Question about Home
How to fit a CEDO soft close cumin toilet seat EAN 4016959098582
3 Suggested Answers
SOURCE: can you help re fitting cedo rue toilet seat
Had same problem, this website has the instructions:
http://www.haro-sanitary.com/technical_intelligence_ENG_HTML.htm
Posted on Jan 15, 2010
SOURCE: cedo Rue Toilet Seat Soft Close White
Just bought a Cedo Rue soft close toilet seat. Can't make any sense out of the useless instructions and what to do with all the bits. It also included an alum key which I can't see a use for. Can you please help
Posted on May 03, 2010
How do I remove toilet seat?Appears to be 2 bolts with top access only.
rak soft close toilet seat - YouTube
? 0:31
https://www.youtube.com/watch?v=RLssM9BYJjg
Oct 9, 2013 - Uploaded by Paul Hooker
rak soft close toilet seat. ... How to remove and change a Villeroy & Boch toilet seat with top fixings ...
Rak Series 600 Back To Wall Toilet - YouTube
Nov 29, 2015 | Home
Hi, I am replacing a rounded BTW toilet seat and the measurements are: between holes=150mm, width=370mm, length=430mm. I bought a Ceso Rue Softclose from B&Q as per this description http://w
I believe the European standard for distance between fixing holes is 155mm +/- 10 mm. I am not familiar with the actual products you are using, but often these holes are slightly oversize. Your seat may fit depending on this, as well as on the actual diameter of the fixing bolts. You have two options - try it or not. If you don't try it I assume you'll return it. If you do try it and it doesn't fit, you'll return it. You might as well try it, because if it fits, you're done! Good luck.
Dec 01, 2014 | Home
How do i fix a soft closing toilet seat
some of these have bolts under seat...you turn seat to left or right by grabbing while in closed position...this will release the seat from the holding bolts...then tighten the bolts....then reset the seat on bolts then lock down by doing the opposite as you took off...
Oct 10, 2014 | Home
Soft close toilet seat
Mine is a Bemis and does the same thing. Seat drops and lids does a slow close! Are you going to takes yours back for a new one?
Jan 18, 2014 | Home
The toilet see is not tight. How can I tighten the seat? I have an elongated seat with the soft closing lid.
Right behind the bowl on the underside there is a nut on either side that holds the seat on...tighten those nuts and it will tighten down the seat...
heatman101
Aug 29, 2010 | Toto Aquia II Dual Flush Toilet
Just bought a cedo rue soft close. any idea of order of washers going on etc as instructions unreadable
Metal peg fixing goes "into" large plastic "cup" washer. Metal fixing now goes through holes in toilet pan sitting in the "cup" washer. From the bottom push up the thin round plastic washer, convex side towards the hole. Next the oval shaped thick washer flat side towards the hole. This has a cup shape into which the final plastic screw fitting pushes into (like a coax plug on the TV aerial). This will push up the thread into the cup where the sides force the thread to grip. Finger tighten so that you can still move the metal fixings from the top. Line up the toilet seat holes and push fit onto the pegs. It may take a smart thump to get them fully seated. Before tightening with the supplied black plastic spanner" make sure the large "cup" washer on top has not got trapped under the metal fixing. If all is ok line up the seat and tighten.
Dec 24, 2009 | Home
Can you help re fitting cedo rue toilet seat
Dec 08, 2009 | Home
Cedo Rue Toilet Seat Soft Close White EAN: 4016959076115 Just bought this - fixing instruction diagrams are unreadable. Can anyone help? Does anyone know if the manufacturer has a web site?
Nov 29, 2009 | Duravit Home
One of the softclose buffers on the Subway toilet seat has pulled
Each soft close 'Barrel' is handed - one left - one right. (One is grey - the other white).
Most soft close errors occur because the seat hinges come loose. When this happen, the barrels slightly pull-out of the seat. (There are silver discs on the barrels - These should be tight against the seat).
Once the barrels become loose the first thing that happens is the top cover won't soft close - but the seat still does.
To rectify - puch both barrels tighly into fitting and tighten the hinges. (See below).
To tighen the seat hinges you need to get a flat headed screwdriver underneath the chrome round hinge cover - and 'flick off'. Underneath is a X head screw which id also hexagonal. You can either tighen both by spanner - or screw driver. (sometimes these can be tricky - but it will come off).
If both cover AND seat do not soft close AND the barrel silver discs are firmly located against the seat - the barrel has probably broken.
If so - spare parts can be obtained here:
http://bathroomstudio.co.uk/villeroy-boch-spares/cat_131.html
Jun 15, 2009 | Villeroy & Boch 9955 S1 Subway Toilet Seat...
Home Logo
1,020 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
