7.5kg Top Load Whirlpool Washing Machine 6ALSQ8000MW
the dr
  • 447 Answers
SOURCE: whirlpool top load washing machine - agitator
There are gears inside the agitator that are very cheap and relatively easy to change they are called agitator dogs. Dont forget to rate my solution as solved if i answered your question accurately.....Thanks!!
Posted on Oct 01, 2007
jsrock516
  • 5911 Answers
SOURCE: how to take apart a Whirlpool top loader washing machine
If you have not taken the exterior washer casing off, the first steps will explain how to accomplish this:
1. Unplug washing machine.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer. The cap will pull off towards you as you are facing the unit from the front of the washer. There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up. There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Under the console will be two large brass colored clips. Take a large flat blade screwdriver and place it in the groove of the clip on the washer top. With the screwdriver firmly in the groove, push away from you towards the back of the washer. This will release the clips.
5. Disconnect the lid switch connector plug. This is the white colored plug on the washer top under the console.
6. Remove the washer casing. Open the lid of the washer. Using one hand, grip under the front rim of the washer opening. Do not grab the wash tub, just the casing. Tilt the washer case from the back first towards you, slide forward slightly, and then lift up. The entire case comes off exposing the wash tub and components.
Once the casing is removed, you should have full access the the washer interior components. Since you have mentioned you taken the "internal post" off (I'm assuming this is your agitator), I will spare the steps in involved in accomplishing that task.
Next, follow these series of steps:
1. Remove the tub ring. This is the cylindrical donut shaped ring attached to the top of the wash tub. This ring needs to be removed in order to accommodate the removal of the inner spin basket. The tub ring comes off by placing a screwdriver under the series of the tabs that hold it in place and GENTLY prying them up until they release. Be careful not to break off the tabs, or crack the wash tub.
2. Remove the spanner nut that is under the agitator. This holds the inner spin basket to center post.
3. With the spanner nut removed, the spin basket should lift straight up and out. Sometimes the basket will stick to the center-post and may required some "coaxing" to get it free. This can be accomplished by grabbing the rim of the spin basket and prying up on one side, then the other, in an attempt to rock the basket side to side.
Searspartsdirect.com has excellent exploded view diagrams that you can use as a reference. Simply type in your model number and look under the "Agitator, Basket and Tub" heading. The tub ring gasket, I mention below, is listed as item 6. Appliancepartspros.com also has these same drawings.
Some things to consider:
If you remove the tub ring, it is recommended that you replace the seal on the ring before reassembly. Once the tub seal is broken, it can leak if the seal is not replaced.
When reinstalling the exterior cabinet, follow these steps:
1. Re-install washer case. With the lid of the washer open, place grasp case under front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame and rocked back onto the frame to ensure that the small cleats on the frame fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
2. Make the back of the washer fits into the washer casing on each side and reinsert the brass clips. Place the clip into the slot on the back of the washer first, and then forcefully push it into the opening on top of the washer. It will snap back into to place.
3. REINSTALL LID SWITCH CONNECTOR. It is easy to forget. If you do not reconnect it, the washer will not work correctly.
4. Reinstall console.
If you have questions, or need further assistance, please let me know. I hope this helps you.
PS What is the reason for removing the spin basket? Anything else I can help you with?
Posted on Jan 17, 2009
SOURCE: I have a Whirlpool coin operated top load washing
I hate this
try insert another coin
if not you will have to run a wire through and a frictioned and magnetised coin might help
if you can you will have to dismantle this part in trying to release it
Posted on Sep 27, 2009
57 varieties
  • 1653 Answers
SOURCE: My whirlpool duet front load washing machine stops in mid cycle
F21 = LONG DRAIN ERROR
If the drain time exceeds 8 minutes the water valves turn off. After 4 minutes the “Sd” error will be displayed, then 4 minutes later the F21 error code will be displayed.
Press PAUSE/CANCEL two times to clear.
Procedure:
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
5. If the above does not correct the problem, go to step 7.
6. Unplug washer or disconnect power.
7. Replace the pump.
Alternative Procedure:
If the machine cannot be forced to its diagnostic mode then:
1. Disconnect the washer from the power supply and water supply.
2. Remove the top panel by taking out the three screws in the back of the washer. The pressure switch is right on top.
3. Remove the Molex connector from the water level switch / pressure switch.
Refer to the picture below.
4. Reconnect the power supply but not the water supply.
5. Power the machine. The machine will enter diagnostic mode.
6. Power off the machine.
7. Replace the water level switch / pressure switch.
8. Reconnect the water supply.
9. Power on the machine it will work without error
Posted on Oct 02, 2009
SOURCE: GIVING ELECTRIC SPARK INSIDE THE WASHING MACHINE DURING RUNNING
washing machine motor sparks during spinning
Posted on Oct 03, 2009
My machine 5kg how many cloth put in side like pant shirt
hard to say--- kids pants and shirts or 5xl pants and shirts
best gauge is just to drop the clothes in loose and when they are around near the top of the agitator , that is a load
Aug 13, 2016 | Washing Machines
Need user manual for whirlpool AWG 5061/M --600RPM AA 5Kg
I NEED USER MANUAL BOOK FOR WHIRLPOOL FRONT LOAD W/ MACHINE MODELS NO AWG-5061/M AA 5KG 800 RPM please send it to me on fayaz_1966@yahoo.com I will be greatful to you Thanks
Nov 03, 2010 | Whirlpool AWG329 Front Load Washer/Dryer
My Whirlpool Washer will not spin tub
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Nov 01, 2010 | Whirlpool LSR9434PQ Top Load Washer
My Whirlpool Calypso Top Load Washer isn't draining or spinning. What can I do?
heatman101
Sep 07, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
I require a user manual for a Whirlpool AWG5122 5kg 1200 spin washing machine
if you go to the whirlpool web site under support you should be able to download one.
Apr 07, 2010 | Washing Machines
I need to replace the lid switch on my whirlpool washing machine super capacity plus model 6ALSQ8000MW
RepairClinic.com (which is good)
espares.co.uk
AppliancePartsPros.com
Try these sites.
Jun 06, 2008 | Whirlpool Washing Machines
Washing Machines Logo
81 people viewed this question
Top Washing Machines Experts
