Hi, I am facing issue with my Access control
Hi, I am facing issue with my Access control which is Syirs SYW95AV3. Its gives error like " Not found communication keypro in COM. please check it or Restart." Can someone look into it. Thanks,
techman
  • 3130 Answers
SOURCE: "reinsert the cassettee" error in Sony HandyCam CCD-TRV 438E.
The camcorder most likely is not detecting the tape, you have a bad sensor and these sensors all come on a flex type board and the flex board is mounted on the chassis surface. This will mean that the entire mechanism will meed to be diassembled, and is a very big and costly job. My opinion is that this repair will run you abut 250 to 300 bucks and this camcorder is not worth this as new camcorders are under 200 bucks. Good Luck
Posted on Apr 03, 2007
shaggyrat
  • 1224 Answers
SOURCE: Fujitsu Error
try a new paralel or usb cable you might have gotten a defective cable
Posted on May 26, 2008
SOURCE: Xerox DC12 gives error 14-372 please HELP!!
ERROR 14-372 ROS MOTOR FAIL , ITS THE MOTOR THAT ROTATES THE POLYGON OF THE LASER BEAM , ITS LOCATED , BELOW THE SCANNER UNIT AND OVER THE COPY/PRINT CTG. 13R557/13R558 . IT CAN BE ONE OF 3 THINGS THE ROS ASSY. (LASER SCANNER UNIT OR ROS) , IOT DRIVE PWB(THE PC BOARD BELOW THE NVM AND IOT-SYS) OR A PROBLEM ON THE WIRING HARNESS / POWER SUPPLY. WE CAN REPAIR THOSE UNITS OR I CAN PROVIDE YOU THE PART NUMBERS IF YOU WANT TO ORDER THEM NEW FROM XEROX . diesco_cxl@hotmail.com
Posted on Mar 26, 2009
Katwal
  • 129 Answers
SOURCE: I have an LG KS360 phone with a T-Mobile account.
I need some clarification about the connection which you are referring to Sync the details.
Are you trying through bluetooth or USB?
If through USB, please use the PC suit given by the manufacture(LG). It help you to connect with USB. For Sync you does not required internet connection but your outllok should be the default email client in windows and properly configured.
If you face any problem again please contact me personally at katwal.raman@gmail.com.
Posted on Sep 14, 2009
  • 11967 Answers
SOURCE: The error is Lens error, restart camera. If
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Sep 27, 2010
My RSD30S Dacor Range is giving an F1 error code for a while now. What is the expected total cost of repair?
Hi
Error code F1 means that an error with the keypad has occurred. Usually it happens due to loose ribbon cable on the keypad or the electronic control assembly itself going bad. To resolve this issue first, disconnect the power to unit and then gain access to the back of the clock assembly (Electronic Range Control/ERC). Now unplug the touch pad ribbon connector from the ERC, it would be a flat wire approx. 1 1/2" to 2" wide and make sure that the cable is not broken and nothing is shorted on the keypad. After this is done insert the cable back and then plug the unit back to check. If the error is still there then the electronic control board should be replaced. Hope this helps...please post back for further assistance.
Daniel
Jul 26, 2011 | Kitchen Ranges
Adobe reader wont work i get error 1402
file:///C:/Documents and Settings/ACER/My Documents/My Pictures/error 1.bmp
Aug 02, 2010 | Adobe Computers & Internet
Can somebody help me fix this error message in windows. ''windows cannot access the specific device path or file. You may not have the appropriate permission to access the item.'' Toshiba laptop with...
Hi ,
This is an issue with the permission set for a particular program so what you can do is right click on the file or a program that you are trying to access then click on properties and under the security tab you will see Group and user names and below that u will see permissions so click on the advance option select the user and then click on edit and then click on the box that says full control and then click on apply ok .Also click on add and then type in everyone and give full control .You can al so create a differnet user account as an administrator ...
all the best
May 09, 2010 | Computers & Internet
I m connected yahoo messenger while i m open cam that time give a massege 'a network error occurred while connection to the server '
HI,
This type of issue is usually solved by reinstalling the particular software which is giving the network error.
Please reinstall the yahoo messenger and let me know if you still face the same problem or not.
Thank you for using fixya.
Nov 17, 2009 | Labtec 961307-0914 Webcam
F11 error
Hi
Thanks for using FixYa. Error F11 means it is a serial communication error between the Central Control Unit (CCU) and the Motor Control Unit (MCU) and the communication cannot be sent correctly to these units and the washer. To resolve the issue you are facing with, please check the wire harness connectors to the MCU, then the motor and Central Control Unit (CCU). Also please check the drive system for any worn or failed components, MCU, CCU, motor and wire harness.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jul 29, 2009 | Whirlpool WFW9600T Front Load Stacked...
I cant access my yahoo mail? ERROR CODE 1
I think you might be able to use a mail program like windows mail or incredimail (free download) and then import your yahoo stuff, Yahoo is a pop server so you should be able to open windows mail create a new account and get the server information from yahoo support, I know the one will probably be pop.yahoo.com and the smtp server should be smtp.yahoo.com not too sure but give it a shot...Steve
Jun 13, 2009 | Yahoo Mail
Unable to Login to Yahoo Mail.
Hi yahoo
i am unable to log in my yahoo account..if i typed my user name and password ..again it comes same log in page ..
and i am able to access my email in my blackberry device ..only my desktop i am not able to log in ...
pls help me some one for this problem it will grate for me
Nov 30, 2008 | Yahoo Mail
ERROR IS (MEMORY ACCESS VOILATION C0000005)
I AM FACING LOT OF PROBLEM DUE TO ABOVE SAID ERROR ALL THE OTHER SOFTWARE IS RUNNING PROPERLY EXECPT TALLY 7.2
TALLY IS OPEN UPTO SELECTION OF COMPANY AFTER THE COMPANY SELECTION AT GATEWAY OF TALLY IT SHOWS THE ERROR MEMORY ACCESS VOILATION C0000005
Nov 12, 2008 | Tally Line Matrix T6050 Printer
Washing Machines Logo
35 people viewed this question
Top Washing Machines Experts
