Question about Watches
How do you fasten a theorema copacabana watch
How can I open back?
Unless it is fastened by tiny screws, the usual removal method is to pry it open by "knifing" it. Watch a jeweler at work to learn the technique.
Jan 16, 2013 | EOS Ice Watch In
Name the projection of a watch to which strap is connected?
The projections on the body of the watch to which the straps are fastened are called "lugs".
Feb 12, 2011 | Caravell e 43B41 Beautiful Strap Watch...
I need to get my battery out of my pockt watch
There seem to be several methods of fastening watch backs.
If you go to "www.thewatchguy.com/pages/OPENCASE.html" there is a description of the range of options for old watches that should cover yours also.
Mar 02, 2010 | Watches
Adjust Watch Band
Click on my profile, then click on TIPS AND TRICKS. There you will find explanation how to add or remove links. Rate me, plz.
Feb 24, 2010 | Timex Ironman Triathlon Hi Ti Watch,...
Adjust the band on my merona watch
at the back side of bracelet you can find direction mark, use fine and strong pin with tiny hammer to remove pin out. if there no mark , just look at both side of bracelet, thru narrow hole push your pin, then fastening pin come out thru wider hole
Feb 23, 2010 | Bulova Watch
How to fasten a Skagen watch?
Hi there. Insert the mesh strap inside the hole and secure with the hook and clip fastening with a foldover security clasp.
Hope this one helps.
May 16, 2009 | Skagen Slimline Mesh 358SGS Wrist Watch
The user guide is wrong
I have a Theorema Parago Automatic through not wearing it regularly it sometimes stops. Winding it wouldn't solve the problem and I couldn't find a solution either on the Theorema site or online so through a series of self help efforts the following is the solution for this watch 1 Set the watch to the correct time date day etc. 2 Wind the watch using the side winder for about 40 revolutions in clockwise rotation 3 Hold the watch in your right and strike it firmly into the stiff palm of your left hand. This gives the winding mechanism a shark shock and kicks it back into life.The watch then works away without a problem.
Nov 17, 2008 | Ebel Tarawa Automatic 9127J40/5435136...
Watch stops
sounds like the oil is contaminated and causing undo friction or the main spring is ether broken or slipping. Time to service your watch. call me 707-338-3207 www.finewatchmaking.com
Mar 01, 2007 | Ebel Tarawa Automatic 9127J40/5435136...
Watches Logo
126 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
