Question about Ovens
Chef ebc5231w.32 The door could not close tight.
2 Suggested Answers
  • 142 Answers
SOURCE: CHEF EBC5231W*53 OVEN.overcooks food underneath
Did you per chance put the food on a plate that pretty much is as big as the oven? If you did, you trapped all the heat from the baking element under the food. Please check that first.
Posted on Aug 10, 2011
What are the dimensions of a chef baroness integra gas wall oven
You need the Chef Model number, then click on the model and then on 'More'.
chef integra baroness wall oven 92 60 chef Compare Cheap chef integra...
Chef EXC627W Wall Oven
Compare prices $849.00 Chef EXC627W 60cm electric fan forced wall oven with separate grill and 60 minute timer in white Separate grill 60 minute timer Easy clean formed shelf supports Cooler door temperatures with air cooled door Wall installation Cooling fan Oven size (cm): 60 Oven - internal dimensions (h x w x d) (mm): 376 x 475 x 432 Separate grill - internal dimensions (h x w x d) (mm): 216 x 475 x 432
Specifications Style of Oven
Separate grill/wall
Oven Type Electric
Width 888 mm
Depth 595 mm
Height 573 mm
Or contact them direct
Welcome to Chef
https://www.chefappliances.com.au/Explore Chef's range of products! ... The simple touches that make Chef functional and easy. Fingerprint. Anti-fingerprint. A special stainless steel finish means our ovens stay free of messy prints. Cooktop options. Gas, electric solid or ceramic. image 1. Boils faster than gas? Easy. The Induction cooktop provides modern, ...
Apr 08, 2018 | Ovens
The oven door doesn't close tight
Hello, Anna -
The problem of your oven door not closing tightly could be caused by one of several problems:
* A problem with the door hinges
* Broken oven door springs
* A problem with the gasket inside the edge of the oven door
This article from the San Francisco Examiner newspaper describes the problems and how to fix them:
http://homeguides.sfgate.com/fix-oven-door-not-close-properly-28760.html
Best wishes.
Feb 07, 2018 | Ovens
I have a Chef oven EOC624S*04. Whats involved in changing the hinges on the doors as the door wont close properly. Also where can I buy these hinges from
they probably only need to be cleaned,or the door cleaned,open the door 10 inches and lift the door off and you can inspect them.
Apr 01, 2015 | Ovens
Door will not close completly
When you say "oven door will not close properly", do you mean that it closes but not tightly against the rubber seal on the oven cavity?
Or is it some other closing problem?
If it is the former, then it is a sign of the door hinge springs wearing out. The solution to this is to replace both hinges on the offending door.
Sep 08, 2011 | Ovens
CHEF EBC5231W*53 OVEN.overcooks food underneath but undercooks on top side.any tips would be grateful
Aug 10, 2011 | Ovens
Unlock oven door
The oven model 9815 shows you have a mecahnical latch. this latch has a switch that tells the control board what position it is in (open or closed). This switch should be tested.
Jan 07, 2010 | Magic Chef 9815 Electric Single Oven
Ovens Logo
37 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
