My whirlpool sports serial No.wfs1274cd has the code f08 on display please help
ngfam1
  • 639 Answers
SOURCE: Error code F08
DEAR FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
It means you should try to unplug the machine for three minutes and then plug it back in and restart it! If this fails you will need to call service for error codes!!
Sounds like you need both knob and screw!
Here is a good service that I recommend to my customers,
in our 65 year old appliance business! they answer 24/7
Not expensive!
A&E Factory Service
1-800-905-9505 -(IN U.S.A.)
They are open to make appointments 7days/24hours
A&E is factory authorized service for most brands!
Including warranty work!!!
They will help you, and all will be well!
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
Posted on Aug 26, 2008
aborcass
  • 2651 Answers
SOURCE: whirlpool duet sport. I am getting a f33 error code.
i would look for a small blak rubber tube running frim the pressureswitch tothe back ofthe tub, its possible that the tubing if either clogged or ripped, and is not able to detect current water level inthe machin causingthe F33. 3 screws from across theback will release the main top, from thereyou an locate the hose back right corner i believe
Posted on Mar 12, 2009
  • 240 Answers
SOURCE: Whirlpool Duet Sport ~ E28 Error Code
serial communication error between central control and motor control.
Check connections at ccu (top front right corner) and mcu (bottom by motor), check belt drive for wear.
Did motor run ? Any other codes in diagnostic? (any one modifier button 4 sec on 4 secs off 5 times.) F codes are failures and C codes are portions of test cycle(automaticly run)
Posted on May 02, 2009
blueextc3221
  • 15935 Answers
SOURCE: Whirlppol Duet Sport Error Code
"F21" (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump...
If you experience a problem where the washer does not drain properly or the drain pump makes excessive noise, here's the information you need to check the drain pump:
Symptom: PUMP IS RUNNING, BUT NOT DRAINING PROPERLY.
1. Unplug the washer while servicing inside the unit.
2. Remove the lower kick panel under the door by removing the three 7mm screws under the bottom edge of the panel. HINT: Use a couple of blocks of wood to prop up the front feet of the washer to gain better access to the screws. Once the screws are removed the panel should drop down, and then pull off. If the panel becomes stuck, a slight tap on either side will dislodge it.
3. Locate the drain pump. It will be located directly under the wash tub (it is the only pump this washer has).
4. There is an access removal cover on the pump that can be removed to clean out the trap. BEFORE doing this, it is strongly recommended that you remove all residual water from the wash tub & drain line or you will have about a gallon or so inside your washer and on the floor to clean up.
5. Here's a helpful way of quickly removing the residual water. If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall and pull a vacuum with the shop vac. This will empty the wash tub, pump and drain lines. If you don't own a shop vac, grab a bunch of old towels and open the access on the pump slowly so that it comes out at a trickle. Allow the towels to soak up the majority of the water. Close the access and stop the water if you need to get additional towels.
6. Open the pump access and remove once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there's nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
7. Clean out the pump thoroughly and reinstall the access cover. Make sure the cover is snug, but do not over tighten.
8. Place the drain hose back in the standpipe (IMPORTANT - DO NOT FORGET!).
9. With the bottom panel still off, plug the washer back in and select the following on the operator console - DRAIN SPIN, NO SPIN, and then press any button under OPTIONS 4 times (it must be the same button). "C00" will show on the console display as the washer begins diagnostics mode.
10. Check the drain pump for leaks as the washer fills. The pump is gravity filled and will hold water even it is not pumping. Allow washer to run through diagnostics until it begins the wash tub tumble cycle.
11. At this point, you can stop the diagnostics procedure by pressing PAUSE/CANCEL 2 times. The drain pump energizes and the washer will begin to drain.
12. If the drain pump works normal and there are no leaks detected, reinstall the bottom panel and tighten screws.
NOTE: It is normal to have residual water left inside the wash tub under the wash basket. This is why it is important to leave the door ajar when not in use so this water does not become sour.
http://media.fotki.com/1_p,wktwwdgrkbbfrdgxgtqsskgwtqkq,vi/kstdgfskbxktqtggsqb/1/1303472/5961857/image64920img-or.gif
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 21, 2010
HansPP
  • 2510 Answers
SOURCE: Whirlpool washing machine showing a code of F08
That is an overflow condition.
Check the drain hose and make sure it is not plugged or kinked
Check the wire harness to the drain pump, pressure switch and Central Control Unit
Check and clean the drain pump filter of foreign objects
Check for drain pump failure
Check that the inlet valve shuts off fully
Check that the pressure switch is operational.
Posted on Apr 06, 2011
What is the rated capacity for a Whirlpool Duet Sport Washing Model WFW8300SW02 Type 831
Capacity = 3.3 Cu Ft
Whirlpoolcorp.com download manual:
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=WFW8300SW0&siteCd=WHRCOM&userType=Consumer#
The breakdown for Whirlpool Serial Numbers is:
1st Alpha Character = Manufacturing Division Code.
2nd Alpha Character = Year Manufactured (See Tables).
1st and 2nd Digit = Week of Year Manufactured.
3rd though 7th Digit = Order of Manufacturing that Week.
http://www.electrical-forensics.com/MajorAppliances/WhirlpoolDateCodes.html
If this was helpful, please rate post
Sep 13, 2014 | Whirlpool duet Washing Machines
Washing machine why does my whirlpool WFS1274cd have no power?
have you checked the fuse and the wire for any damage first
Jul 30, 2014 | Whirlpool Washing Machines
Whirlpool f08
whirlpool f08
f08 e03 error codeF8E2 is DISPENSER SYSTEM ERROR - Dispenser motor is unable to reach the desired position. Possible causes: Check the mechanical linkage from the dispensor motor to top of dispenser. See TEST #12 (Dispensor Distribution System) on page 21. Someone else can post to contents of Page 21. Good luck.
Read more: http://forum.appliancepartspros.com/washer-repair/529426-f08-e02-error-codes.html#ixzz34yTou7Nz
Yes, it is a dispenser system error. The technician manual says to check the mechanical linkage from dispenser motor to top of dispenser.
However, in my case this page from whirlpool was helpful:
https://www.whirlpool.com/product-he...r-code/PH5260/
It says a common solution for this error (f8 e2) is:
The detergent drawer or detergent cartridge might be clogged with detergent. Clean out the detergent cartridge per Use and Care Instructions.
If cleaning the detergent cartridge did not correct the problem, please contact us.
For any additional questions, please call our Customer eXperience Center toll-free at 1-866-698-2538, Monday through Friday 8AM-8PM Eastern Standard Time.
You will be asked to provide the model and serial number which is found on the front door rim after opening the door.
So I washed out my dispenser and now it's working again.
Read more: http://forum.appliancepartspros.com/washer-repair/529426-f08-e02-error-codes.html#ixzz34yTzjNdt
May 15, 2014 | Whirlpool WFW94HEAW Duet Front Load Washer
7.5 Kg Front Load Sports Washer WFS1274CD Door is locked, how do I unlock it.
Remove the top cover, located the door latch. On the bottom of the latch is a release for the door. Simply pull this down and the door will open.
http://www.on-timeappliance.com/washingmachinerepair.html
Mar 28, 2012 | Whirlpool Washing Machines
My whirlpool wfs1273bd the door open light is red and the display is showing F08 when i press start
here is what my service manual says for that fault code
F8 Board failure Replace control board (also called ERC or clock).
Hope this helps,if it does please give me a 4 thumbs up rating
Gene
Jul 31, 2011 | Kitchen Ranges
Reset error code F08 in a whirlpool washing machine, or whats the problem.
Error code F08 is indicating that the heater relay is not being activated.
You need to check all the connections on the module, the pressure switch, and the heater element.
May 28, 2011 | Washing Machines
Front loader WFS1273BW not woking fault code F08 comming up on display
Although I do not have all of the Whirlpool models' fault codes, on many it is 'Heating Element, Open Circuit' so I suppose it would be reasonable to assume the same for yours.
I would suggest a service engineer call is required. Sorry ;-0(
Good luck,
John C
Mar 07, 2011 | Whirlpool Washing Machines
Apr 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
