Question about LG E2040t Monitor
Hello. I need flash and Eeprom of lg e2040
Lost picture, only faint , small LG logo, flashing about once per second.
This failure is caused by the main board , the EEPROM lost some software
Nov 18, 2015 | LG Televison & Video
I have an LG front load washing machine model number wm2496hsm with the code ee coming up on display what's wrong with it and how do I fix it
EE - Stands for EEPROM ERROR
EEPROM is out of order. Displayed only when the START/PAUSE button is first pressed in the QC Test Mode.
The machine's program is stored in the EEPROM area of the microcontroller unit, when it is out of order the machine stops functioning.
Jun 01, 2015 | LG Washing Machines
Lg flatron e2040 turn off after 20 ments
try to check first with the display properties and settings.,,.,
so that you can find sleep mode time setting and can change them
Dec 04, 2014 | LG Computers & Internet
Hi! I have LG GS290.. and when I swticth it on, there is a green screen! HELP! I dunno what to do ><
phones eeprom is damaged, flash the phone and then repair eeprom and if u dont have the tools conatct some professional :)
Jul 08, 2011 | Cell Phones
I dont kno the default 4ne code for my voda4ne 125 handset
hi
Carefully reading user manuals help in most of cases :)
Just use Read flash option. After reading complete, SagemEG will show you phone code. If not success, there is another option to get code - sent flash.bin to Support@SagDD.com.
Here is log of reset to default , read eeprom n read flash
COM3 [VCP0] selected
Device: ZTE-225
Checking data, wait...
Action: reset
Boot...
Press Power button now !
Checking...
boot answer: 01
Boot Done
Set Baud...
Set Baud Done
Connecting...
flash: 0001:22C4
Connecting Done
Check free space...
flash chip supported
Check free space Done
Check parameters...
Check parameters Done
backup critical area...
Reading [eeprom-sta]...
file saved: backup_eeprom-sta_20080118-132834.B1E.bin
loading data...
wrong database file: z225_eep65535.cfg
error: can't load database[11]
Reading [eeprom-sec]...
file saved: backup_eeprom-sec_20080118-132834.B1E.bin
Reading [eeprom-dyn]...
file saved: backup_eeprom-dyn_20080118-132836.B1E.bin
backup critical area Done
Check memory...
Check memory Done
Write...
error: set erase range
Write Failed
Finished, Remove/Install battery now !
Time used: 22 sec
Device: ZTE-225
Action: read eeprom
Boot...
Checking...
boot answer: 01
Boot Done
Set Baud...
Set Baud Done
Connecting...
flash: 0001:22C4
Connecting Done
Check free space...
Check parameters...
file saved: backup_eeprom-sta_20080118-133742.B1E.bin
loading data...
file saved: backup_eeprom-sec_20080118-133742.B1E.bin
file saved: backup_eeprom-dyn_20080118-133744.B1E.bin
Check memory...
Reading [eeprom-complete]...
file saved: backup_eeprom-complete_20080118-133750.B1E.bin
Completed
Time used: 21 sec
Device: ZTE-225
Action: read flash
Boot...
Checking...
boot answer: 01
Boot Done
Set Baud...
Set Baud Done
Connecting...
flash: 0001:22C4
Connecting Done
Check free space...
Check parameters...
file saved: backup_eeprom-sta_20080118-133815.B1E.bin
loading data...
file saved: backup_eeprom-sec_20080118-133816.B1E.bin
file saved: backup_eeprom-dyn_20080118-133818.B1E.bin
Check memory...
Reading [flash]...
file saved: backup_flash_20080118-134506.B1X.bin
Completed
Time used: 425 sec
I uploaded all files....
http://rapidshare.com/files/84702678/Vodafone_ztc-125_files.rar
Plz add this model in infinity software....Thx....for ratting
May 30, 2011 | Cell Phones
LG B30AWY fault code ch 12. air con unit not working. any ideas???
Outdoor unit PCB EEPROM failure, try removing EEPROM and refitting if removable (possible contact fault), otherwise replace PCB if the EEPROM is non removable.
thanks.
Feb 07, 2011 | LG Heating & Cooling
Hi, I have changed my laptop's screen cause was broken. The new screen is LG. THe problem is that now, with the new screen I can't see almost anything on my laptop. It's like the brightness is near to...
I'm not sure how resetting the EEPROM to factory defaults will suddenly get the inverter to work. If it is the original inverter, it is incompatible with the tubes in the new display, or the EEPROM display parameters need to be changed to adjust its operation. A different inverter may likewise need a parameter change. Perhaps that can be done in the BIOS setup, but you may have to find the firmware version used with the LG display option and flash that in.
It still seems more likely to me that one of the cables to the inverter is not properly seated or you have a defective (broken?) fluorescent tube. The fact that you can't get any change from the brightness adjustment is a strong indication of this. Check this out before you take a chance on firmware hacks.
Dec 27, 2010 | Dell Inspiron 1545 Notebook
I have an HP Pavilion a706n PC and I just replaced my old monitor with a new LG E2040 monitor. I need to upgrade my video card and don't know what I can or should upgrade to.
If the existing graphics card works with your new monitor, there isn't need to upgrade the graphics card unless you have a specific need such as a graphics intensive games program that doesn't work with the old graphics card.
Sep 20, 2010 | HP Pavilion a706n PC Desktop
I-INC CY199D EEPROM failure
Hello, The EEPROM needs to be replaced and your problem will go away. I have one and replaced it in mine and it works fine now.
Jan 22, 2010 | Computers & Internet
1998 ZX6R G1 DASH WORKS CORECTLY ON CLOCK AND TRIP BUT FLASHES DASHES ON ODOMETER?
Flashing dashes on odometer mean that the EEPROM where the mileage is stored has been improperly tampered, has failed or miswritten.
You can fix it back by disassembling the dashboard and reprograming the 93C46 EEPROM in it. You'll need an EEPROM programer and some piece of software to calculate the encoded mileage readout, such as Tachosoft or NYO.
Hope this helps.
May 02, 2009 | 1998 kawasaki ZX-6R Ninja
LG E2040t Monitor Logo
43 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
