Question about Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television
Zenith E44W46LCD Lamp Access Door Location
I need to replace the Lamp on my Zenith E44W46LCD and do not know where the access door is located at. Can you point me in the general direction?
  • 3 more comments
  • Anonymous Mar 17, 2008
    Mine is not there, it looks like it is to the left of the fan but I don't know how to get there, Is there anymore places I could look.
  • Anonymous Mar 24, 2008
    yes but can't find the location of bulb?
  • hawkonevoodo Oct 14, 2008
    The fan is in the middle of the rear panel and the only panel to the right is where all the cables plug in or attach. This is what the back of mine looks like. Your help would be very much appreciated.
  • Anonymous Dec 12, 2008
    I HAD the same problem until you all helped me out. Never again will I pay 350.00 for a repairman to insert a bulb. Thanks!!
  • Anonymous Dec 15, 2008
    how do you replace bulb?
I found the location to get at the lamp. If you are loking at the front of the TV there is a small panel at the bottom of the right end. Two screws, remove panel, two screws inside and a small handle that lifts so you can slide the unit out. 4 screws on top of the cage that the lamp sits in, carefully slide up the silver bracket holding the bulb, be careful the edges are sharp. Remove the bulb from bracket and remove the 2 cables attached to the bulb. Now just do the same but in reverse. Make sure you wear plastic gloves that should be provided because if your fingers touch the lense you could be out the price of the lamp.
Posted on Oct 14, 2008
Techman, do you know how to reset the lamp timer?
Posted on Jul 09, 2008
Techman on the money!!
Posted on Jul 01, 2008
There's a large panel, (2 screws) on the right side of the tv.
Unscrew it, remove the panel and there will be another panel within it. Unscrew the next set of 2 screws, pull on the silver hatch and the light housing will come out. Unscrew the 4 screws at the top of the light cage, slide the bulb up via the silver front panel and you're all set.
Posted on May 07, 2008
    President:
  • 3,130 Answers
There is a cover for the fan filter onthe lower left hand side of the set if your looking at it from the rear. Right next to this filter cover to the right and up a little is another cover with two screws on it. You open that cover and there is the bulb. Good Luck
Posted on Sep 01, 2007
I am trying to figure out how to replace my replacement lamp, but do not know where it is located.
Lamp Access door for Sony KF50WE610 is below the screen on the front of the TV. This page shows location of Lamp access door and DIY bulb change instructions for most SONY LCD TVs:
DIY Bulb Installation Guide
XL-2000 XL-2100 XL-2200
XL-2400 XL-2500 XL-5000
XL-5100 XL-5200 XL-5300
This page shows Lamps and bulbs for all Sony LCD Projection TVs
Sony Lamp Gallery
Look at Optical Engine Faults before buying a lamp or bulb. Replacement bulb will not repair these problems.
Feb 05, 2011 | Sony Grand WEGA KF50WE610 50" Rear...
How do i get the lamp out ..in order to replace it ?
Frtom the front of the tv, go to the right and lower portion of the tv, you will find an access door, this door has one screw holding it in place, remove the screw and door, inside you'll see a black plastic cover that has two screws and a metal handle, remove the screws and pull the lever evenly, this will pull ot a cage, inside that cage you'll see the lamp. refer to the following link for replacement instructions. http://www.kewego.com/video/iLyROoafYw6f.html
Feb 03, 2010 | Zenith E44W46LCD 44" Rear Projection...
How do you get the bulb out to replace it?
depending on model .Some models have access door on left or right side of tv .On some models access door is on back .Access doors will be about 6 inches squared .If tv does not have access door.Then you will have to remove rear bottom panel.Make sure to wear clean gloves when installing new lamp as not to tough lamp with fingers.
Jul 30, 2009 | Zenith Z62DC1D Television
Replace lamp light led on.
There is an access door on the back ( or side ) and the lamp is usually held in by two phillips screws. very easy to change yourself.
Apr 15, 2009 | Zenith E44W46LCD 44" Rear Projection...
Lamp has been replaced but TV wont power up?
If the lamp is a known good one, the next most likely suspects are the lamp ballast/power supply board or a mis-aligned lamp door. There's an interlock switch which opens when the lamp door is removed. Try removing and re-installing the lamp and the door.
Feb 15, 2009 | Zenith E44W46LCD 44" Rear Projection...
Zenith replacement bulb
I would suggest to remove the lamp from your TV and check it. You can also just buy the lamp without the other hardware.
This site seems to have good prices.
Let me know if you need any more assistance.
Mar 26, 2008 | Zenith E44W46LCD 44" Rear Projection...
Lamp
it is located on the lower right side of the television
Mar 18, 2008 | Zenith E44W46LCD 44" Rear Projection...
Color Fading on Zenith E44W46LCD
you neeed to change the lamp. the access is located on the right side of the television. you can buy the lamp for about $125 from discount-merchant.com
Mar 10, 2008 | Zenith E44W46LCD 44" Rear Projection...
Replacing LCD Lamp
The lamp may not be the defective part as the ballast board has been known to cause problems with this model - Part#6913v00002c You didn't mention how long you have used the set, and I believe the lamp should last at least 4000 hours. The lamp is usually replaced by opening a door by taking out one or two screws in the back or side of the set.
Dec 29, 2006 | Zenith E44W46LCD 44" Rear Projection...
Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television Logo
2,400 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
