new toner in and it says "[jam 1] or no cartridge" please help this is an office fax and desperately needs to be working.
Many thanks,
Adrian.
Apr 15, 2008 | Samsung SF-560 Plain Paper Laser Fax
Samsung SF560 Message reads "toner empty". Replaced new toner cartidges and still get same message. have change toner in fax but getting message (jam 1) or toner empty it seems pretty common problem as...
Turn off the Machine for safety.
- Try to double check if the toner cartridge is properly installed
- Clean it also if dusty
- Make sure he sensor have no paper or dust.
"toner empty" problem
The samsung sf 5100 toner cartridge has a .05 Amps fuse in it. This gets blowed when you switch on the machine.This is used to reset the page counter and also to inform the machine that you have inserted a new toner. Now this recycled cartriges will not have this fuse and this is the reason why your machine shows TONER EMTY message! If you dont get the same rating fuse, put any fuse of the same size, insert the toner, close the door and just switch on the power and switch off immediately. Then take out the Toner cartridge and remove the fuse. Now your cartridge is ready for use.
Dec 06, 2007 | Samsung SF-5100 Plain Paper Laser Fax
Samsung SF-560 Plain Paper Laser Fax Logo
585 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
