Question about SATO Office Equipment & Supplies
Windows 7 fails to install USB driver when I connect my SATO CT400 to a usb port. I have tried different usb ports and on 2 different computers.
  • 3 Answers
Check usb driver first
Posted on Jul 31, 2013
iqbal_del
  • 655 Answers
SOURCE: USB port problems with hp printer
There are few things to remember using USB.
  • If your System is in hybernation mode, don't remove any attached USB device, because it will damage your USB driver. This is one of the known problem from microsoft.
  • If you have to remove any USB device use 'Safely Remove Hardware'.
To remove currepted USB drivers its not enough to remove your printer drivers.
  1. You should un-install the 'Universal Serial Bus Controllers' from Device Manager.
  2. Then re-boot to clean registry.
  3. Install the 'Universal Serial Bus Controllers' using XP Setup CD.
  4. Then check the Mass storage, PDA etc, it should recognized by XP.
  5. Then install printer driver (don't attach printer to system untill setup finish or setup says to connect).
I think it will fix.
Please let me know your feed-back.
Thanks
Iqbal
Posted on Apr 15, 2008
SOURCE: Lexmark X8350 "communication not available"
I fixed this by completely uninstalling the Lexmark software, then unplugging the USB and restarting. I then installed the new Lexmark software that I downloaded from their site, make sure not to plug the USB back in until it told me to. It then detected the printer properly and started working.
Posted on Jun 03, 2009
SOURCE: Cannot install Canon PIXMA MP190 printer
Thank you for your promptitude.
Today I solved my problem. Was a cable connection problem. Cable incompatibilit or all 3 cables used before are damaged. Tuday I buy an other new cable and SUCCESS!!!: my computer see de printer ("new hardware found" when attach usb cable) , create virtual usb port, install the drivers (I have the drivers downloaded from the Canon web site) and printer is working fine.
Anyway, thank yow again for your support!
Posted on Jul 10, 2009
komguy
  • 2306 Answers
SOURCE: HP Laser 4L driver for USB port
Not all USB adapters are the same, you need the one that is made for your printer, I would try a different adapter before going too deep, because when you plug it in your computer should see it even without drivers.
Posted on Jul 21, 2009
leethedeuce
  • 4472 Answers
SOURCE: Dell Photo Scanner / Printer
Unfortunately on their website it isn't listed as supported by windows 7. Also when a new operating system comes out there is always a lot of issues in the beginning. I have seen quite a few windows 7 problems of this nature. My first question would be did you run the setup in compatibility mode for windows vista? This would be the first thing to try.
Thank you,
Lee
Posted on Jan 30, 2010
HOW TO CONNECT HPDESKJET D2545 PTINTER
The D2545 is a basic USB printer. The USB 2.0 (A-B M/M) cable is not included. The installation steps are 1) plug in the power cord and turn on the printer, 2) make sure that it has paper and ink, 3) connect the USB cable to the back of the printer (the square end) and to the computer (rectangular end) with the computer on. The Windows or Apple OS will then install the basic driver software. If this step does not occur, check if your cable is fully seated. Next try a different USB cable and a different USB port. If you are using a USB hub, try a direct connection to the computer's USB port. If the driver software still doesn't work, check that the correct USB driver is installed and working. In Windows, go to the Device Manager. (Press the Windows Key + X in most versions of the OS or go through the Control Panel under Hardware. That involves left clicking the Start button for Windows 7 and lower. For Windows 8.1 and 10, right click on the Start button.) If you see a triangle with an X or an exclamation point, you have a driver problem. Check the computer manufacturer's site for updated drivers.
Go to http://support.hp.com/us-en/product/HP-Deskjet-D2500-Printer-series/3374272/model/3571289/drivers if you want the full featured software and drivers.
I hope this helps.
Aug 23, 2015 | Office Equipment & Supplies
How do i get my computer to see my 1350 garmin nuvi?
The problem could be the computer's USB port or the cable. Make sure that you aren't connecting to a USB hub or a dock. Try a different USB A to mini-USB cable (match the number of pins and shape of the mini USB connector). Try installing the Garmin Agent software manually from http://www.garmin.com/agent .
Make sure that the Nuvi 1350 is fully charged. Disconnect the USB cable from the computer and turn off the Nuvi. Then turn it back on. Reconnect the cable to the computer at a different USB port. (If you are using a front port, try one of the back ports. Do not just switch to a top or bottom port since every pair of ports share a controller.) If you are using Windows, check if the Nuvi is listed as a mass storage device (press the Windows key + E or double-left click on the My Computer (Computer) icon). Recent security changes prevent USB devices from triggering the Auto-play feature on Windows. (You can change this from the Control Panel in the Hardware section for AutoPlay.)
Next try using a different computer if you can. If the Garmin Nuvi correctly communicates with the second machine, you may want to check the USB controller. Go to the Device Manager (from the Control Panel under Hardware) and expand the Universal Serial Bus controllers. You can remove the driver or check for updates. (Check for updates manually from the computer manufacturer as well.) Reboot the computer and check if the ports work. Check if other USB devices work on those ports. USB ports can fail. Sometimes, you might notice a device getting hot while connected to a failing port. Other times, the port just isn't getting enough power. Check if the power supply is sufficient for the number of devices both inside (hard drives, video card, etc.) and externally connected to the computer.
I hope this helps.
Oct 17, 2014 | Garmin nuvi 1350 Car GPS Receiver
The port to which the printer is connected is not supported. Check the port
I'm assuming you are using a USB connection, not a Ethernet connection.
Try a different USB port (preferably in the REAR of the computer, not the front). It's not unusual to have 1 or 2 poorly-performing (low power) ports on a PC; some printers don't like those.
If you have a really old computer, it may have ancient USB type "1" (slow) ports instead of the newer 2.0 or 3.0 USB type. Some printers don't like old USB 1 ports, but it is not supposed to matter.
If all else fails, try another USB cord, or a shorter one. Some printers don't work well with cords longer than 4 feet, and USB cords can go bad.
Or, try the printer on another computer. If the same USB cord works fine there, YOUR computer has the problem (probably a USB port or USB driver issue).
Are you having issues with other USB devices? If so, it may be a Windows driver issue.
Good luck. If no help, post your exact printer model # here, or try contacting Lexmark.com support
Dec 02, 2013 | Lexmark All-in-One Printer with PictBridge
How to check fo faulty USB port
W 7
First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
for XP or earlier
Click start right click on computer select properties device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
Check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts Check if USB Ports Are Damaged
USB ports are an important part of your computer's hardware.
Many devices connect to the computer via USB, such as music players, cell phones and digital cameras.
This connection lets you charge your devices and manage files on them.
When you connect a device to a USB port, it is typically recognized automatically.
If not, there may be a problem with the port. USB ports sometimes fail on their own, or they may be damaged by force.
Plug a variety of devices into the USB port you think is damaged.
If none of them work, the port is probably broken.
Connect the same devices to the USB ports on a different computer.
If they work, this is another indication your ports may be damaged.
Run Windows Update on your computer to ensure your devices and computer function together and have the latest drivers.
Click "Start," then type "Update" in the search bar.
Click on "Windows Update," "Check for Updates" and "Install Updates."
Open the Windows Device Manager by clicking "Start," then typing "device manager" into the search bar.
Click the Device Manager link when it appears.
Click on each of your USB ports.
In the Properties window, look for "This device is working properly."
If this is displayed for each USB port, they are not damaged, but there may be a problem with your device instead.
Click "Update Driver" next to each USB port in the Device Manager, and Windows searches for and installs the latest driver.
If one can't be found, go to your computer manufacturer's website, and download the driver there. Try to use the USB port again.
Sometimes, outdated or damaged drivers result in a non-working USB port.
Open your computer case by unscrewing or sliding off the side cover.
Use a can of compressed air to clean out the dust from inside, especially from within the USB ports.
If your USB ports are hooked up to the motherboard, remove the cable, then replace it.
These actions sometimes help to fix non-working ports.
http://askbobrankin.com/usb_ports_not_working.html
Sep 05, 2013 | Dell OptiPlex 780 Desktop Computer 1 x...
My iomega media xporter hard drive not being detected by my PC having windows 7?
Try your Iomega drive on another computer to make sure it works. if it works on another computer, then come back to your computer with windows 7 and try different usb ports. Maybe one of your usb ports is bad. If your usb ports are ok, then your drive is not compatible with windows 7.
Go to iomega's website and see if they have an update, patch or driver for Windows 7.
Get online and got to www.google.com In the google search box type: "Iomega Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operating system when requested. Download and install the Windows 7 drivers.
May 30, 2012 | Iomega Media Xporter 160 GB USB Hard Drive
I have an old serial printer that works fine, I can not connect it to my new computer via a parallel to usb cable convertor on windows 7!
Hi craig931, First try downloading the latest driver of your printer and your usb converter compatible for windows 7. Second Checked your device manager if your printer and usb to parallel driver properly installed, it should be there. If not yet installed try using different usb port one at a time until the cable have been detected. Third if you see already the printer port force to change it to USB001 or Com1, then try to print. regards,
Sep 26, 2011 | Office Equipment & Supplies
I cannot get my keyboard or my mouse to work with my dell computer. what can i do?
Please add more information to get specific assistance. Are these wireless devices? If wired, do they use USB or PS/2 connections.
For wireless devices, try replacing the batteries and resynching to the receiver. (You may want to check putting the receiver in different USB ports.)
For wired devices, disconnect and reconnect. For PS/2 devices, you will need to restart the computer to check if the devices work. For USB devices, try connecting to different USB ports.
Next step, try using a different keyboard and mouse (that work on another computer (stick to USB or PS/2 to match the current pair)). Try a wired set if the problem is with a wireless pair. If those work, continue diagnostics on the wireless keyboard and mouse. Check if the mouse and keyboard work on another computer. If they don't work with another computer, replace them.
If another USB keyboard and mouse pair don't work in any port, your USB ports may have failed. Check if even one port works enough to access the Device Manager. (Start > Control Panel > Hardware and Sound > Device Manager (Win7); similar directions in other versions of Windows) Check for a problem with the drivers (For USB ports, scroll down to the USB drivers and look for a triangle with a yellow exclamation point or red x). Try to update the driver or roll it back. If that doesn't help and one USB port works, a USB hub may solve the problem.
Otherwise if the USB or PS/2 ports do not work with any devices and the driver fix doesn't work, then I'd suspect a problem with the ports on the motherboard. Replace the motherboard/computer.
I hope this helps.
Sep 12, 2011 | Dell Computers & Internet
Can't connect printer.
Hi, It seems that the you might have upgraded your computer to Windows 7 and you are not able to get your printer work. In this case you need to download printer's driver for the operating system that you are using that is Windows 7 64-bit. Download the driver from: http://www.epson.co.uk/Printers-and-All-In-Ones/Inkjet/Epson-Stylus-DX5000-all-in-one-printer/Drivers-Support
Once downloaded, install the printer using the new obtained driver. Hope the new driver would work on your computer. Moreover, you may change the USB port to which the printer is connected, meaning unplug the printer from the computer and re-connect it to different USB port of your computer and try to install printer.
Cheers!
Mar 02, 2010 | Microsoft Windows 7 Ultimate for PC
Unable to print
With the Lexmark printers communication subsystem you MUST let the driver ask for you to plug in the printer. DO NOT plug the printer into the USB port until told to do so.
To fix a fouled install :
(1) Uninstall the Lexmark drivers in Add Remove Programs
(2) Shutdown the computer
(3) Disconnect the printer from the USB port
(4) Restart the computer
(5) Run the Driver Installation software
(6) Cancel ALL attempts by windows to auto install the printer
(7) When the sofware asks for the printer connect it and continue
Sep 07, 2008 | Lexmark X73 All-In-One InkJet Printer
Ibm think centre a 30
Windows XP has Drivers within the operating system to Install and setup USB Ports.
Here Are your options to Provide A Fix.
1: )The USB Port May Be Disconnected From The motherboard.
2:) The Device you are trying to Connect ( Pen-Drive ) May be faulty And Not Recognised By The Computer.
3:) The USB Cable Or Socket May Be Faulty.
Solution:- Try Connecting the Device To An Alternative ( different ) USB Socket On The PC.
Solution:- Try Connecting a Different Device to the USB Port. i.e MP3 player Or Digital Camera et,c.
Solution:- Check that the USB Header Cables ( from Motherboard To USB Ports ) Are connected Or incorrectly Connected.
Mike @ Compurepair.
*****Common Sense Comes As A Built In Feature*******
Feb 28, 2008 | Computers & Internet
367 people viewed this question
Top SATO Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
mukhtar21 shaikh
mukhtar21 shaikh
Are you a SATO Office Equipment and Supply Expert? Answer questions, earn points and help others
